Re: G's Mopar build thread (hemi, gerst, '69 Charger)
[Re: gsmopar]
#2564301
10/15/18 10:45 AM
10/15/18 10:45 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Do you have studs or bolts on your valve covers? If you have studs you MAY have trouble getting the passenger's side valve cover off.
My car flexes enough that if I jack it up and take the weight off the front suspension, the valve cover can be removed. I do have valve cover studs. If it's sitting w/ the weight on the tires, the cover contacts the shock tower when I try to lift it off. Hopefully yours doesn't do this since you have snout bars on your cage...wish I'd done that.
[Re: Cab_Burge]
#2564616
10/15/18 10:19 PM
10/15/18 10:19 PM
Posts: 4,077 Mo.
racerx
Mo.
Cab....I was speaking on the build it self, ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) the valve cover is a little to tight for my likings. but i'm sure the op will address that ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) consider this a ![bump bump](/ubbthreads/images/graemlins/custom/bump.gif) don't what this thread to get lost.
[Re: racerx]
#2564674
10/16/18 12:25 AM
10/16/18 12:25 AM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Cab....I was speaking on the build it self, ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) the valve cover is a little to tight for my likings. but i'm sure the op will address that ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) consider this a ![bump bump](/ubbthreads/images/graemlins/custom/bump.gif) don't what this thread to get lost. The thread won't get lost! I'm a pic/post [censored]! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I shortened the Engine Plate and sealed it to the water pump. I also added the bypass mod with a threaded insert to adjust the orifice size. Currently at 1/8 per the other thread on this board.
[Re: second 70]
#2565413
10/17/18 03:44 PM
10/17/18 03:44 PM
an8sec70cuda
I can't be the only one who has to remove the shock to get the valve cover off am I? LOL
Even with studs removal sucks. Nope, I forgot to mention that I have to take the shock loose and push the shock stud down out the way.
[Re: an8sec70cuda]
#2566246
10/19/18 12:30 AM
10/19/18 12:30 AM
gsmopar
Arizona, USA
Even with studs removal sucks. Nope, I forgot to mention that I have to take the shock loose and push the shock stud down out the way. I have family in town this weekend and won't get any garage time. I'm going to try to pull the valve covers when I get a chance. I'll be sure to snap pics and update the thread. I might start a new thread for the induction. I "think" that I want the new Sniper 4500 fuel injection. However, I haven't read many success stories, and Thumper Carbs appear to be pretty bullet proof. I'll probably to the exhaust or cooling system next and think on this one a little.
[Re: gsmopar]
#2567715
10/22/18 10:41 AM
10/22/18 10:41 AM
an8sec70cuda
From what I've heard so far, I'd wait a while on the EFI. Put a good carb on it and enjoy it...later on when more of the bugs are worked out of these EFI systems, maybe.
[Re: gsmopar]
#2603741
01/09/19 02:33 AM
01/09/19 02:33 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Apparently Instagram stopped the hot linking of images. Does anyone have a good pic hosting site? I've been using https://imgur.com/It took a little while to figure out how to use it, but I'm pretty happy with it.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
