1970 Charger Full Build
#2568430
10/23/18 04:45 PM
10/23/18 04:45 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Critique my build Engine: 440 source 500" stroker kit (.030 or .040 over depending on whats needed with the current condition) Trick Flow 240 heads (possibly cc heads from 78 to 84, to lower compression to around 10.5) Holley SD intake Holley 850? street avenger Cam with 240-245@.050 (the average of suggestions between 230-250) Hedman ceramic coated headers 1 3/4" (if I can find a pair of 1 7/8" that fits with the fast ratio pitman arms ill get it) 3" exhaust with flowmaster super 44's Most likely Harland Sharp rocker arms Transmission: SST perfect fit kit magnum 6 speed, close ratio, billet flywheel, 1350 yoke Driveshaft: Denny's HD 3 or 3.5 in depending on his suggestion Rear end: Moser Dana 60 with mark williams billet main caps, 35 spline truetrac, 1350 yoke, 3.73, tapered roller bearing, wilwood 12.19 parking brake kit, aluminum cover (would 1/2"x20x2" screw in studs work with factory style wheels?) Suspension: Rear: XHD springs with caltracs Bilstein shocks New shackles and bushings Front: PST Adjustable strut rods Bilstein shocks LCA rebuild and stiffen Polygraphite PST super front end kit MP .96 torsion bars Wilwood 12.19 brakes Chassis: Stiffen all chassis welds and k member (especially the steering box mount) US Car Tool subframe connectors and torque boxes
Re: 1970 Charger Full Build
[Re: tboomer]
#2568441
10/23/18 05:01 PM
10/23/18 05:01 PM
Posts: 289 Lowes
steve660
Lowes
How many threads are you going to start on this build?? Please stick to a couple...This is getting out of hand.. You have 7 threads on the first 2 pages here.. FINALLY.......THANK YOU
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: krautrock]
#2568497
10/23/18 06:24 PM
10/23/18 06:24 PM
fast68plymouth
So. Burlington, Vt.
the build looks great. build it up and let us know how it works!! Yeh.... that.
[Re: 70charger512]
#2568549
10/23/18 08:18 PM
10/23/18 08:18 PM
Posts: 4,213 New York
polyspheric
New York
Trick Flow 240 heads (possibly cc heads from 78 to 84, to lower compression to around 10.5) Can you do this yourself? Very complex work, should be done with a flow bench
Pistons: dome shape, static CR, valve reliefs, quench clearance?
Cam with 240-245@.050 That reduces total choices to 50 LSA? Intake/exhaust bias? Installed ICL?
the average of suggestions between 230-250 Why?
Pushrods?
Most likely Harland Sharp rocker arms Intake ratio? Exhaust ratio?
Boffin Emeritus
[Re: 70charger512]
#2568552
10/23/18 08:42 PM
10/23/18 08:42 PM
Posts: 3,289 West Coast, USA
jbc426
West Coast, USA
I saw some of the bench racing talk about the engine in previous posts, and I am curious if you even own the car yet? Either way, worrying about how all these specific parts will work together is way overthinking it not to mention expensive, very expensive for a daily driver.
Having a plan is a good thing, but having a running driving car that you can thoughtfully upgrade over time is an even better plan. I would say it helps you avoid expensive mistakes, but I have far too many spare parts that I've accumulated over the years to say that. Hope you are on the right track to accomplish your dreams.
Are you going to build this all at once or upgrade it over time?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 70charger512]
#2568572
10/23/18 09:23 PM
10/23/18 09:23 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
My critique:
Don't mess with the cc of the heads. Get the right pistons that give you the desired compression ratio with the stock 78cc head. Hopefully you've been in touch with an engine builder to handle the machine work and assembly.
Stay right around 240@050 on the cam and I recommend hydraulic roller, and yes Harland sharp rockers are very good.
TTI 1 7/8 headers and exhaust instead of hedman. TTI headers and exhaust fit great and are very good quality. They also sell stock replica exhaust tips in 3" stainless.
This seems like a build that would run fuel injection, but carb works good too. Personally, I'd call quick fuel for a carb, but 850 street avenger should be fine.
Everything else seems good. I know nothing about that trans, but hope it can handle all that torque.
2 kids and a dog
[Re: TonyS451]
#2568588
10/23/18 09:50 PM
10/23/18 09:50 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
My critique:
Thank you, TTI headers have alot more clearance than most correct? And the carb would just be overall better for the street, while being still more than good enough for the strip (i just dont know if the size is good). And that transmission is rated for 700 lb-ft of torque, plus theres a cryogenic treatment option that adds 200 lb-ft (if im correct its somewhere around there)
[Re: jbc426]
#2568590
10/23/18 09:51 PM
10/23/18 09:51 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Yes i do own the car. With a stock 440. And i will be doing suspension, steering, and braks, while HP engines will build the engine, and im going to have the rest of the driveline professionally installed (most likely by Mark Dudley)
[Re: polyspheric]
#2568600
10/23/18 09:58 PM
10/23/18 09:58 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Pushrods?
Most likely Harland Sharp rocker arms Intake ratio? Exhaust ratio? Oh no id have the engine shop cc the heads if i had to do that. Theyre flat tops with valve reliefs, from the 440 source stroker kit. The kit says around 11.5 (depending on overbore with 78 cc heads) which makes me worried about a really hot day causing problems on 93 octane (maybe not to 84 but just enough to be at or under 11). The pistons are also .018 in the hole. Im trying to get quench anywhere between .035-.039, im thinking around .038 to be specific. Im thinking lsa around 110 installed 4 degrees advanced to be more street friendly, but looks like those options are limited. I have found plenty of 109 and 108 lsa cams with that duration. And the suggestionsive gotten ranged from 230-250, so im thinkin if i go in the middle ill be good, of course ill talk to the Mr. Page while the motor is there. Also thinking more exhaust on the cam (that is more street friendly, correct?) Pushrods should be stock ball/cup style but i dont know where i should get them from. 1.5 rocker arms. Harland sharp isnt a guarantee, i just know theyre good.
[Re: 70charger512]
#2568603
10/23/18 10:03 PM
10/23/18 10:03 PM
TonyS451
Chicago, IL
My critique:
Thank you, TTI headers have alot more clearance than most correct? And the carb would just be overall better for the street, while being still more than good enough for the strip (i just dont know if the size is good). And that transmission is rated for 700 lb-ft of torque, plus theres a cryogenic treatment option that adds 200 lb-ft (if im correct its somewhere around there) TTI headers fit great and have the best clearance of any shelf header. The carb is easier to bolt on and less expensive, but FI should be better on the street. The carb may or may not be better at the track. If you stay with a carb, I think a 950 is where you need to be.
2 kids and a dog
[Re: TonyS451]
#2568646
10/23/18 11:15 PM
10/23/18 11:15 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
My critique:
Thank you, TTI headers have alot more clearance than most correct? And the carb would just be overall better for the street, while being still more than good enough for the strip (i just dont know if the size is good). And that transmission is rated for 700 lb-ft of torque, plus theres a cryogenic treatment option that adds 200 lb-ft (if im correct its somewhere around there) TTI headers fit great and have the best clearance of any shelf header. The carb is easier to bolt on and less expensive, but FI should be better on the street. The carb may or may not be better at the track. If you stay with a carb, I think a 950 is where you need to be. Oh yes, of course FI would be better overall, i just dont know if i want to go that route, sorry i thought you were referring to the vacuum secondary vs doube pumper part, my bad. And 950? ok thank you i guess ill just ask my engine builder when its all built without the carb just in case too.
[Re: 70charger512]
#2568648
10/23/18 11:26 PM
10/23/18 11:26 PM
Posts: 4,457 Washington
madscientist
Washington
What are you using for a clutch? You can cryo all the parts you want, but if the clutch is a parts killer it will kill the gear box no matter what it's rated at.
As for the compression ratio and the cam, you need to get in the phone with a cam company where you can actually talk to someone who isn't a minimum wage catalog parts finder. You need to talk to someone who actually understands cams.
Then you order the cam. If the cam is correct, I wouldn't worry about 11:1 on pump gas. I run 11:1 on pump gas, but I didn't buy a cam of the shelf, or by web suggestions.
[Re: madscientist]
#2568661
10/23/18 11:53 PM
10/23/18 11:53 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Then you order the cam. If the cam is correct, I wouldn't worry about 11:1 on pump gas. I run 11:1 on pump gas, but I didn't buy a cam of the shelf, or by web suggestions. Oh of course i will talk to a cam company, i just need some ideas so i dont have to have them teach me everything over the phone hahah. 11:1 seems fine to me, but how would 11.5:1 be on 93 with a cam in the spec range that has been discussed. And as for the clutch it is SST’s clutch (and flywheel), heres everything they sent me in the quick quote, notice the last part about the metallic series.
[Re: 70charger512]
#2568713
10/24/18 02:45 AM
10/24/18 02:45 AM
Posts: 31,100 Oregon
AndyF
So a lower LSA is actually better for the street?
No. Street cars have wide LSA, race cars have narrow LSA. First thing you need to do is figure out if you're building a street car or a race car. If you're building a street car you shouldn't be asking so many questions in the race forum. When you ask questions in the race forum you get answers from racers. Could be part of your confusion.......
[Re: 70charger512]
#2568759
10/24/18 10:49 AM
10/24/18 10:49 AM
madscientist
Washington
On any BB Mopar big C.I. stroker motor you want a big carb, it is impossible to be to big ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I would use a 108 LSA cam on your deal installed at or close to ,+ or - one degree at 104 on the intake lobes, that will give you more bottom end power with a small decrease in top end, upper RPM(above 6000 RPM) power That will make the stick shift motor a lot more fun and easy to drive on the street also Nothing wrong on planning ahead So a lower LSA is actually better for the street? And this is exactly why you need to get on the phone and talk with someone who actually knows what they are doing and not some guy who is paid to answer phones and sell you a cam off the shelf. Not to pick out any one company, but let's say my no name ass calls Comp. I'm a nobody. I'm going to get to talk to a dude whose job requires him to punch in some numbers in his computer and spit out a cam off the shelf. And maybe, if you are lucky, they'll move the LSA to make you think you are getting something worthy of what you should have. If I call Cam Motion, I talk to the same guy every single time. When I was buying 10 cams a month, I developed a relationship with that guy, and he understood what I expected. Cam Motion never failed to deliver. If you call Jones cams, you will talk to Mike Jones himself. We have different opinions on how things should be, so I didn't use many of his cams, but his stuff works and you get to talk to him, not some phone dude. If I call Racer Brown, I get to talk to Jim. Jim answers the phone. Jim grinds every cam. On my last build, I had done some things most guys wouldn't do to a street engine. I also wanted to run 11:1 compression on pump gas (and did) and with my valve job and port work, I decided after spending way too much time on the flow bench, I needed to net .600 lift, even though the heads broke over at .500 lift and didn't gain it all back, but I got some back around .650 lift. Jim was the ONLY one of the 5 cam grinders I called who even considered discussing why I wanted that much lift. Everyone else said I was wasting my time opening the valve that much. In the end, I ended up with .620 gross lift and I net a bit over .600 and not because Jim caved and gave me what I wanted. I sent him copies of the flow sheets with my copious and boring notes. I also sent him a drawing of the cutter I used to the valve job so he could see what I was talking about. In the end, the Racer Brown grind was about .060 or more lift than any other grinder said I should use, was a tight lash lobe and the LSA was nowhere near what anyone else thought it should be. The engine will idle at 750, but I don't let it idle that slow. It doesn't idle any rougher that a 270 degree hydraulic but will pull to 7,000 all day long. So sometimes it don't about the name on the box. It's about who you get along with that ends up getting you something worth the effort. You just can't guess at an arbitrary LSA and say it's the magic number. It isn't. It's the sum of the events. It does make a difference for sure. That's why I say put away your preconceived ideas of what you think you need. In fact, if I was building your engine, I'd be ordering the cam and not you, the customer. But that's how I did it.
[Re: AndyF]
#2568764
10/24/18 11:04 AM
10/24/18 11:04 AM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
No. Street cars have wide LSA, race cars have narrow LSA. First thing you need to do is figure out if you're building a street car or a race car. If you're building a street car you shouldn't be asking so many questions in the race forum. When you ask questions in the race forum you get answers from racers. Could be part of your confusion....... That's exactly what I thought, but Mr Cab said the lower LSA would be better for the street. I was thinking "man I know around where I should get for my LSA" then he answered that way and made me rethink. Before, his response I was 100% sure I should get a 110-112 LSA cam anyway. Im only asking in here because it's engine tech specifically too.
[Re: 70charger512]
#2568769
10/24/18 11:13 AM
10/24/18 11:13 AM
madscientist
Washington
No. Street cars have wide LSA, race cars have narrow LSA. First thing you need to do is figure out if you're building a street car or a race car. If you're building a street car you shouldn't be asking so many questions in the race forum. When you ask questions in the race forum you get answers from racers. Could be part of your confusion....... That's exactly what I thought, but Mr Cab said the lower LSA would be better for the street. I was thinking "man I know around where I should get for my LSA" then he answered that way and made me rethink. Before, his response I was 100% sure I should get a 110-112 LSA cam anyway. Im only asking in here because it's engine tech specifically too. If the above generalization is correct, why is my 98% street cam on a 105 LSA, installed on a 105 ICL? It's difficult to make generalizations like that. I know that catalog cams all have a default LSA. Look at an Isky catalog. All that stuff is on a 108. Look at Comp. 99% of their stuff is on a 110. That's why I hate catalog cams. There is never a reason to buy a cam off the shelf. LSA is a sum of the cam timing events and nothing more. If you go to speedtalk.com and search for LSA and find dozens of threads where this has been hashed out and beat to death by some of the best minds on the web. Mike Jones is in some of them. David Vizard posts about LSA and those two don't always agree. The head dyno guy for one of the NASCAR teams posts in those threads and plenty of other guys who have forgotten more than I'll never know. If you establish in your mind what ought to be, without enough background, knowledge and experience, you're going to have issues doing what you want. I personally don't see a reason to build a pump gas engine at less that 10.5:1 for about anything. I may squeeze my junk to 11.5:1 later on. But you have to understand how everything else affects every other decision you make. Hell, I can't see any reason to use a 45* valve job on any performance build any more. I use a 50* seat. I can't think of a reason not to. But that's just me.
[Re: 70charger512]
#2568772
10/24/18 11:19 AM
10/24/18 11:19 AM
madscientist
Washington
There are two hydraulic rollers from Howards Cams that I found that look to be in the right range, anyone have any experience with either of these: 1. 235/241 @.050, 110 LSA, 106 centerline, .545/.545 lift 2. 243/251 @.050, 109 LSA, 103 centerline, .530/.515 What exactly does the bigger difference in LSA and centerline mean, this would be installed 6 degrees advanced correct? And what is affected when theres more intake lift than exhaust? You are asking great questions. But you are asking the wrong people. Call Howard's and ask them. Take notes. Then call 6,7 or even 10 other cam grinders and give them the exact same numbers and see what they say. Take notes. Then sit down and compare the answers. Also, you should ask them why the split pattern cam? Are they adding exhaust duration, or reducing intake duration. Because it makes a difference. I say they are reducing intake duration. Then they move the timing around on the exhaust side to get the LSA wider. This kills the all important mid range power, so the shift RPM will stay the same as if you put the intake duration back in and closed the LSA up. With production style heads, I'm a big advocate of single pattern cams. The split pattern cams look cool on paper, but almost always they are down on power in the mid range. That's the worst place to give up power I can think of. Get on the phone. Write down all the questions you can think of. Ask the cam grinders. Again, take notes. You'll be surprised what you find.
[Re: 70charger512]
#2568799
10/24/18 12:17 PM
10/24/18 12:17 PM
polyspheric
New York
The actual overlap window, which has a large effect on idle quality and low speed response, is VERY different between 240° @ .050" & 112° LSA and 250° @ .050" & 108° LSA. Averaging cam event timing is banging your head against the wall. Ask a good porting service what your heads like w/r/t in/ex bias.
Boffin Emeritus
[Re: TonyS451]
#2568807
10/24/18 12:28 PM
10/24/18 12:28 PM
Posts: 2,094 central texas
krautrock
central texas
My critique:
Don't mess with the cc of the heads. Get the right pistons that give you the desired compression ratio with the stock 78cc head. Hopefully you've been in touch with an engine builder to handle the machine work and assembly. i posted a question in the other thread, i can't keep up with all the threads and i think it might've acutally been deleted. Nick, why not build a 440/512 with a -17cc dish piston...you would get 10.5:1 compression (roughly) with a 78cc combustion chamber...
[Re: krautrock]
#2568864
10/24/18 01:37 PM
10/24/18 01:37 PM
Posts: 1,030 ohio
67mprfan
ohio
My critique:
Don't mess with the cc of the heads. Get the right pistons that give you the desired compression ratio with the stock 78cc head. Hopefully you've been in touch with an engine builder to handle the machine work and assembly. i posted a question in the other thread, i can't keep up with all the threads and i think it might've acutally been deleted. Nick, why not build a 440/512 with a -17cc dish piston...you would get 10.5:1 compression (roughly) with a 78cc combustion chamber... Watch out now he'll start another thread about building a 512 over the motor he wants now
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 70charger512]
#2568867
10/24/18 01:40 PM
10/24/18 01:40 PM
AndyF
No. Street cars have wide LSA, race cars have narrow LSA. First thing you need to do is figure out if you're building a street car or a race car. If you're building a street car you shouldn't be asking so many questions in the race forum. When you ask questions in the race forum you get answers from racers. Could be part of your confusion....... That's exactly what I thought, but Mr Cab said the lower LSA would be better for the street. I was thinking "man I know around where I should get for my LSA" then he answered that way and made me rethink. Before, his response I was 100% sure I should get a 110-112 LSA cam anyway. Im only asking in here because it's engine tech specifically too. You were on the right track before you got derailed. For your type of build I'd go with a cam that is 230's in duration at 050 and 112 LSA. The old Mopar 0.528 solid cam is a good street cam for a stroker big block. It is 236 duration and 112 LSA. Works great on the street and pulls hard to 6000 rpm. What you are trying to accomplish isn't difficult. The shop I work with has five BB Mopar stroker engines on the floor right now in various stages of assembly. Any one of those engines would work just fine in your car. They are all pump gas strokers with aluminum heads and street cams. They will all make at least 500 hp and one or two might be closer to 550. Building engines like this is routine for some of us.
[Re: 70charger512]
#2568869
10/24/18 01:45 PM
10/24/18 01:45 PM
Thumperdart
State of confusion
No. Street cars have wide LSA, race cars have narrow LSA. First thing you need to do is figure out if you're building a street car or a race car. If you're building a street car you shouldn't be asking so many questions in the race forum. When you ask questions in the race forum you get answers from racers. Could be part of your confusion....... That's exactly what I thought, but Mr Cab said the lower LSA would be better for the street. I was thinking "man I know around where I should get for my LSA" then he answered that way and made me rethink. Before, his response I was 100% sure I should get a 110-112 LSA cam anyway. Im only asking in here because it's engine tech specifically too. 108 lsa here installed at about 105 street/strip car, 470 stroker 6.15 at 112+ mph in the 1/8 9.6 in the 1/4 now it's more than you are looking for but PLENTY street-able just check out my video on here titled :How do I post a you tube video on here"...........Another approach I make when picking a cam as I have Isky grind mine, is weight.....heavy car and less powerful motor, less duration, lighter car good power, more duration........This is one of many other factors involved............... ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: AndyF]
#2568904
10/24/18 02:44 PM
10/24/18 02:44 PM
Thumperdart
State of confusion
No. Street cars have wide LSA, race cars have narrow LSA. First thing you need to do is figure out if you're building a street car or a race car. If you're building a street car you shouldn't be asking so many questions in the race forum. When you ask questions in the race forum you get answers from racers. Could be part of your confusion....... That's exactly what I thought, but Mr Cab said the lower LSA would be better for the street. I was thinking "man I know around where I should get for my LSA" then he answered that way and made me rethink. Before, his response I was 100% sure I should get a 110-112 LSA cam anyway. Im only asking in here because it's engine tech specifically too. You were on the right track before you got derailed. For your type of build I'd go with a cam that is 230's in duration at 050 and 112 LSA. The old Mopar 0.528 solid cam is a good street cam for a stroker big block. It is 236 duration and 112 LSA. Works great on the street and pulls hard to 6000 rpm. What you are trying to accomplish isn't difficult. The shop I work with has five BB Mopar stroker engines on the floor right now in various stages of assembly. Any one of those engines would work just fine in your car. They are all pump gas strokers with aluminum heads and street cams. They will all make at least 500 hp and one or two might be closer to 550. Building engines like this is routine for some of us. 230 @ .050 at those cubes? Not how I would go as the cubes will make it purr like a kitten not roar like a TIGER......I know you build this n that Andy and if mellow is the goal then he should be REAL happy.......... ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: krautrock]
#2568918
10/24/18 03:04 PM
10/24/18 03:04 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
My critique:
Don't mess with the cc of the heads. Get the right pistons that give you the desired compression ratio with the stock 78cc head. Hopefully you've been in touch with an engine builder to handle the machine work and assembly. i posted a question in the other thread, i can't keep up with all the threads and i think it might've acutally been deleted. Nick, why not build a 440/512 with a -17cc dish piston...you would get 10.5:1 compression (roughly) with a 78cc combustion chamber... Not a bad idea at all, if i can keep the .030 over id gladly do that, but i dont know what condition it is in. We will just have to see when its apart.
