Re: XtremeJohn's Duster project
[Re: GOAT Duster]
#256684
03/19/09 12:40 AM
03/19/09 12:40 AM
Posts: 106 Albuquerque, NM
GOAT Duster
Albuquerque, NM
Last pic for tonight. Here it is in mostly primer. As body work gets going I will post more pics. I have just been sanding and priming areas in order to see what I find that I get the fun of fixing. Plus I wanted to see how much of the car I could actually prime in the garage without the wife coming out and cutting off my air. ![](/ubbthreads/images/graemlins/spank.gif) By the way the other side is mostly in primer too.
[Re: UCUDANT]
#256686
03/19/09 12:54 AM
03/19/09 12:54 AM
GOAT Duster
Albuquerque, NM
You met my wife, what do you think...I can fix the air...it is my neck I fear. lol I have acquired a few 8 3/4 rearends. A B body and a C Body...one of them will make it into the car. The B looks like it will fit with the wheels and tires that I have now but I am still thinking. UCUDANT keeps bugging me to minitub it. That will depend on what goes into the 71 dated 360 block we recently were given. Donations are awesome. ![](/ubbthreads/images/graemlins/bow.gif) If I can afford to stroke it then minitub will be a necessity and that means cutting down a housing and axles. Good thing I have two to play with and a third set of axles. Thanks Bob
[Re: GOAT Duster]
#256688
03/24/09 11:54 PM
03/24/09 11:54 PM
GOAT Duster
Albuquerque, NM
UCUDANT headed off to the MATS this weekend with out me. ![](/ubbthreads/images/graemlins/rant.gif) But I am not upset...a little jealous is all, but then again while he is out looking at other peoples cars I am here working on mine. ![](/ubbthreads/images/graemlins/2231195-dggif.gif) Here is a shot of the patch tack welded into the right rear quarter.
Re: GOAT Duster's project aka xtremejohn
[Re: GOAT Duster]
#256691
03/25/09 11:04 AM
03/25/09 11:04 AM
The welds aren't THAT bad. You gotta grind 'em down anyway! ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: UCUDANT]
#256695
03/28/09 11:58 PM
03/28/09 11:58 PM
GOAT Duster
Albuquerque, NM
The patch took a little bit of bending, tweaking, filing,hammaering and grinding to make it fit just so. Them I rought it up a bit and filled with kitty hair. Used to hide small imperfections before skimms of bondo and primmer and lots and lots of block sanding. OH well it is called "Body work", not "Body fun".
[Re: GOAT Duster]
#256696
03/29/09 08:51 PM
03/29/09 08:51 PM
Posts: 8,149 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
...and filled with kitty hair.
DISCLAIMER: No kitties were harmed while performing of this repair ![](/ubbthreads/images/graemlins/whistling.gif)
