Re: 3.6 pentastar V6 questions [Re: NEVjr] #2560855
10/08/18 01:15 PM
10/08/18 01:15 PM
central IL
myduster360 Offline
myduster360  Offline
central IL
Originally Posted By NEVjr
[quote=myduster360][quote=NEVjr]
what are you using for an ECU? it sounds like you are able to read from it?
fly by wire throttle?
what donor vehicle? what all came from the donor vehicle?
where is the O2 sensor? does your ECU require the after cat sensor?
any other trap, pitfalls, or dragons to be aware of?
2013 Manual trans Wrangler PCM.
I use HP Tuners and DiabloSport CMR for Custom tuning.
yes I use the stock pedal sensor. I kept wiring as stock as I could.
No cats in a 72 Swinger(lol), so Rear O2 sensors are OFF in the tune along with A LOT of other crap(ie:evap). My "Exhaust manifolds" aren't done yet, so I didn't have upstream O2 sensors installed during that video. 1st fire was last Friday night.
Biggest issue so far has been interference with the steering gear and column with the A/C compressor(i had to delete it) and routing exhaust. The 3.6l is WIDE! As wide as a 440 valve cover to valve cover!
Tons of info in my Build thread.
https://www.forabodiesonly.com/mopar/threads/72-dart-swinger-3-6l-pentastar-t5.361683/
1972 Swinger 3.6L Pentastar
Diablo CMR tuner
Re: 3.6 pentastar V6 questions [Re: myduster360] #2560865
10/08/18 01:29 PM
10/08/18 01:29 PM
moparx Online content
moparx  Online Content
a lot of my questions answered on your build thread ! what a neat project, and well thought out ! up kudos to you sir !
beer
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2560889
10/08/18 02:40 PM
10/08/18 02:40 PM
central IL
myduster360 Offline
myduster360  Offline
central IL
Originally Posted By myduster360
[quote=NEVjr]I'm not aware of any Pentastar with a variable intake. I know my Jeep/Ram intake and my Caravan intake do not. im not sure of the 2016 and newer PSU engines
atleast as of 2018 they all have an intake runner length valve
2016 and newer PSU 3.6L has a lot cool upgrades like Cooled EGR and Variable Valve LIFT, but nothing about a variable intake.
This is the only mention of the intake manifold in Wards AutoWorld thorough write up
"The intake manifold is all-new, with longer runners to boost torque."
2016 and newer 3.6L may not be a sturdy as the 1st gen if you plan on a turbo or supercharger. The article mentions that in an effort to reduce overal weight, FCA "reduced the size of the main bearings and crankshaft pins and using thin-wall castings"
Diablo CMR tuner
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2562285
10/11/18 02:31 AM
10/11/18 02:31 AM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
youre right, parts guy quoted me the wrong part no.
I dont want to add any boost, it sounds like NA it will produce plenty of power, I am more interested in saving the weight. Your build thread is super helpful.
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2562292
10/11/18 03:00 AM
10/11/18 03:00 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
iagree
My thoughts exactly. Power it makes and the weight savings make it ideal in my book for a cruiser. up
Although I may have to rethink using an early A with the clearance problems he is having. work
I will definitely be following his thread. boogie
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2565218
10/17/18 02:50 AM
10/17/18 02:50 AM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
do you have a CAD file for the bell housing bolt pattern you are willing to share? Were the fuel lines plastic in the wrangler the motor came from?
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2566174
10/18/18 10:09 PM
10/18/18 10:09 PM
Missouri
randavis Offline
randavis  Offline
Missouri
I checked my 2013 Ram today and the oil pressure stays high (~80 psi) until the water temp gets to 192*.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2571209
10/29/18 08:18 PM
10/29/18 08:18 PM
central IL
myduster360 Offline
myduster360  Offline
central IL
Got 3.6L Swinger driving this weekend
https://www.youtube.com/watch?v=YEMtwDl6hd4
Diablo CMR tuner
