Why trans hesitates on 2006 Dakota 4x4 4.7 #2562694
10/12/18 12:14 AM
10/12/18 12:14 AM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
Started last winter, when I put trans in drive it hesitated about 5 seconds before moving forward. It's now doing it in warmer weather. What could be causing this? Thanks
Still looking for LM29H1B415501, '71 Demon 340
Re: Why trans hesitates on 2006 Dakota 4x4 4.7 [Re: PAULS_340] #2562721
10/12/18 01:09 AM
10/12/18 01:09 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
When was the last time you changed the fluid a filter in the trans.
Re: Why trans hesitates on 2006 Dakota 4x4 4.7 [Re: PAULS_340] #2563041
10/12/18 06:45 PM
10/12/18 06:45 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the filters are know to seperate at the plastic/metal conection and suck air causeing weird stuff, seen it a few times myself.
Re: Why trans hesitates on 2006 Dakota 4x4 4.7 [Re: PAULS_340] #2563442
10/13/18 04:10 PM
10/13/18 04:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There's a TSB on the problem:
http://dodgeram.info/tsb/2006/21-007-06.htm
NUMBER: 21-007-06
GROUP: Transmission
DATE: April 07, 2006
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-016-05, DATED SEPTEMBER 01, 2005, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS.
SUBJECT:
RFE Transmission Filters - Delayed Engagement And Related Transmission DTC'S
OVERVIEW:
This bulletin involves verifying the build date of the transmission, and if necessary, the replacement of both the cooler return and sump filters in the transmission.
MODELS:
2005 - 2006 (DR) Ram Truck
2005 - 2006 (HB) Durango
2005 - 2006 (KJ) Liberty / Cherokee
2005 - 2006 (ND) Dakota
2005 - 2006 (WK / WH) Grand Cherokee
2006 (XK) Commander
NOTE:
This bulletin applies to vehicles equipped with the a 45RFE or a 545RFE automatic transmission (sales code DG4 or DGQ respectively) having a specific transmission build date code (see the below DIAGNOSIS section for further details).
SYMPTOM/CONDITION:
The customer may experience an initial delayed shift engagement following an extended off (not running) period of time, generally after being parked overnight. The initial shift engagement may feel like a delay or slip when a transmission gear (reverse or drive) is first selected after engine start.
Re: Why trans hesitates on 2006 Dakota 4x4 4.7 [Re: PAULS_340] #2563727
10/14/18 02:36 AM
10/14/18 02:36 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I get the same thing sometimes in my 2007 Ram. I shift from drive to park and back a couple of times and it works fine afterward.
I change the fluid and filters sooner than the factory schedule. It has done this from about 40,000 miles to the current 312,000 miles.
