Re: Building your own headers [Re: CMcAllister] #2573106
11/02/18 04:51 PM
11/02/18 04:51 PM
Washington
madscientist Offline
Washington
Originally Posted By CMcAllister
It's a fun, relaxing way to spend a few days, especially if it's a piece of cake like a Hemi or an RB in an A body with stock suspension. I would not suggest it for your first project if you just bought a new welder and decided to teach yourself how to make stuff.
You and I certainly have a different definition for fun and relaxing!!! I've built several sets of headers and I'll never do it again. Last set was a set of 2.125 X 28 x 4 in an early A with the engine set back 8 inches AND torsion bars.
New swear words were invented. The bad thing was I had 12 inch collectors and really needed to be at 18 or a bit more but just didn't have the room.
Re: Building your own headers [Re: racerx] #2573194
11/02/18 08:19 PM
11/02/18 08:19 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
First, Kudos to everyone who posted pictures of headers they've made. Pretty nice to super nice work. All very impressive. The mandrel from the slug is very clever. up
Originally Posted By racerx
Can anyone give some tips or tricks on building your own headers?
Some good threads on speedtalk about building headers.
Join the speedtalk forum so you can see the pictures. The only e-mails you'll get are those from Speedtalk itself - maybe once a year or two. This one is long but lots of good info in it.
First Time Header Build - Speed talk
Although the guys there prefer 421, we found it too be very difficult in my Barracuda. (We really being Brian Slowe, as he did all the real work) Passenger side is really tight. 4 in 1 would be easier.
Whether or not going for a narrow rpm band, Calvin Elston's perspective on tube size and length off the head is really interesting. If interested, check out his posts in this one
What is (exhaust) Blowdown Length? p.2
and poke around his blog.
http://www.exhausting101.com/?p=37
Another place with building tips is Headers By Ed's website and booklets. If you have the ground clearance, his designs are pretty nice and because they are multi-piece, easy to install.
Re: Building your own headers [Re: HardcoreB] #2573203
11/02/18 08:51 PM
11/02/18 08:51 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I try to 'size' them dimensionally with consideration of what upgrades may be in the future for the application. Put the collector in place first, ideally on a fixture to hold in place. Route the rear tubes for each bank (i.e. 7,8) out the inner fenders and around the frame. Route the tubes CW or CCW respective to the engines firing order. Build the most compromised tube or tubes first so they flow as good as possible. Don't sweat equal lengths. Make S.plugs and wires easy to access. I use a hose clamp and cut out a section in the middle to allow tack-welding while holding tube in place.
Good ideals gents up i'm likeing the hose clamp /drill hole deal for tacking tubes.
Re: Building your own headers [Re: rickseeman] #2573212
11/02/18 09:05 PM
11/02/18 09:05 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Originally Posted By rickseeman
Nice
x2 up
Re: Building your own headers [Re: FastmOp] #2573216
11/02/18 09:14 PM
11/02/18 09:14 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Originally Posted By FastmOp
I have made a few sets. I'd charge $1500 plus materials if I was going to do a set.
Fastop or the top set for the turbo setup?
Re: Building your own headers [Re: racerx] #2573221
11/02/18 09:24 PM
11/02/18 09:24 PM
PA
moparacer Offline
moparacer  Offline
PA
I want to do a setup similar to what 69B1 Dart did on my Dart, With them exiting out the fender.
Read over a lot of threads but never see what guys are using for primary length on different setups. What are you guys with setups similar to mine using for primary length on Big block stroker setups? I have a 502 cid with Indys that probably makes 800 and something or so HP and have hooker supercomp fenderwells on it, that I know are killing it.
I was thinking something like 2-2 1/8 dia. with 32-34 inch long pipes?
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Building your own headers [Re: racerx] #2573225
11/02/18 09:35 PM
11/02/18 09:35 PM
tri-cities Washington/Denver, ...
5280Dart Offline
5280Dart  Offline
I mocked up a set using a kit supplied by gp headers, and set the mock ups to them for fabrication in stainless. $1800
https://www.gpheaders.com
https://youtu.be/j9knDsi-td8
https://youtu.be/9s1-AZcPWAA
Re: Building your own headers [Re: CMcAllister] #2573228
11/02/18 09:44 PM
11/02/18 09:44 PM
whistling I fixed it for you grin
Re: Building your own headers [Re: racerx] #2573347
11/03/18 09:57 AM
11/03/18 09:57 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
theirs a talented guy!! nice work!!
Re: Building your own headers [Re: racerx] #2573393
11/03/18 11:50 AM
11/03/18 11:50 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Yes that's for Ka-BLUE-E the Turbo Avenger.
The black coating has not held up as well as I had hoped. I think my next set will be stainless just so I can skip getting them coated.
I used a couple scrap pieces of aluminum and a couple hose clamps at the joints I wanted to weld to get everything lined up. Worked pretty good.
Re: Building your own headers [Re: FastmOp] #2573439
11/03/18 01:37 PM
11/03/18 01:37 PM
Fort Collins, Colorado
CoDart Offline
CoDart  Offline
Here are some headers and crossover pipe I made for my stock 440 big single turbo Dart. What a tight fit everything was grin
Re: Building your own headers [Re: FastmOp] #2573567
11/03/18 07:36 PM
11/03/18 07:36 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Take a look at plasma applied zirconium dioxide.
Its an industrial process but some places will do small jobs.
Swaintech in the US calls it "white lightning exhaust coating". Seems to have a good rep in turbo circles. I had a set of headers done by them but can't speak to the long term durability personally (sold the headers).
In UK and maybe Aus, Zircotech has several versions of this coating for exhausts. But its more expensive even before shipping.
https://www.zircotec.com/exhaust-coatings/
http://swaintech.com/race-coatings/automotive-coatings/automotive-coatings-price-sheet/
http://swaintech.com/race-coatings/race-coating-descriptions/white-lightning-exhaust-coatings/
Re: Building your own headers [Re: racerx] #2573571
11/03/18 07:49 PM
11/03/18 07:49 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I made a set of turbo headers over the summer. I never attempted to make a set before and didn't know what I was getting into over the comments about how difficult they are to make that I read online... I have to say it was 100 times easier than I expected. I bought a header kit to make your own for the pipes/bends and bought some good thick stainless flanges. A few afternoons they were pretty much done.
Just have a lot of bends on hand and it's pretty easy to do. No way I'd pay 2k to have a pair made.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Building your own headers [Re: FastmOp] #2573575
11/03/18 08:05 PM
11/03/18 08:05 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Fastmop were you useing header wrap on the turbo headers or running them unwrap?
Re: Building your own headers [Re: racerx] #2573580
11/03/18 08:17 PM
11/03/18 08:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
No wrap
Re: Building your own headers [Re: racerx] #2573627
11/03/18 10:04 PM
11/03/18 10:04 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Re: Building your own headers [Re: CrAzYMoPaRGuY] #2573734
11/04/18 02:47 AM
11/04/18 02:47 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Originally Posted By CrAzYMoPaRGuY
I made SURE the bends flowed, no tipped tubes/bends and no cheating. Smooth flow.
Then someone showed me a dyno test of a set of headers on a dyno, fresh headers that were then hammered like crazy. Not much difference on the dyno. Which to ME seems crazy!!!
I seen the same video I believe it was on a Road Kill episode. Basically shows that the header tubes were to big for the engine. It was interesting showing them beating the heck out of a new set of headers.
