Originally Posted By screamindriver
Originally Posted By topside
I've had the Eastwood stuff - the stainless coating - on manifolds for 20 years. Sprayed over a dead-clean surface, even used a foam brush one time. Also used it on a couple sets of headers. It's always held up very well for me.
The Slip-Plate deal is interesting - thanks for sharing, never heard of it - maybe the hot tip for master cylinders, too.
Eastwood pulled the rug out from underneath everyone that used the stainless coating..No warning just stopped offering it so if you need a touch-up you're committed to using a different color which means repainting the entire part..I'd like to try the slip-plate myself on an upcoming project thanks for the tip...
This is the stuff I used in the early '90s after a good sandblasting. It's still on and looking fantastic! It's sad to hear a cost effective and quality product like that pulled off the market.
