Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2572445
11/01/18 12:15 AM
11/01/18 12:15 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By furious70
I had started to wonder that. Every combo I've had in the car is supposed to be internally balanced. I've been concerned cuz this block has an 'E' stapmed on the pad and is a 71, not original to the car but was in the car when I got it with 43k in it. Engine has been rebuilt by a cheap house back in the day, had a reman tag on it.
It'd be sad that if it's always had a cast crack in it and in 21 years of ownership I didn't realize it.
This would be the first one I've mismatched, do they normally act up in only 1 rpm range?
If your engine is marked "E"it's a 69 not a 71. 71 would be marked "G". All 69s are internally balanced.
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2572460
11/01/18 12:40 AM
11/01/18 12:40 AM
IL
furious70 Offline OP
IL
No, e for cast crank, like later 440's were stamped. It's a 71 date engine by casting date
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2572465
11/01/18 12:51 AM
11/01/18 12:51 AM
IL
IL
Also found a site that said take rpm/60=Hertz, don't need a sirometer.
2700rpm is about the worst spot. 45hz. Same site said for internal engine stuff take second order so 90hz. What I can't find is something that says what materials or component matches that frequency.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Bad Vibrations, Chicago Fury saga [Re: Morty426] #2572479
11/01/18 01:39 AM
11/01/18 01:39 AM
Prefix "E" would be for the date (1969 I think)/ suffix "E" would denote a cast crank (originally & likely still) eng.
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2579009
11/16/18 01:30 AM
11/16/18 01:30 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
Once you figure out your Hz, how do you figure out if it's a 1st or 2nd order harmonic? And then what is a guide for where to look at in/on the engine? I'm trying to read up, but it's almost over my head
Re: Bad Vibrations, Chicago Fury saga [Re: Jeff_383] #2579199
11/16/18 03:55 PM
11/16/18 03:55 PM
IL
IL
I'm in that exact spot, I couldn't find any more info. the one site I found said that external stuff was 1st order, internal is 2nd order. I'm 99% sure it's not an accessory or physical interface with the chassis or something, so I went with 2nd order.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2579228
11/16/18 04:59 PM
11/16/18 04:59 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You can eliminate all the external accessories by removing all the belts. A few minutes without the waterpump turning won't be the end of the world and it will eliminate the one big accessory, the cooling fan.
How's the crank endplay?
Kevin
