Loctite Form-A-Thread is made specifically for this task. You will need to use a release agent on the pipe or plug if you want it to be disassemble-able. Original JB Weld or JB Water Weld will work as well. The fitting doesn't see enough temperature or pressure to need anything more.
R. (Prince of Goop)
