How Much Gain In The Tune Up? #2572546
11/01/18 11:07 AM
11/01/18 11:07 AM
Spring Hill Fl
65Fury440 Offline OP
Spring Hill Fl
I have decided just to make the 100 plus mile trip to a chassis dyno.
It has been hard t get runs at the track.I mph at 117-118 11.6 secs
To recap, my heap weighs 4000 lbs with me in it.
I have a 520 ci rb stroker, 670 net lift cam 260@50
TF heads flowing 370 @ 700, 337 intake, 2 " primary headers.
Calculators say I am making about 550 hp. Not sure if they factor in shift changes for a manual trans.
After checking the AFR, with the exhaust intact, I am at 11.6-8 range at WOT. I do run it with exhaust off though, not sure how much leaner that would make it.
After getting a good dial back timing light, I am running 42 degrees total timing all in about 3000 rpms.
Any educated guesses on how much more power I'll make by leaning it up to high 13s and limiting the advance to 36-38?
Re: How Much Gain In The Tune Up? [Re: 65Fury440] #2572557
11/01/18 11:33 AM
11/01/18 11:33 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The motor “should” easily make in the 675-700hp range.
(MarkZ’s 505 with ootb TF270’s, gasket matched 337, similar sized cam as yours made a tad over 700/700 on the BES dyno).
Unfortunately, poorly set up street cars(especially those with a manual trans) rarely reward their owners with time slips representative of how much power the motor makes.
This is an example of(one of the many reasons) why I dyno anything I build.
If the motor had been dynoed, you’d know what it made, had it all tuned up, and have a reasonable idea of the potential performance in the car.
If the car was underperforming, you’d know it wasn’t the motor, so you wouldn’t waste time and energy trying to find the lost performance there.
At this point, the chassis dyno could be helpful.
FWIW, there is no such thing as a “good” dial back light, imo.
On the moroso chart 118@4000lbs shows 505hp.
With a reasonably well set up street/strip car, my experience has been that you should be able to run within 10% of the engine dyno numbers(provided they aren’t inflated).
If I assume the less than optimal manual trans set up costs you another 5%(15 total), and start at the low end of the predicted power output(670hp), you’re looking at running speeds that correspond with 570hp........ which would be 122.5mph.
However, without the dyno numbers....... we don’t know how much of that missing speed is lack of power, and how much of it is poor car set-up.
On a dyno jet with a manual trans....... you should be near 600rwhp, unless there are some serious fuel supply or exhaust system issues(or the motor is just down on power).
As an example of how good it can all work...... 69 A12 car in FAST......3900lbs, 600hp, 4 speed, g70-15 bias ply tires, ex manifolds...... 129mph in some killer air.
Re: How Much Gain In The Tune Up? [Re: fast68plymouth] #2572578
11/01/18 12:49 PM
11/01/18 12:49 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
The MPH only at 117-118 shows that it's really down on power from it's potential with the parts you have... As mentioned above it's hard to know anything by ET, but the MPH is pretty telling.
I can tell you when my car spins, and I have to let off the throttle, then get back on the throttle, it may loose .5 sec in ET, but always comes back around on the top end within 2mph or so. Foot on the floor in high gear, there isn't much car "Setup" that can change that.
Hopefully you find something on the Dyno. I've seen so many simple things (bad timing light, throttle cable misadjsuted and carb not going WOT, etc...) The parts in the motor have good potential...
Re: How Much Gain In The Tune Up? [Re: 65Fury440] #2572625
11/01/18 02:39 PM
11/01/18 02:39 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
What's the gear in you ride???
5.53 @ 125 1/8th on the launch control..more left in her!
Re: How Much Gain In The Tune Up? [Re: 65Fury440] #2572628
11/01/18 02:48 PM
11/01/18 02:48 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Truth. Unfortunately, timing lights have become as common as carb adjusting tools in a regular mechanics box. Do a search here. There have been a number of conversations on the subject.
Re: How Much Gain In The Tune Up? [Re: Eric] #2572645
11/01/18 03:25 PM
11/01/18 03:25 PM
Spring Hill Fl
Spring Hill Fl
4.10 with 26x10.5 " bias ply
It does best to leave at about 2k rpm or I just boil them off.
I have CalTrac split leaf monos, just need the rest of the set up.
Re: How Much Gain In The Tune Up? [Re: CMcAllister] #2572646
11/01/18 03:27 PM
11/01/18 03:27 PM
Spring Hill Fl
Spring Hill Fl
I see that now.
My buddies Snap on dial back is 4 degrees retarded from my eons old Craftsman.
Where mine shows 18 and 38 degrees, his shows 22 and 42.
Re: How Much Gain In The Tune Up? [Re: 65Fury440] #2572658
11/01/18 03:51 PM
11/01/18 03:51 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
For the reasons stated above worry less about what the number is and more about how it reacts when you move the timing. Just make sure you use the same timing light for verification later on.
68 Barracuda Formula S 340
Re: How Much Gain In The Tune Up? [Re: Bad340fish] #2572661
11/01/18 04:05 PM
11/01/18 04:05 PM
Spring Hill Fl
Spring Hill Fl
Hopefully the dyno operator has a good light.
Will be nice to know whats going as far as peak HP and torque points.
I was just curious how much I might expect to gain by jetting and timing.
Re: How Much Gain In The Tune Up? [Re: dizuster] #2572664
11/01/18 04:07 PM
11/01/18 04:07 PM
Spring Hill Fl
Spring Hill Fl
For sure, I have no idea where the torque or HP peak is. I shift at 6500, maybe need to stretch it out more.
Re: How Much Gain In The Tune Up? [Re: fast68plymouth] #2572667
11/01/18 04:17 PM
11/01/18 04:17 PM
Spring Hill Fl
Spring Hill Fl
Thanks for taking the time to explain those points.
When it was all put together, the build went from a tow truck motor to an RPM deal, because the goal was to keep it under the hood with the 337 intake.
The plan was for it to be all done by 6k. I want to go to a roller cam, and will call you for a recommendation when the time comes.
I don't power shift it, that seems like a slow shifting manual would skew the calculators from a fast shifting auto.
Optimizing the tune will help, just was wondering what guys with experience tuning would see, 50hp? 100hp?
Thanks again for your time.
Re: How Much Gain In The Tune Up? [Re: 65Fury440] #2572670
11/01/18 04:27 PM
11/01/18 04:27 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Just as a comparison, my car weighs in at 3926 with me in it and a half tank of gas. 493 stroker. cam is 259/266, 623/633 lift with 1.6 rockers. 4.56 gears. Stock 18 spline tranny. My 60' are a little slow at 1.55 range, but my et's are all in the low 11's at over 123 mph. I run my car with mufflers. It has gone high 10's with open exhaust. My carb is a 1050 AN. 85/92 jets. .070/.030 bleeds. Timing is set at 37* all in at 1800 rpm. I hope this gives you a starting point. Also, my car is a street car mostly. I really don't push the rpms at the track.. I shift at 6k at trap around 6400.. No use in beating on it as I already know what she is capable of.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: How Much Gain In The Tune Up? [Re: 65Fury440] #2572689
11/01/18 05:01 PM
11/01/18 05:01 PM
So. Burlington, Vt.
So. Burlington, Vt.
There are countless motors I’ve tested where I’ve forgotten I even tested them, much less the details about what was done on the dyno, but I can’t think of a single instance where I picked that kind of power by “tuning”.
Usually, when they’re down on power that much, something needs replacing.
I can think of a time or two where there was 30hp or so found in messing with the carb........but that was something that was totally out to lunch to begin with.
Unless you have something pretty far off from what the motor wants, I’d say if you picked up an honest 15hp, you’d be doing okay.
But, that’s why you test......... you might have something that’s way off.
Buy yourself a non-dial back timing light.
Re: How Much Gain In The Tune Up? [Re: fast68plymouth] #2572696
11/01/18 05:23 PM
11/01/18 05:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Years ago on a chassis dyno we picket up 60+ hp at the tires on my 470 messing with timing, jet and bleed changes.......I was way lean and needed more timing iirc and that's when I got a WB and really started studying the different circuits in a carb. Found out about changing the curve with bleeds and how Holley's tunes were quite wacky in my case so after many low 10 second passes, I got my first 9.98 pass...........Lots to learn on the dyno to at least get ya close and in some cases, bragging rights backed up with respectable et's..... beer
Re: How Much Gain In The Tune Up? [Re: 65Fury440] #2572702
11/01/18 05:44 PM
11/01/18 05:44 PM
Washington
madscientist Offline
Washington
When you go to the dyno, do NOT let the dyno operator only tune with his light. Bring the light you are going to use and check your light against his.
I don't really care what numbers the timing light shows. What matters is you use the same timing light every single time. I don't care if it shows your car runs better with 60 on it.
The best situation is to buy a quality timing light and use a degreed damper. Why is your damper not degreed?
Also, you need a minimum of a 4.56 gear. Probably 4.88 because you don't have enough first gear to move that weight.
Re: How Much Gain In The Tune Up? [Re: Thumperdart] #2572703
11/01/18 05:45 PM
11/01/18 05:45 PM
Spring Hill Fl
Spring Hill Fl
Next steps will be a roller cam and Thumper 1050!
Re: How Much Gain In The Tune Up? [Re: 65Fury440] #2572717
11/01/18 06:17 PM
11/01/18 06:17 PM
I've slow a mid ten second car down by advancing the timing beyond 36 degrees up to 38 ( over .10)and slowed it down again by going to 40 degrees tsk We where intentionally trying to slow the car down from mid 10.60 to run S/ST at 10.90, we ended up short shifting the 1st and 2nd gear shift points down to 5500 RPM and reduce the total timing to 30 degrees to get their wrench We tried adjusting the throttle cable to not go to full throttle but went back to full throttle off the line and tried other things to slow it down wrench Over revving the shift points to 7000 RPM in both gears was worth right at .10 reduction also work
This was a long time ago,1984, long before throttle stops and the electronic aids available now.
Re: How Much Gain In The Tune Up? [Re: 65Fury440] #2572760
11/01/18 08:15 PM
11/01/18 08:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Like we talked, at that weight either a skirted banjo straight 1050 Dommy for the wow factor or a BLP Billet 1.610 bore 4150 that I have on 8000 rpm puller trucks, boats, street strip and drag only cars/trucks. You need velocity to move 4000 lbs. and those Billets deliver across the board........ thumbs
Re: How Much Gain In The Tune Up? [Re: 65Fury440] #2572840
11/01/18 11:14 PM
11/01/18 11:14 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow you are way down on power for that bad boy. As said MPH will tell you what kind of power the eng is making. I agree with use one timing light and set it for best power on the dyno. Honestly if the timing light is right then 42 sounds to high as most of these engines with modern aluminum heads seem to only need between 32 to about 38. To much in high gear once rolling can actually hurt power some. Many racers would actually retard the timing some in high gear once the cars weight is moving along. As said if you can get the car on a chassis dyno and tune from there it will help a lot as you are definetly missing some power that your eng should be making. As for shift rpm ??? Maybe I am just an old fool but 99% of the time I race I never even look at the tach going down the track. I just shift by how the eng is pulling by the feel of it. When it feels like its done pulling and peeking out I shift. Then I can mess with it some from there but my car is very consistent when I just shift by how the eng sounds and feels to me. And I don't think your shift point is the problem you have. Heck it could be as much as an improperly adjusted throttle cable which I am sure you have checked ? Good luck with it but get it on a chassis dyno and if you have any friends who are very good with hotrods and engines take them with you as the more heads thinking on this can be better to help find the problem. Good luck and keep us posted. Ron
Re: How Much Gain In The Tune Up? [Re: Thumperdart] #2572872
11/02/18 12:54 AM
11/02/18 12:54 AM
Spring Hill Fl
Spring Hill Fl
Thanks for taking time to chat.
Just as an FYI, the car weighs 3740, I weigh 260, so the race weight is 4K.
So you don't think the flow pattern hitting 6500 rpm would be better on a 4500?
I'm all ears.
