Re: overcharging [Re: maxwedge1] #2567840
10/22/18 03:01 PM
10/22/18 03:01 PM
and bulk heads are corroded.
NAPA has the male/female brass terminals (725147/725145) & they are 99 cents ea but you can get them elsewhere in quantity for less. there is a slight trick for getting em in/out & both bulkhead halves to fit good when done, just holler when the time comes.
Re: overcharging [Re: maxwedge1] #2568495
10/23/18 06:22 PM
10/23/18 06:22 PM
PA
70HemiGTX Online content
70HemiGTX  Online Content
PA
You could also just have a bad connection somewhere in your system. I had a 71 Challenger. It would actually cook the battery. I chased all the wires under the hood and the dash. Finally one day I was laying under the dash just looking around and saw a black streak in the connector for the steering column to the main harness. It was the main (heavy) red wire. The connection was bad. I snipped the wire off on both sides and used a "butt" connector to make the connection. Solved my problem. Charging went back to normal.
Look at all your connections. Pull them apart. I could not pull that one apart. I was lucky it didn't burn the harness up.
Re: overcharging [Re: 70HemiGTX] #2568544
10/23/18 07:58 PM
10/23/18 07:58 PM
^^^ agreed, you VOM is your best friend right now. fast idle voltages.
