Page 5 of 10 1 2 3 4 5 6 7 9 10
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2604495
01/10/19 03:54 PM
01/10/19 03:54 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Originally Posted By gsmopar
This was the closes thing to an "Easy Button" that I've found for my car. I just had to drill a couple holes:
http://www.speedcooling.com/26-Big-Block-Mopar-Radiator-Dual-Fans.html
Can you measure the depth of that setup from the core support to the nose of the fans? It looks great and the price is nice too.
~7.5 inches from the support to the back of the fan motors. I was able to center the water pump between the fans to gain clearance. My car must have had the smaller radiator as I had to drill holes and use 1/4in spacers between the support and radiator mount:
Looks familiar... LOL. Looking good. Mine was tight & I mounted my over flow bottle the same way.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2604499
01/10/19 04:00 PM
01/10/19 04:00 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Originally Posted By moparx
very nice piece ! however, i would recommend a support bearing on the steering shaft. that would keep some flex out of the column and rack shafts.
beer
Really? I haven't seen a mopar with one yet and GERST, RMS, and MF are pretty common. Do you have any pics so I can see what you're talking about?
I added one om my steering shaft also.I made mine with a nylon bushing. This is about the best picture I have of it. It now has a grease fitting also that I added.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2604507
01/10/19 04:09 PM
01/10/19 04:09 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Bolts on the valve cover and yes I plan to clearance the shock tower. Really glad that I converted to GERST suspension so I don't need the shock tower. Now the real question is if I'll be able to get 1/4 without scratching the paint!
Indy has rocker covers that are cast with a relief for more shock tower clearance. Mine are & it helps with a little more room. I don't have any better close up pictures. Hard to tell in this view.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2604510
01/10/19 04:15 PM
01/10/19 04:15 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I found this one while on the stand. If you look closely. The way it is cast the shock tower area is more tapered here.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: 6PKRTSE] #2604534
01/10/19 04:53 PM
01/10/19 04:53 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Those are nice! Will they clear the Barton Rocker Arms?
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2604537
01/10/19 05:06 PM
01/10/19 05:06 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yes, they do. I run those also.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2604570
01/10/19 06:26 PM
01/10/19 06:26 PM
an8sec70cuda Offline
Wish they had those covers when I built mine years ago, lol. That's nice!
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: an8sec70cuda] #2604621
01/10/19 08:02 PM
01/10/19 08:02 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
If those are Indy heads,I believe they are 1/2" wider than the other hemi heads. I think that's why they put a relief in the valve covers.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: OUTLAWSSAA] #2604940
01/11/19 01:11 PM
01/11/19 01:11 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Mine are INDY SR. Not sure about 6PKRTSE's (Stage V?).
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2605246
01/12/19 12:16 AM
01/12/19 12:16 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Interesting read.... had no idea about the trials and tribulations of going “HEMI” .
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: J_BODY] #2605354
01/12/19 12:06 PM
01/12/19 12:06 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Ya, but I'll never burn another plug wire on a header! smile
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2607279
01/15/19 11:21 PM
01/15/19 11:21 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I picked up a mini starter and terminal relocation stuff (via moparts search function). I can't believe I ran the old factory tank for so many years. These little things are tiny!
A little grinding on the posts for clearance. Look similar to your setups?
Headers are going to be tight! I don't know what kind of tape the machine shop used to cover the exhaust ports, but that stuff is sticky. I really wish I took it off and cleaned things up before installing the engine. A few pics of the CNC'ed exhaust ports:
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2607465
01/16/19 12:53 PM
01/16/19 12:53 PM
USA
hudsonhornet7x Offline
USA
I searched for the starter terminal stuff here but did not find it, could you provide a link? Thanks, it looks awesome.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: hudsonhornet7x] #2607482
01/16/19 01:16 PM
01/16/19 01:16 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I'll post an image of my invoice when I get home tonight.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2607499
01/16/19 01:32 PM
01/16/19 01:32 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Lots of good information in this thread. An epic build.
Thanks for taking the time to post!
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2607557
01/16/19 02:49 PM
01/16/19 02:49 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
the yellow stuff on the valve guides/valves is assembly grease, correct ? or something special due to the heat there ? in other words, when burnt upon fire up, it won't stick to the valve stem and cause guide issues.
beer
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2607558
01/16/19 02:49 PM
01/16/19 02:49 PM
Cab_Burge Online work
Cab_Burge  Online Work
I hate the machine shops that use grease on the valve stems down runaway
The motor runs on engine oil, why not use that work I always do up
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2607573
01/16/19 03:06 PM
01/16/19 03:06 PM
Probably white lithium grease. Most use that when the engine will sit for a while before startup.
CHIP
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: an8sec70cuda] #2607584
01/16/19 03:19 PM
01/16/19 03:19 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
beer
I'll stick my finger in it later and let you guys know, but ya! Probably assembly lube of some sort.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2607601
01/16/19 03:39 PM
01/16/19 03:39 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
laquer thinner on a rag, hold it on there, will take that tape residue right off....
Otherwise..NICE build !
....BAD A$$ STREET CAR.....
