Page 2 of 4 1 2 3 4
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567498
10/21/18 10:21 PM
10/21/18 10:21 PM
Locomotion Offline
Locomotion  Offline
I've broken a few 742 8 3/4's over the decades. It's always been the ring & pinion teeth. 1.47 best 60' in a 3,540+ lb 360 footbrake car. I've been using the aluminum cases, which may help overall. I believe that weight is a big factor. But it's difficult to pin down why other things, like an OEM cap, breaks before the teeth. Lots of variables. I put a Dana 60 in my 12 second 3,930 lb Aspen and haven't changed the rear in the Dart yet. Peace of mind.
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567505
10/21/18 10:41 PM
10/21/18 10:41 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
This year I could have run a 8.75 as my car has been on jack stands 99% of the time. When I get back to the track, I prefer my S60.
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567507
10/21/18 10:43 PM
10/21/18 10:43 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Originally Posted By B3422W5
Than a production 489 housing
Anybody using a nodular 8.75 rear with a brake?
I have done this, as my Dart got quicker the parts attrition got worse. 60' 1.39/1.40 normally now, 3375lbs Nod 489 case, 35 spline, magic pink goo shock proof oil, back braced. I run a 4.30 gear which is probably the worst but it is what the car wants.
I race often it got down to 2 ring and pinions a year, Richmond, Motive, Yukon had them all. I did a 9" and am very happy with it. You will be money ahead in the long run to just upgrade to a tow truck rear or a 9"
I had to type this out 3 times to remove the cutting sarcasm, cuss words, and bad attitude I have on this subject
"Just a Bracket car dressed up like a streetcar"
Re: Nodular 8.75 case , how much stronger [Re: Just-a-dart] #2567517
10/21/18 10:56 PM
10/21/18 10:56 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Thanks. That settles it
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Nodular 8.75 case , how much stronger [Re: merpar] #2567537
10/21/18 11:25 PM
10/21/18 11:25 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Originally Posted By merpar
The weak point in the 8 3/4 is the bearing caps.
"You can brace it like a tank and it will NOT fix the inherent weakness of the 8.75. Torque pushes the ring gear away from the pinion when the case flexes. You CAN'T fix that. They break caps because all the debris from the shelled teeth gets in there and it pushes the cap off. So you will spend a lot of time and money trying to fix a problem you can't fix and it will eventually break anyway." Monte Smith
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Nodular 8.75 case , how much stronger [Re: Just-a-dart] #2567538
10/21/18 11:26 PM
10/21/18 11:26 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
. I'm going to have to say it was being built wrong for you to have broken that much stuff in a 10 second car.. guys like Thumper have been using the same one for 17 years.. that being said there is no substitute for 9inchs whistling
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Nodular 8.75 case , how much stronger [Re: WHITEDART] #2567548
10/21/18 11:34 PM
10/21/18 11:34 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
[/quote]. I'm going to have to say it was being built wrong for you to have broken that much stuff in a 10 second car.. guys like Thumper have been using the same one for 17 years.. that being said there is no substitute for 9inchs whistling [/quote
Ha ha You sir are still a A..hole (and a friend)
Re: Nodular 8.75 case , how much stronger [Re: Thumperdart] #2567582
10/22/18 12:22 AM
10/22/18 12:22 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Originally Posted By Thumperdart
Originally Posted By csk
Ok I will say it, Do not waste more money on an 8 3/4, PERIOD
Been driving racing my 9-second Dart forever and JUST replaced the "stock" pumpkin 2+ years ago that had stock caps bolts etc. Too many wives tales but then again, some people are puttin them in the wrong application so you need to know where the cut off point is...........
The cut off point in mine was reached last weekend. Shelled teeth off the ring gear even with all the band-aids, but that's with a car that weighs 3800+
I'll be purchasing a Dana 60 next month.
72 Plymouth Roadrunner 11.08@123.25
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567589
10/22/18 12:28 AM
10/22/18 12:28 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I’ve had no issues with either the stock or Nodular 489 case launching at 4500 dead hooking on Drag Radials off the brake at varying weights between 3300 and 3150. 250+ launches off the stock case, while I worked through traction issues to boot. Last weekend it went 6.30 in the 1/8mi with a 1.36 60’. No doubt a Dana or Ferd 9” are tougher, but needed? The data in my book suggests otherwise for a 3300 lb car running 10’s.
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567624
10/22/18 01:24 AM
10/22/18 01:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’m sure if we search enough we can find somebody who’s had no prob with HP and his 8 1/4 too.
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567626
10/22/18 01:32 AM
10/22/18 01:32 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
& when that 8 3/4 lets go & takes out that expensive 727,a518 mopar auto trans, THEN the 8 3/4 size tears will flow smile
Re: Nodular 8.75 case , how much stronger [Re: J_BODY] #2567627
10/22/18 01:35 AM
10/22/18 01:35 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
haha
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Nodular 8.75 case , how much stronger [Re: Thumperdart] #2567737
10/22/18 11:20 AM
10/22/18 11:20 AM
an8sec70cuda Offline
Been running the Dr Diff unit for 2+ years and it is awesome imo and a bit heavier but beefier with forged caps and stout adjusters.........of course my stock unit lasted 16+ years........... boogie drive
Come on Dom, we all know you go to the track for a couple passes like once every 2 years. laugh2
Beating on it on the street will never duplicate the traction/stress it will see at the track. Lots of weak parts can live a long life w/ no traction.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Nodular 8.75 case , how much stronger [Re: an8sec70cuda] #2567740
10/22/18 11:21 AM
10/22/18 11:21 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Thank you!
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567741
10/22/18 11:24 AM
10/22/18 11:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Why did the factory put the dump truck rear in stick cars? I mean come on! They already had 8.75s that would fit.... and these were street cars... with tiny skinny tires!! What were they thinking!!
Re: Nodular 8.75 case , how much stronger [Re: an8sec70cuda] #2567745
10/22/18 11:36 AM
10/22/18 11:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I ran a 8 3/4 and still do in the race car.. the
car is light but it blew the ring and I changed
to the alum center.. its had a back brace all
along.. when I built the hot rod I put a 9" in
it with a back brace and DRs.. had slicks in
the race car and a brake with 1.19 60'.. both
are still running strong
wave
Re: Nodular 8.75 case , how much stronger [Re: J_BODY] #2567800
10/22/18 01:20 PM
10/22/18 01:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thank you!
Your welcome and I will post a pic of my fat ass time slip book then you can tell me how I've only raced a couple times a year..........Don't be hatin on my quick ass n/a street car......... drumhit
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567813
10/22/18 01:48 PM
10/22/18 01:48 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I still run the 742 8-3/4” that came with my car from the factory. After breaking a couple of sure-grip differentials, I now run a spool, along with a steel cap on the driver side, 35-spline axles, and my housing has a brace stitched onto it. My car doesn’t make power like most on this board, but I do throw more weight at mine than most, as my car crosses the scales at a solid 3870 these days. It 60’s in 1.53,the footbraking.
I know a guy here locally that runs a low10-second 67 GTX on a trans brake. He still runs an 8-3/4”. My belief is that 8-3/4’s have their place. A 9-second B-body may not be that place.
For all those that call the modifications “band-aids”; the 9” units that most run are not stock Ford units, they’re full of aftermarket stuff also. For that matter, most Dana’s in this conversations are likely S60’s outfitted with Spools, aluminum covers, and aftermarket axles.
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567817
10/22/18 02:01 PM
10/22/18 02:01 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Don did not mention his car is a ladder bar car that will be another add expensive of switching over to the dana the hp your going to make will be fine with a new housing and axels
Re: Nodular 8.75 case , how much stronger [Re: StealthWedge67] #2567821
10/22/18 02:09 PM
10/22/18 02:09 PM
Originally Posted By StealthWedge67
For all those that call the modifications “band-aids”; the 9” units that most run are not stock Ford units, they’re full of aftermarket stuff also.:
I agree: No stock Ford parts at all tsk work I was told by Joe Reath back in the early 1970 that their funny car, Dunn and Reath, where the test mule for the Chrisman family helping develop the Ford nine inch for drag racing. He said they where into it back then for around $2300.00 and still would put the Dana 60 back in the car to go to certain high altitude low traction tracks like in Salt Lake so they didn't have to change third members at the races due to carnage at those tracks work
As far as Dana 60 used for drag racing in some cars I normally will use a junk yard damaged Dana 60 core due to the lower price and I'm going to have them cut down and narrowed to fit and use after market spools and axles up
The truck rear ends set up properly will push by hand in the car so much easier than any 9 inch Ford equip car I have help push at the races or any where else, same thing on drag cars with 8 3/4 rear ends in them when it comes to pushing them by hand shruggy work
Page 2 of 4 1 2 3 4
