Re: Using a box truck as a race car hauler???
[Re: theraif]
#2565903
10/18/18 01:27 PM
10/18/18 01:27 PM
Posts: 22,722 Bitopia
jcc
Bitopia
same here thought it would be cool to make one of these into a hauler But the U hauls do not have flat floors, they have internal wheel wells, and they are IMO kinda of sissy trucks? Not sure what the real advantage is.
[Re: A/MP]
#2566259
10/19/18 12:56 AM
10/19/18 12:56 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
What is the disadvantage of just using a 4400# lift gate for the car and a walk through door on the side?
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: 65 Hemi]
#2566266
10/19/18 01:06 AM
10/19/18 01:06 AM
Superfreak
Superfreak
The further you have the deck out in-order to have your car sit on it the load on the hydraulics will exceed the lift capability.
[Re: 65 Hemi]
#2596868
12/25/18 06:45 PM
12/25/18 06:45 PM
65 Hemi
San Diego CA
I got my box truck/hauler home after a 1500 mile drive. It’s a little under powered with a 5.9 Cummins but some 75hp injectors will help. It drove like a dream and for $20k I couldn’t replace my enclosed trailer for the price. Hopefully now the lift gate will lift my car. It’s a 4400# lift gate but 1/2 the car will be on extended ramps!
Doug
[Re: topside]
#2596910
12/25/18 08:30 PM
12/25/18 08:30 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
It's a tempting idea, but the Oleyniks we used had beavertails and much lower rear sill (floor) height; yet the ramps still had to be at least 8 feet long and positively lock into the sill. Very tough deal to modify the rear rails & floor to make a beavertail out of a "normal" box truck. I've seen some moving vans that sit lower, but still iffy on load height and then there's the wheelwells. Medium-duty truck maintenance is not like working on a pickup; stuff might last longer, but it's half again as large and seems like triple the weight! We'd get a million miles or so out of a GMC 6500, but any wheel/tire/suspension/brake/drivetrain maintenance was a back-breaker. Yes,the Oleyniks built most of the haulers back in the day including the 77 S&M hauler now owned by a close friend.The 413 has been replaced with a Cummings out of a pickup along with the dash being grafted into the cab.The 2 speed rear is disconnected but I could not keep up to it with my 2010 Hino rollback.So maybe more boost or a gear change could help that issue. One other thing,air brakes are an endorsement only on a CDL.......
[Re: A/MP]
#2596923
12/25/18 09:27 PM
12/25/18 09:27 PM
65 Hemi
San Diego CA
This was $20k and I figured I may have another $15k in when I’m done with bathroom and kitchenette, insulation and AC.
Doug
[Re: Twostick]
#2596925
12/25/18 09:30 PM
12/25/18 09:30 PM
65 Hemi
San Diego CA
It’s a 2000. There are a lot of injector choices out there and I still may go with a tuner. I may need to get creative with the lift gate . I think you're going to be disappointed with that lift gate plan. Take a look at how the gate works on a stacker trailer as that's where you're going to end up I think.
The rest of the plan sounds good. If Texas won't let you register it as a motorhome after the required components are installed and I seriously doubt they won't, find a state that will.
What year is the truck? Those 75 hp injectors are usually a 12 Valve deal which is 98 and older. If it's got a common rail injected engine, 2003 or newer IIRC, more power is a Bullydog tuner or preferred brand away. No hardware changes unless you're planning to get silly. The 98.5 - 2002 24V with the VP44 pump doesn't have as much tuner support but 75-100 hp can be had with an Edge EZ box and no hardware changes.
What trans and rear axle ratio?
Kevin
Doug
[Re: Locomotion]
#2597103
12/26/18 01:00 PM
12/26/18 01:00 PM
Posts: 34,947 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Neat truck but, I think you are going to run into problems with your plan
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: EchoSixMike]
#2597171
12/26/18 03:21 PM
12/26/18 03:21 PM
65 Hemi
San Diego CA
Thanks for all the input. Worse case I have a line of a full lift gate made to lift car. We will see how it all goes... Maybe I should test it with my wife’s car when she is not home. Lol 😂
Doug
[Re: 65 Hemi]
#2597194
12/26/18 04:06 PM
12/26/18 04:06 PM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Maybe I should test it with my wife’s car when she is not home. Lol 😂 THERE'S an idea!!! Lol Kevin
[Re: 65 Hemi]
#2597221
12/26/18 04:57 PM
12/26/18 04:57 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
Does it have a Jake Brake on the truck now? If not I would add it for safely stopping it ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I agree on not using that lift gate to support the car while traveling ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) I've owned and used a bunch of different car trailesr and car hauler trucks from one ton crew cabs with open beds and ramps to a early Dodge D500 with a flat head six and a two speed rear axle that ended up with a 392 Hemi in it, which helped that old rascal a bunch I wrecked (totaled) a friends car on a borrowed open trailer that total the Hemi GTX NHRA stocker and hurt the trailer and my 1/2 ton Ford pickup due to not having enough stopping power to avoid a dog running out in front of the truck on the way to the races, the dog got hung up the right front wheel well and jerk the steering wheel out of my hand which resulted in jack knifing the car and trailer ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) Multiple mistakes compounded and ruined our day ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I've not towed anything with a 1/2 ton pickup since, that accident happened in 1973
[Re: jcc]
#2597342
12/26/18 11:19 PM
12/26/18 11:19 PM
Posts: 1,505 TN
SCATPACK 1
TN
same here thought it would be cool to make one of these into a hauler But the U hauls do not have flat floors, they have internal wheel wells, and they are IMO kinda of sissy trucks? Not sure what the real advantage is. JCC you would just build ramps over the wheel wells. Saw that in a hauler that Mr. 4 Speed Herb McCandless had back in 72 for his Pro Stock Demon. The car was not hauled Flat, It was on a tilt like on an open Ramp Truck.
Old Geezer Racing
[Re: Cab_Burge]
#2597353
12/26/18 11:41 PM
12/26/18 11:41 PM
65 Hemi
San Diego CA
I will be putting a jake brake on it. It does have new brakes and drums all the way around and the brakes are air brakes. Safety will always be first. I will always own a newer 3/4 or 1 ton truck. I have a new 3500 dually with 1500 miles on it to tow if needed. I really bought the truck because I think it will be cool/convenient when done. To be honest with all my time being taken with businesses and with young kids I may not race for a few years anyways. It will be fun to tinker on and make just the way I want it when time allows.
Doug
