340 dual exhaust fit 318? #2564143
10/14/18 11:06 PM
10/14/18 11:06 PM
OK
Boes71conv Offline OP
OK
Can anyone tell me if a stock 340 dual exhaust system will attach correctly to the stock exhaust manifolds of a 318 on a 71 Barracuda? or do I need to install 340 exhaust manifolds?
thanks,
Re: 340 dual exhaust fit 318? [Re: Boes71conv] #2564150
10/14/18 11:13 PM
10/14/18 11:13 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
pretty sure you need to use 340 exhaust manifolds 71 is different than 70
Re: 340 dual exhaust fit 318? [Re: Boes71conv] #2564163
10/14/18 11:31 PM
10/14/18 11:31 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
You need 340 manifolds 340 exhaust flanges are flat, 318 are shaped like a cone..or you can custom fit or make up the front mani connection and use the rest as 340
Re: 340 dual exhaust fit 318? [Re: Boes71conv] #2564170
10/14/18 11:39 PM
10/14/18 11:39 PM
OK
OK
That is what I suspected. Thanks for the feedback.
Re: 340 dual exhaust fit 318? [Re: Boes71conv] #2564293
10/15/18 10:37 AM
10/15/18 10:37 AM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
Or you can order a direct bolt in 318 exhaust system from Accurate Ltd.
http://www.accurateltd.com/70-74-E-Body-Small-Block-318340360-Complete-Exhaust-Systems-_p_239.html
Re: 340 dual exhaust fit 318? [Re: Boes71conv] #2565256
10/17/18 10:17 AM
10/17/18 10:17 AM
OK
OK
Talked to Accurate exhaust and they can build me one. Thanks
Re: 340 dual exhaust fit 318? [Re: Boes71conv] #2567463
10/21/18 08:52 PM
10/21/18 08:52 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
WOW, is that made out of gold?
Our local garage will make a complete dual system for about $400.oo, installed.
I have mechanical Aptitude.
I can screw up anything.
