Re: Small Block Head ??
[Re: dwayne welder]
#2568598
10/23/18 08:57 PM
10/23/18 08:57 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
If they dont LEAK!!!!!!!!!!!!!!!! I have seen 3 sets that leaked and tryed to fix!!!!!!!!!!! Don't say that as I already made the deal.
6.50 @105.26
[Re: Kindafast]
#2568736
10/24/18 07:15 AM
10/24/18 07:15 AM
Kindafast
Seaford, Va
The ones I am getting are used and on a guys vehicle so I feel good about them. They do shaft oil don't they ?
6.50 @105.26
[Re: Kindafast]
#2569186
10/24/18 11:22 PM
10/24/18 11:22 PM
Posts: 5,488 SoCal
Brian Hafliger
SoCal
The ones I am getting are used and on a guys vehicle so I feel good about them. They do shaft oil don't they ? Yes they do. Don't over port the ex. ports, and you'll be good to go.
Brian Hafliger
[Re: Brian Hafliger]
#2569189
10/24/18 11:28 PM
10/24/18 11:28 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
The ones I am getting are used and on a guys vehicle so I feel good about them. They do shaft oil don't they ? Yes they do. Don't over port the ex. ports, and you'll be good to go. 😉
[Re: Kindafast]
#2569644
10/26/18 08:03 AM
10/26/18 08:03 AM
Kindafast
Seaford, Va
Thanks everybody for all of your comments and opinions. I look forward to getting my new " used " heads and seeing how they work. I talked with Ryan at Shadey Dell about porting them . Looking for a high 9 second pass next year on engine ..
6.50 @105.26
[Re: Kindafast]
#2569653
10/26/18 08:42 AM
10/26/18 08:42 AM
one bad fish
bronx n.y
Thanks everybody for all of your comments and opinions. I look forward to getting my new " used " heads and seeing how they work. I talked with Ryan at Shadey Dell about porting them . Looking for a high 9 second pass next year on engine .. thats no problem to achieve that you will be fine
[Re: Kindafast]
#2570190
10/27/18 12:41 PM
10/27/18 12:41 PM
Posts: 3,433 Toronto
mshred
Toronto
Thanks everybody for all of your comments and opinions. I look forward to getting my new " used " heads and seeing how they work. I talked with Ryan at Shadey Dell about porting them . Looking for a high 9 second pass next year on engine .. Pump gas all motor high 9 sec. pass?? I'd like to see that, isn't too common in my opinion and definitely not easy either
