Page 16 of 20 1 2 14 15 16 17 18 19 20
Re: Demon build [Re: Quickrunner] #2536852
08/15/18 06:40 PM
08/15/18 06:40 PM
Are you going to use the air conditioner condenser to cool down the intercooler air to air unit ?
Re: Demon build [Re: Cab_Burge] #2537328
08/16/18 07:06 PM
08/16/18 07:06 PM
Indianapolis In. usa
Quickrunner Offline OP
Whipple uses an air to water intercooler under the blower in the manifold, has a -12 inlet & outlet at the back. Look a few pics up to see the Killerchiller unit mounted behind the headlight. Liquid coolant tank, to pump, to Killerchiller, to intercooler, back to tank & repeat. The killer chiller runs in tandem with the small Vintage air unit in the car. It is the real reason i am having AC on the car. its same technology that they use in the new Demon. There is a electronic ball valve that cuts the AC coolant flow to the evaporator under the dash for race mode. But for cruising & drag week the AC will be nice.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Demon build [Re: Quickrunner] #2539688
08/21/18 05:44 PM
08/21/18 05:44 PM
Got a little work done on the dash last night. Made a plate to fit the vintageAir control in the stock bezel. Goin to tackle fitting the dash pad cap around the cage bars tonight.
Re: Demon build [Re: Quickrunner] #2539943
08/22/18 10:26 AM
08/22/18 10:26 AM
Got the dash cap trimed up and fitted around cage bars. That was fun...NOT.
Re: Demon build [Re: Quickrunner] #2540021
08/22/18 02:28 PM
08/22/18 02:28 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Where did you get the dash insert for the gauge panel?
Re: Demon build [Re: Quickrunner] #2540039
08/22/18 02:54 PM
08/22/18 02:54 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Nice work on fitting the dash to the A pillar. One of the hardest jobs to do is fitting stuff to a angled round tube.
69 GTX 68 Road Runner
Re: Demon build [Re: STEFF] #2540062
08/22/18 03:28 PM
08/22/18 03:28 PM
Found it on the web, I think it was Redline gauge works.
Re: Demon build [Re: JERICOGTX] #2540064
08/22/18 03:31 PM
08/22/18 03:31 PM
I zip tied a piece of tube to my angle gauge and eyeball traced the hole with a sharpie! Started a bit small and snuck up on it a little at a time with the dremel. In and out of the car roughly 27 times LOL
Re: Demon build [Re: Quickrunner] #2540067
08/22/18 03:47 PM
08/22/18 03:47 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Yup! To do it right it takes a lot of time, creativity, and patience.
Re: Demon build [Re: Quickrunner] #2542026
08/27/18 02:48 PM
08/27/18 02:48 PM
made some brackets and got the VintageAir unit mounted. Then made some adapters to utilize the 2 fresh air holes under the cowel for some functional vents.
Re: Demon build [Re: Quickrunner] #2542028
08/27/18 02:53 PM
08/27/18 02:53 PM
Got the hidden smaller jeep wiper motor mount fabed up for under the dash. hooked up 12v and tested the action. Works like factory!
Re: Demon build [Re: Quickrunner] #2546086
09/05/18 11:40 AM
09/05/18 11:40 AM
Picked up this nice billet master cyl relocation block from Mike Roth after seeing it on a few of the SS/AH cars at the nats. This is a nice piece and will get me the clearance to run the bigger 4.5 Whipple blower with the rear inlet elbow.
Re: Demon build [Re: Quickrunner] #2546091
09/05/18 11:43 AM
09/05/18 11:43 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Nice work, love the details
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Demon build [Re: Quickrunner] #2548268
09/10/18 09:33 AM
09/10/18 09:33 AM
Got the master cyl relocated and the brake peddal re hung SS/AH style! Added a zerk and orings on the shaft since it does not ride on plastic bushings anymore. Added adjustable push rod to it yesterday and fabed a brake switch.
Re: Demon build [Re: Quickrunner] #2548595
09/11/18 12:10 AM
09/11/18 12:10 AM
Got the trans cooler mounted under the trunk floor. Also the switches showed up from Australia I ordered.
Re: Demon build [Re: Quickrunner] #2558913
10/04/18 02:39 PM
10/04/18 02:39 PM
Starting to mock in the plumbing, hiding the heater hose, AC lines, & intercooler hoses under the fenders.
Re: Demon build [Re: Quickrunner] #2565919
10/18/18 01:55 PM
10/18/18 01:55 PM
Little more progress under the fender. Getting the AC lines plumbed in for the Killer chiller unit. Will make a quick release panel to hide and protect all this when its done. As a bonus to super cooling the inter-cooler it looks like I may be able to get 90 proof out of it!
Re: Demon build [Re: Quickrunner] #2568802
10/24/18 12:25 PM
10/24/18 12:25 PM
Put the wheels on and sat her down to get a look
Re: Demon build [Re: Quickrunner] #2568803
10/24/18 12:26 PM
10/24/18 12:26 PM
Few more
Re: Demon build [Re: Quickrunner] #2568806
10/24/18 12:28 PM
10/24/18 12:28 PM
last one
