1970 Cuda road lamp switch location #2564517
10/15/18 06:07 PM
10/15/18 06:07 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Anyone have a photo of the location of the road lamp switch location on a rallye dash? Do you run a relay with your road lamps? I read somewhere that a relay was not necessary to operate the road lamps but may be required for other functions.
Re: 1970 Cuda road lamp switch location [Re: gregok] #2564899
10/16/18 03:52 PM
10/16/18 03:52 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
70 and 71 have different relays and the wiring is also different..if you are running the original switch, most of them won't handle the full 12 volts through them, hence the relay.as for the mounting, they are different locations..standard dashes are under the headlight,wiper,dimmer panel..
Re: 1970 Cuda road lamp switch location [Re: AARCONV] #2564946
10/16/18 05:09 PM
10/16/18 05:09 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I have a rallye dash, where is the switch located on it?
Re: 1970 Cuda road lamp switch location [Re: gregok] #2564956
10/16/18 05:31 PM
10/16/18 05:31 PM
Kirkland, Washington
Pacnorthcuda Offline
It hangs in front of the heater controls. Just to the left of the fan "OFF" lettering.
Re: 1970 Cuda road lamp switch location [Re: gregok] #2564989
10/16/18 06:18 PM
10/16/18 06:18 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
The road lamp switch on a rallye dash mounts on the bottom left lower frame. There will be a D shape punched hole along with a small hole in front of it to line up the switch bezel.
The contacts inside either the 70 or 71 road lamp switch are just too small to support the current swing directly to the front lamps, which is why they used a relay.
Re: 1970 Cuda road lamp switch location [Re: Slotts] #2565019
10/16/18 07:22 PM
10/16/18 07:22 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
thanks, that is exactly what I needed.
Re: 1970 Cuda road lamp switch location [Re: gregok] #2565179
10/17/18 01:14 AM
10/17/18 01:14 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
70 Cuda ralley dash...
roadlamp70cudaralleydash.JPGroadlamp70cudaralley.JPGroadlampralleydash70cuda.JPGroadlampralleydash70.JPG
Re: 1970 Cuda road lamp switch location [Re: DAYCLONA] #2565268
10/17/18 10:56 AM
10/17/18 10:56 AM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Thanks Dayclona!
