Re: Dana 60
[Re: moparx]
#2572987
11/02/18 12:37 PM
11/02/18 12:37 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I hear they were made in a lean-to right behind Chrysler Corp by 3 Amish guys and a MOPAR engineer.
Re: Dana 60
[Re: cdwmotorsports]
#2572992
11/02/18 12:52 PM
11/02/18 12:52 PM
crabman173
crabman173
FWIW check out Gail Banks ( yea the turbo guy) he did an extensive testing on aftermarket aluminum housing backs--they all kept oil off where it needed to be etc and were awful compared to stock covers that direct oil exactly where it needs to be VERY interesting--On Youtube somewhere or easier to find on Bangshift.com Very extensive testing--amazing results--MUCH to learn from there
Re: Dana 60
#2573025
11/02/18 02:08 PM
11/02/18 02:08 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
While Gale's testing was impressive and interesting I am not sure how much it applies to drag racing where we only load these things down for a few seconds.
68 Barracuda Formula S 340
Re: Dana 60
#2573041
11/02/18 02:29 PM
11/02/18 02:29 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
Mine is an original 3.54 1968 B Body piece, however I actually got it from a Camaro. Needed some work like ladder bar brackets cut off, a going through and a gear change. Had 4.88s in it when I got it, a little too much for me. Dr Diff helped a bunch with all the parts. Chevy parts are usually reasonably priced so that worked out pretty well.
Rich H.
Esse Quam Videri
Re: Dana 60
#2573047
11/02/18 02:39 PM
11/02/18 02:39 PM
Posts: 11,737 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
8.75, D60, 9 inch - they all have their specific place and applications where they are the best choice. I would have no problem using any of them, in the application where they would work best. Big difference between a nice weekend driver, a fast, light weight, tube chassis car and everything in between.
Re: Dana 60
[Re: CMcAllister]
#2573115
11/02/18 05:09 PM
11/02/18 05:09 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
8.75, D60, 9 inch - they all have their specific place and applications where they are the best choice. I would have no problem using any of them, in the application where they would work best. Big difference between a nice weekend driver, a fast, light weight, tube chassis car and everything in between. I could not agree more, you are not alone on this!
"Just a Bracket car dressed up like a streetcar"
Re: Dana 60
[Re: A727Tflite]
#2573149
11/02/18 06:30 PM
11/02/18 06:30 PM
dartman366
Mt. Vernon, Ohio
Anyone know for certain what Dana came in a 1976 Dodge Van cab/chassis used for motor homes?
360 engine, about 20-22 foot long tandem wheel unit. good probability of a dana 70 those were used in a lot of C@C's ambulances and motor homes, there should be a cast in number somewhere on the center section designating if it is a 60 or 70.
Re: Dana 60
[Re: A727Tflite]
#2573155
11/02/18 06:48 PM
11/02/18 06:48 PM
Posts: 298 mt. pleasant, PA
Diplomat440
mt. pleasant, PA
360 engine, about 20-22 foot long tandem wheel unit. I'd say if it's a dually, it's gonna be a Dana 70.
Re: Dana 60
[Re: A727Tflite]
#2573224
11/02/18 09:35 PM
11/02/18 09:35 PM
Posts: 43,311 Bend,OR USA
Cab_Burge
It depends on the motor home company and what they ordered their chassis with ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I bought a burnt out, burnt down to the floors, Class C 24 Ft. Dodge (1976 or 1978 model year)360 with a 727 tranny motor home chassis years ago to get the dually rear end to use in one of my old car hauler, it was a Dana 60 HD with 4.10 gears and 30 spline axles. I broke, twisted it off on the housing, the left axle is the only reason I know it had 30 spline axles in it That happened while racing my bracket car, not the truck ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) at the Division 7 bracket finals in the late 1980s, one of the other racers welded it back together for me on the back of his open car trailer at the track and I drove it that way for three or four more years until I sold it That was a 1957 Dodge one ton 4 speed truck tranny and chassis converted into a car hauler, the frames on the early Dodge trucks where several inches wider than either Ford, Chevy or I.H. chassis so that motor home chassis rear end ended up being a answer to my prayers, the width and leaf spring perches where exactly dead nuts to fit that old wide truck chassis ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif) The original rear end was shot, 4.89 ratio ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) and sung to me all the way to the races and back ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) The 4.10 ratio was the cats meow ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) It had little bitty short 7.00 x 16.5, I think that was the size, tires on the rear. Nothing taller would fit without extensive chassis mods
Re: Dana 60
[Re: pittsburghracer]
#2573278
11/02/18 11:46 PM
11/02/18 11:46 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
A 9" is not going in my car, if I don't do a Dana 60 I will keep the 8 3/4. I'm not cross breeding my cars. You do realize that Mopar didn't make the Dana rear end and it was available to ALL car makes. LMAO. Dana Corporation. Yep, and this statement "available to ALL car makes" allows me to use it and not feel bad about it. Also it isn't the Ford 60 or the Chevy 60 so...
eBay-cdwmotorsports
Re: Dana 60
#2573284
11/03/18 12:10 AM
11/03/18 12:10 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A 9" is not going in my car, if I don't do a Dana 60 I will keep the 8 3/4. I'm not cross breeding my cars. You do realize that Mopar didn't make the Dana rear end and it was available to ALL car makes. LMAO. Dana Corporation. Yep, and this statement "available to ALL car makes" allows me to use it and not feel bad about it. Also it isn't the Ford 60 or the Chevy 60 so... So with your thinking my powerglide isn’t GM either. ATI case, ATI bellhousing, TCI gear set, TCI valve body, clutches and band I bought from an Ohio vendor. Thanks, I will sleep Better tonight. Lol
Re: Dana 60
#2573285
11/03/18 12:13 AM
11/03/18 12:13 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Ohhhh and my shortened Dana has aftermarket gears, spool, axles, brakes, bearings, seals, yoke, and gears.
Re: Dana 60
#2574407
11/05/18 02:37 PM
11/05/18 02:37 PM
cdwmotorsports
Martinsville, IN
To whom it may concern,
I don't care what you put in your car. I hope you can just answer questions I have and move on. Also unless you're going to fund my build I don't care that you would use a 9" Ford over a Dana, or a Glide over a 727. Have a great day.
eBay-cdwmotorsports
