Re: Nodular 8.75 case , how much stronger
[Re: B3422W5]
#2567507
10/21/18 10:43 PM
10/21/18 10:43 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Than a production 489 housing Anybody using a nodular 8.75 rear with a brake? I have done this, as my Dart got quicker the parts attrition got worse. 60' 1.39/1.40 normally now, 3375lbs Nod 489 case, 35 spline, magic pink goo shock proof oil, back braced. I run a 4.30 gear which is probably the worst but it is what the car wants. I race often it got down to 2 ring and pinions a year, Richmond, Motive, Yukon had them all. I did a 9" and am very happy with it. You will be money ahead in the long run to just upgrade to a tow truck rear or a 9" I had to type this out 3 times to remove the cutting sarcasm, cuss words, and bad attitude I have on this subject
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2567517
10/21/18 10:56 PM
10/21/18 10:56 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
Than a production 489 housing Anybody using a nodular 8.75 rear with a brake? I have done this, as my Dart got quicker the parts attrition got worse. 60' 1.39/1.40 normally now, 3375lbs Nod 489 case, 35 spline, magic pink goo shock proof oil, back braced. I run a 4.30 gear which is probably the worst but it is what the car wants. I race often it got down to 2 ring and pinions a year, Richmond, Motive, Yukon had them all. I did a 9" and am very happy with it. You will be money ahead in the long run to just upgrade to a tow truck rear or a 9" Thanks. That settles it
[Re: merpar]
#2567537
10/21/18 11:25 PM
10/21/18 11:25 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
The weak point in the 8 3/4 is the bearing caps. "You can brace it like a tank and it will NOT fix the inherent weakness of the 8.75. Torque pushes the ring gear away from the pinion when the case flexes. You CAN'T fix that. They break caps because all the debris from the shelled teeth gets in there and it pushes the cap off. So you will spend a lot of time and money trying to fix a problem you can't fix and it will eventually break anyway." Monte Smith
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: Just-a-dart]
#2567538
10/21/18 11:26 PM
10/21/18 11:26 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Than a production 489 housing Anybody using a nodular 8.75 rear with a brake? I have done this, as my Dart got quicker the parts attrition got worse. 60' 1.39/1.40 normally now, 3375lbs Nod 489 case, 35 spline, magic pink goo shock proof oil, back braced. I run a 4.30 gear which is probably the worst but it is what the car wants. I race often it got down to 2 ring and pinions a year, Richmond, Motive, Yukon had them all. I did a 9" and am very happy with it. You will be money ahead in the long run to just upgrade to a tow truck rear or a 9" I had to type this out 3 times to remove the cutting sarcasm, cuss words, and bad attitude I have on this subject . I'm going to have to say it was being built wrong for you to have broken that much stuff in a 10 second car.. guys like Thumper have been using the same one for 17 years.. that being said there is no substitute for 9inchs ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2567548
10/21/18 11:34 PM
10/21/18 11:34 PM
Just-a-dart
Glendora Ca.
[/quote]. I'm going to have to say it was being built wrong for you to have broken that much stuff in a 10 second car.. guys like Thumper have been using the same one for 17 years.. that being said there is no substitute for 9inchs ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) [/quote Ha ha You sir are still a A..hole (and a friend)
[Re: Thumperdart]
#2567582
10/22/18 12:22 AM
10/22/18 12:22 AM
Posts: 1,237 North Central, Indiana
Roughbird72
Ok I will say it, Do not waste more money on an 8 3/4, PERIOD Been driving racing my 9-second Dart forever and JUST replaced the "stock" pumpkin 2+ years ago that had stock caps bolts etc. Too many wives tales but then again, some people are puttin them in the wrong application so you need to know where the cut off point is........... The cut off point in mine was reached last weekend. Shelled teeth off the ring gear even with all the band-aids, but that's with a car that weighs 3800+ I'll be purchasing a Dana 60 next month.
72 Plymouth Roadrunner 11.08@123.25
[Re: Thumperdart]
#2567737
10/22/18 11:20 AM
10/22/18 11:20 AM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
Been running the Dr Diff unit for 2+ years and it is awesome imo and a bit heavier but beefier with forged caps and stout adjusters.........of course my stock unit lasted 16+ years........... Come on Dom, we all know you go to the track for a couple passes like once every 2 years. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Beating on it on the street will never duplicate the traction/stress it will see at the track. Lots of weak parts can live a long life w/ no traction.
[Re: an8sec70cuda]
#2567740
10/22/18 11:21 AM
10/22/18 11:21 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Been running the Dr Diff unit for 2+ years and it is awesome imo and a bit heavier but beefier with forged caps and stout adjusters.........of course my stock unit lasted 16+ years........... Come on Dom, we all know you go to the track for a couple passes like once every 2 years. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Beating on it on the street will never duplicate the traction/stress it will see at the track. Lots of weak parts can live a long life w/ no traction. Thank you!
[Re: an8sec70cuda]
#2567745
10/22/18 11:36 AM
10/22/18 11:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran a 8 3/4 and still do in the race car.. the car is light but it blew the ring and I changed to the alum center.. its had a back brace all along.. when I built the hot rod I put a 9" in it with a back brace and DRs.. had slicks in the race car and a brake with 1.19 60'.. both are still running strong
[Re: J_BODY]
#2567800
10/22/18 01:20 PM
10/22/18 01:20 PM
Thumperdart
State of confusion
Been running the Dr Diff unit for 2+ years and it is awesome imo and a bit heavier but beefier with forged caps and stout adjusters.........of course my stock unit lasted 16+ years........... Come on Dom, we all know you go to the track for a couple passes like once every 2 years. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Beating on it on the street will never duplicate the traction/stress it will see at the track. Lots of weak parts can live a long life w/ no traction. Thank you! Your welcome and I will post a pic of my fat ass time slip book then you can tell me how I've only raced a couple times a year..........Don't be hatin on my quick ass n/a street car......... ![drumhit drumhit](/ubbthreads/images/graemlins/custom/drumhit.gif)
[Re: B3422W5]
#2567813
10/22/18 01:48 PM
10/22/18 01:48 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I still run the 742 8-3/4” that came with my car from the factory. After breaking a couple of sure-grip differentials, I now run a spool, along with a steel cap on the driver side, 35-spline axles, and my housing has a brace stitched onto it. My car doesn’t make power like most on this board, but I do throw more weight at mine than most, as my car crosses the scales at a solid 3870 these days. It 60’s in 1.53,the footbraking.
I know a guy here locally that runs a low10-second 67 GTX on a trans brake. He still runs an 8-3/4”. My belief is that 8-3/4’s have their place. A 9-second B-body may not be that place.
For all those that call the modifications “band-aids”; the 9” units that most run are not stock Ford units, they’re full of aftermarket stuff also. For that matter, most Dana’s in this conversations are likely S60’s outfitted with Spools, aluminum covers, and aftermarket axles.
[Re: StealthWedge67]
#2567821
10/22/18 02:09 PM
10/22/18 02:09 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
For all those that call the modifications “band-aids”; the 9” units that most run are not stock Ford units, they’re full of aftermarket stuff also.: For that matter, most Dana’s in this conversations are likely S60’s outfitted with Spools, aluminum covers, and aftermarket axles. I agree: No stock Ford parts at all ![work work](/ubbthreads/images/graemlins/custom/work.gif) I was told by Joe Reath back in the early 1970 that their funny car, Dunn and Reath, where the test mule for the Chrisman family helping develop the Ford nine inch for drag racing. He said they where into it back then for around $2300.00 and still would put the Dana 60 back in the car to go to certain high altitude low traction tracks like in Salt Lake so they didn't have to change third members at the races due to carnage at those tracks As far as Dana 60 used for drag racing in some cars I normally will use a junk yard damaged Dana 60 core due to the lower price and I'm going to have them cut down and narrowed to fit and use after market spools and axles ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) The truck rear ends set up properly will push by hand in the car so much easier than any 9 inch Ford equip car I have help push at the races or any where else, same thing on drag cars with 8 3/4 rear ends in them when it comes to pushing them by hand ![work work](/ubbthreads/images/graemlins/custom/work.gif)
