Re: Choosing a converter company?
[Re: justinp61]
#2567957
10/22/18 07:40 PM
10/22/18 07:40 PM
Posts: 20 KS
417_Stroker
KS
I’ve ran an 8” 5500 stall behind my 417 inch motor and it was built by Dynamic converters. Always seemed to perform flawlessly but I now have a 9.5” 4500 stall GM converter from FTI due to a trans swap. But more than likely the company who is asking the most questions is going to probably build a converter more closely suited to your exact combination. COAN will build you a good converter for sure but you’ll pay for it. I’ve read a lot of good stuff about PTC too and they won’t cost as much as a Coan I don’t believe. And of course I’ve had good luck with Dynamic.
'69 Dart 417 pump gas with 200-4R 10.49@128
[Re: justinp61]
#2567959
10/22/18 07:41 PM
10/22/18 07:41 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
IMO I have dealt with MOST the companies listed and talked about. The last two years I have been dealing with FTI and could not be happier. They have nailed all 5 converters I have purchased from them in the past two years. Those are from 600hp pieces to 1250hp ones You will not be disappointed if you call the guys at FTI.
https://ftiperformance.com/main.sc;jsessionid=EB762E07DA054AA582AE5D9CCB60B062.p3plqscsfapp004
[Re: justinp61]
#2567978
10/22/18 08:05 PM
10/22/18 08:05 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I would say do not buy a Edge, Andre is full of crap. 9.5 billet cover weighs a bunch and was not efficient for me.
Changed to a Continental 8" picked up .15 ET with 300rpm more flash and less stripe rpm. The problem is Kris is no longer in business
Edit If you got a good Edge, you are a lottery winner.
"Just a Bracket car dressed up like a streetcar"
[Re: justinp61]
#2567979
10/22/18 08:06 PM
10/22/18 08:06 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
Thanks Al, I'll give them a look.
I'm trying to get my 60' back, with my 408 and a $450 9 1/2 Edge converter I ran a bunch of 1.38 60. I killed the Edge and had Ultimate build me a new 8" and my 60' went into the low 1.50's. Before I could send it back I decided to freshen the 408 nad found some issues so I built the 434. After some testing the converter was sent back and gone through, it ran high 1.40's after that. I then sent it to Kenny and he tightened it up a little and it has gone 1.40 one time, most of the time 1.43-44.
The 434 added close to 60 pounds to the front but I also have moved the battery to the trunk to help offset it some. IMO with the added 60-80 hp it should 60' better than the 408 did. Depending on cam/ compression, bigger head etc, it might not necessarly 60 foot better. Convertors as you know can be tricky getting right Last year i went 1.63 sixty and went 11.26 with too tight of a convertor. This year i went 1.51 and 11.32 with too loose a convertor after swapping to a 904 and expecting to knock on the door of 10’s. 1.51 is great for an 11.30’s to 40’s heavier car, but it was so bad in all the other incrementals it gave it all back and more. Never took the time to get it out and adjust it this season
[Re: justinp61]
#2567987
10/22/18 08:11 PM
10/22/18 08:11 PM
fast68plymouth
So. Burlington, Vt.
What I’ve found is, the “bigger head” combos are fussier about how they interact with the converter than a smaller head combo. Especially when there are some compromises made to the engine combo for street duty.
It’s sort of like..... big heads, without the big compression and big cam, have a smaller tuning window at the starting line. It’s just easier to make them work when it’s 14:1 and 280@.050...... you start with a 5800 8” unit and go from there.
[Re: justinp61]
#2567991
10/22/18 08:15 PM
10/22/18 08:15 PM
BradH
I wish I had more experience with converter companies. I had a Coan 11" that worked great, but they said if I exceeded 500 HP it wouldn't hold up... and they were right. Once that car was dipping well into the 11s, it was like the converter's fuse was lit. Tried a J.W. Performance 10" that was too loose for what it was sold for (10+% slippage), so I pulled it and put in a Frank Lupo Dynamic 9.5" which was very "popular" at that time (late '90s). But I don't hear people talk about Dynamic much these days... In my car, that Dynamic worked really well, even after changing the engine and picking up about 50 HP over the original application. Now I've picked up another 50+ HP and am hoping it is at least still in the ballpark to get a new baseline. In a friend's car that Dynamic spec'd a different 9.5" for, not so good... waaaaay too loose, so he yanked it and put in something much tighter. Very disappointing, especially because he knew how well mine worked for me. ATI is probably an hour's drive from me (no traffic), but I've never been sure they were the way to go, either. They told me years ago that I should run an 8", which I thought was a bit absurd for a low-11 second car (at that time). Dayum... I don't know that I helped the OP one bit, but I just reminded myself about how much I don't want to change converters again.
[Re: justinp61]
#2567992
10/22/18 08:16 PM
10/22/18 08:16 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I'm sure there are few good companies out there, but I have had great luck with PTC. Excellent customer service, and reasonable pricing as well. Never had a problem w any of their converters and Ive used in 4-5 diff cars. Always worked great.
2 kids and a dog
[Re: justinp61]
#2567993
10/22/18 08:16 PM
10/22/18 08:16 PM
BradH
Yes Brad.
Lenny built it for the 408 initally, when I built the 434 I talked to Lenny after it was on the dyno and he told me to run it as it should be close. It didn't work, the 60' was way off and it was slipping on the big end. It was sent back to Lenny and gone and configured for the 434. It still didn't work, that's when I sent it to Kenny Ford at PTC. Sorry, I hadn't read all your replies before I posted my question, and then I thought I'd deleted it soon enough that you wouldn't have had to answer it.
[Re: justinp61]
#2568001
10/22/18 08:36 PM
10/22/18 08:36 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Converters are like beer - you choose what you like and others may not agree . I have run a Dynamic for several years as I progressed through different power levels . 9 1/2" 5000 stall . Was great won a championship with it - footbraking . I now have a A1 Performance unit to go with my transbrake . It is a 8" , specced to my 505 with stock port heads and 4150 carb . Was around 5500 .Fitted TF270 heads and went 4500carb stall was just over 6000 . Blew that motor , refitted 440 with big top end stall is 5800 . This is on a pump gas street/strip motor . I always felt a little to high a stall wont hurt , to tight does .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Just-a-dart]
#2568011
10/22/18 08:58 PM
10/22/18 08:58 PM
Al_Alguire
Las Vegas
Edit If you got a good Edge, you are a lottery winner. All of Kris's stuff was purchased by Steve Casner at CRE if you still want to use the product. Just FYI
[Re: Al_Alguire]
#2568019
10/22/18 09:14 PM
10/22/18 09:14 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’ve had real good luck with Transmission Specialties behind my small block powerglide combos. It’s a spragless 8 inch turbo spline. I’ve never given them dyno numbers because I don’t dyno my stuff but when I told them I wanted 5800 stall on my last freshen it came back at 5760. I consider that pretty close. I will be sending another in over the winter to duplicate it so I have a spare sitting here.
[Re: dOc …]
#2568026
10/22/18 09:39 PM
10/22/18 09:39 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
No one mention Turbo Action ? GER?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Al_Alguire]
#2568035
10/22/18 09:58 PM
10/22/18 09:58 PM
Just-a-dart
Glendora Ca.
[/quote]
All of Kris's stuff was purchased by Steve Casner at CRE if you still want to use the product. Just FYI [/quote]
Thanks Al, as always I appreciate the info.
I did not know where the stuff went, the kid Peter was trying to put something together when they 1st closed. But that obviously did not happen.
[Re: justinp61]
#2568123
10/23/18 12:08 AM
10/23/18 12:08 AM
Posts: 4,291 Morrow, OH
markz528
Morrow, OH
Mine is going to Dynamic for the new build. Been dealing with Frank for 35+ years and can't stop now.............
[Re: justinp61]
#2568152
10/23/18 12:55 AM
10/23/18 12:55 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
I have one 8” converter 6200 stall that has some slip, but will print off 1.34 60 times and 6.13 1/8 times by the notebook full. I attribute the consistency to my 3rd place finish in the Hot Rod Heritage Series 2 years ago. My other 8” is tighter and 5800 stall. It can dip into the high 1.2’s on the 60 and has given me a best 1/8th increment of 5.94. Prob is that it can vary on launch and isn’t nearly as predictable. I bought this piece just to shut a guy up that thought he had me covered as he had intel from my slo piece. Good thing I have all these piled up next to my 727 as I’m switching over to a 904... ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) dumb...dumb...dumb...
[Re: J_BODY]
#2568174
10/23/18 02:02 AM
10/23/18 02:02 AM
Just-a-dart
Glendora Ca.
[/quote] Good thing I have all these piled up next to my 727 as I’m switching over to a 904... ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) dumb...dumb...dumb... [/quote] Hopefully I can help inspire you, just think of that glorious feeling you will have when you rip off that 1.35 60' and a 6.14 et with the new combo ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) Who is supplying the new converter?
[Re: justinp61]
#2568268
10/23/18 11:35 AM
10/23/18 11:35 AM
fast68plymouth
So. Burlington, Vt.
ATI is probably an hour's drive from me (no traffic), but I've never been sure they were the way to go, either. They told me years ago that I should run an 8", which I thought was a bit absurd for a low-11 second car (at that time). ATI is still very popular with the stock/superstock crowd.
[Re: justinp61]
#2568271
10/23/18 11:41 AM
10/23/18 11:41 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I was gonna say why not ATI? The local guy that builds my converters and transmissions has a very close relationship w/ ATI and uses a lot of their parts. Atlantic Coast Converters in Conway, SC, is who I use. Almost everyone around this part of SC and NC uses them.
[Re: dOc …]
#2568287
10/23/18 12:12 PM
10/23/18 12:12 PM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
No one mention Turbo Action ? While I have not got anything from them recently I have used Turbo Action for years. I had one converter that sat on the shelf long enough to be out of warranty when I used it. After a few races something let go internally and they still warrantied it. As I understand it Paul works part time now and he is who I would want to talk to. I think he comes in at 1:00 pm four days a week.
[Re: justinp61]
#2569592
10/26/18 12:33 AM
10/26/18 12:33 AM
Posts: 506 Utah, USA
1964superstock
Utah, USA
I would suggest calling A-1, and order a 8 inch converter. I have a 8 inch tight 4800 RPM stall converter in my 505 stoker, with 4:10 dana. Nothing but fun, works so nice, perfect drivability on the street, no slop. Stomp on the gas and holy crap, it flashes to 4800 in an instant and takes off. Very good product, no complaints, custom made per my dyno sheet, and car specs. May be a little more $$ than some, but is worth it in my opinion. Give them a call, you won't be disappointed. Very nice guys to talk with also. FYI...Dave Smith at Pro-Trans built my 727, and recommended that I order a 8 inch A-1 converter. I trusted his recommendation, glad I did. https://www.a-1perf.com/
[Re: 1964superstock]
#2569603
10/26/18 01:05 AM
10/26/18 01:05 AM
Posts: 43,309 Bend,OR USA
Cab_Burge
I would suggest calling A-1, and order a 8 inch converter. I have a 8 inch tight 4800 RPM stall converter in my 505 stoker, with 4:10 dana. Nothing but fun, works so nice, perfect drivability on the street, no slop. Stomp on the gas and holy crap, it flashes to 4800 in an instant and takes off. Very good product, no complaints, custom made per my dyno sheet, and car specs. May be a little more $$ than some, but is worth it in my opinion. Give them a call, you won't be disappointed. Very nice guys to talk with also. FYI...Dave Smith at Pro-Trans built my 727, and recommended that I order a 8 inch A-1 converter. I trusted his recommendation, glad I did. https://www.a-1perf.com/ I had A1 work on my nine inch Continental converter and Mikes Ultra Glide after it broke. It lasted 12 runs before it broke again I paid them to fix it again and it has lasted a little bit longer this time, so far ![work work](/ubbthreads/images/graemlins/custom/work.gif) If and when I have another glide converter built it will be a ATI ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I have used Dave at Pro Trans for years on my Mopar trans. cars ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) He is building me a all out 727 now for one of my customers street and show car with a 800 HP pump gas 572 EFI Hemi motor, hopefully he will be able to supply me with a good converter for that car also OP, buy the best converter you can get ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Not the cheapest
[Re: justinp61]
#2569651
10/26/18 09:28 AM
10/26/18 09:28 AM
crabman173
crabman173
Just a thought IF you footbrake The fastest converter may not be the best for hitting the tree--Tighter makes it easier to nail the tree vs loose ( which is usually faster 60 ft etc)
[Re: justinp61]
#2569663
10/26/18 10:30 AM
10/26/18 10:30 AM
Posts: 4,585 Motor City
6PKRTSE
Motor City
My favorite two are ATI & PTC. I used to run a PTC 8" 5000 nitrous convertor in one of my old Pro street 69 Charger for 5-6 year on the street until I sold the car. Totally street friendly until you mashed the throttle & then it would do what it needed to do. I currently have another PTC 9.5" 3800 convertor in my street driven cruiser 70' Charger with well over 30,000 street miles on it & is about 10 years old now without any issues.
I also have another PTC 9.5" 5400 Nitrous convertor in my 70' Hemi street/strip 70' Challenger. No complaints from PTC from me.
ATI is usually more expensive than PTC but so many of my buddies are always returning them back & forth between ATI & Ultimate Convertors to adjust the stall up or down several hundred RPMs to get them right.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Just-a-dart]
#2569670
10/26/18 10:52 AM
10/26/18 10:52 AM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
[/quote]
All of Kris's stuff was purchased by Steve Casner at CRE if you still want to use the product. Just FYI Thanks Al, as always I appreciate the info. I did not know where the stuff went, the kid Peter was trying to put something together when they 1st closed. But that obviously did not happen. [/quote] Glad I clicked on this thread. Kris built me a converter a couple of years ago and it turned out to be one of his last. Great guy, great product, great price. I appreciate the update.
1970 Duster 340 clone
[Re: Spaceman Spiff]
#2569737
10/26/18 01:26 PM
10/26/18 01:26 PM
Posts: 1,237 North Central, Indiana
Roughbird72
No one mention Turbo Action ? GER? ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) I learned the hard way on that way back when. Broke one GER(it sound like a box of glass), they replaced it and the replacement had 13% loss. I've been running a PTC for quite awhile.
72 Plymouth Roadrunner 11.08@123.25
[Re: justinp61]
#2569784
10/26/18 03:36 PM
10/26/18 03:36 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I've had a UCC in mine since 2005 no issues...
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Roughbird72]
#2569790
10/26/18 03:47 PM
10/26/18 03:47 PM
6PKRTSE
Motor City
No one mention Turbo Action ? GER? ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) I learned the hard way on that way back when. Broke one GER(it sound like a box of glass), they replaced it and the replacement had 13% loss. I've been running a PTC for quite awhile. One of my buddies tried a 10" 4000 GER in his turbo 400 in his 68 Pontiac because they were so cheap. He got lucky. It lasted many years with abused street/strip miles in a 10 sec all steel street car. Still worked great when he just sold it a few years ago. The car has changed hands & is still going strong today & is back up for sale again now from new owner #2.
[Re: justinp61]
#2569935
10/26/18 08:50 PM
10/26/18 08:50 PM
Posts: 2,527 PA
moparacer
PA
I had and 8 inch ATI in my car that broke a lug in July. James at Coan built me a spragless 8 inch that picked me up .05-.06 in the 1/8.
If you are shoe polish racing a loose 8 inch is the way to go.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: justinp61]
#2569944
10/26/18 09:14 PM
10/26/18 09:14 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I've had great luck with ATI, the one in my 9 second 69 Dart had less than 3% slip. ALOT of guys at my local tracks are using 501 Perfect Converter now and having awesome results.
[Re: 6PKRTSE]
#2570235
10/27/18 03:20 PM
10/27/18 03:20 PM
Roughbird72
No one mention Turbo Action ? GER? ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) I learned the hard way on that way back when. Broke one GER(it sound like a box of glass), they replaced it and the replacement had 13% loss. I've been running a PTC for quite awhile. One of my buddies tried a 10" 4000 GER in his turbo 400 in his 68 Pontiac because they were so cheap. He got lucky. It lasted many years with abused street/strip miles in a 10 sec all steel street car. Still worked great when he just sold it a few years ago. The car has changed hands & is still going strong today & is back up for sale again now from new owner #2. The second converter was still working when I replaced it with the PTC 9.5", but the 13% loss was costing me almost .30 and quite a bit rpm.
[Re: justinp61]
#2570296
10/27/18 06:06 PM
10/27/18 06:06 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
We've been dealing almost exclusively with JW Performance for a while now. Really love my 8" for the 904. We've sent a few back for adjustments and they've performed exactly like what we were looking for when we got them back.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
