Re: Gear drives?
[Re: GY3]
#2562953
10/12/18 03:39 PM
10/12/18 03:39 PM
Posts: 4,457 Washington
madscientist
Washington
Do the Milodon drives fit under a stock cover? Only on engines with a thick, cast timing cover. So, small block Chrysler's, pontiacs...damn I think FE ford but for the life of me I can't think of what that cover looks like, the 385 series fords. You get the idea. If it's a stamped tin cover then you need a cast aluminum cover to fix the idle to.
Re: Gear drives?
[Re: mopardude318]
#2562955
10/12/18 03:42 PM
10/12/18 03:42 PM
madscientist
Washington
I agree with mad scientist. I have a milodon gear drive in my 408 stroker. I can't hear the whine over the exhaust. I run mine on a street car, with street mufflers. My gear drive makes zero noise. If I don't tell you it's there, you won't know it. I've had people call me a liar at a car show I went to. I was talking to a few guys about it when I parked and I mentioned it was a gear drive. They had me start it again. When they couldn't "hear" the gear drive they said I was a bullshitter and walked away. And how do you prove what you have if the gear drive is under the cover? Pull it apart I guess.
Re: Gear drives?
[Re: madscientist]
#2563052
10/12/18 07:17 PM
10/12/18 07:17 PM
Posts: 43,372 Bend,OR USA
Cab_Burge
Why would you want to argue with car shows guy Aren't all of them car Experts, in their own minds I have that same problem here, a bunch of show and shine guys
Re: Gear drives?
[Re: Cab_Burge]
#2563183
10/13/18 12:14 AM
10/13/18 12:14 AM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Why would you want to argue with car shows guy Aren't all of them car Experts, in their own minds I have that same problem here, a bunch of show and shine guys I guess I'm kind of car show and race. It ran mid 10's with a little nitrous old school .590 and a Pete Jackson Noisy gear drive. I degreed the cam at 106 if I remember right. No issues with the gear drive. Ran it on a couple cams. First installed around 1993 and was in the engine when I sold it. From what I've read, belts have less harmonics and are supposed to be faster. I have yet to read about anyone with real world experience that actually gained hp or lost et with/without one. My new Hemi has a chain. MM asked me if I wanted a belt or chain. I asked if there was any HP to be gained with a belt. Mike said no. My slow pig
Re: Gear drives?
[Re: bigblk66_coronet]
#2563301
10/13/18 11:13 AM
10/13/18 11:13 AM
Posts: 4,213 New York
polyspheric
New York
Quite useful: you didn't know they were idiots until they self-identified: that's a "tell".
Boffin Emeritus
Re: Gear drives?
#2563355
10/13/18 12:48 PM
10/13/18 12:48 PM
Posts: 2,938 A shed in England
Tig
A shed in England
Ran a Milodon gear drive in the 572 (it came with it's own cover), hated the noise so changed it to a Jesel belt drive when funds allowed. No difference in ET and the valves springs still needed replacing at the end of the season.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
