proper way to repaint a car to best get factory look
#2560104
10/06/18 09:52 PM
10/06/18 09:52 PM
Posts: 356 Greenwood Lake, NY
fuelishnsilly
Greenwood Lake, NY
Is there any book or "how to" instructions to get the best look or technique for repainting a car? A friend of mine is starting a full blown resto on his car and is trying to get accurate information for the painter. I'm familiar with the dip tank primer process but is there any certain way or order the body color was applied?
thanks.
inherited a 69 roadrunner from my grand pop.
Re: proper way to repaint a car to best get factory look
[Re: fuelishnsilly]
#2560152
10/06/18 11:12 PM
10/06/18 11:12 PM
fuelishnsilly
Greenwood Lake, NY
He is doing a GTX. What would have been already assembled? I'm guessing doors, fenders, hood, trunk lid were all attached already? He is looking to do a base clear vs the single stage.
I also know the GTX got that organisol paint on the lower part of the car below the body molding. Would the color of the car been painted all the way down or just down far enough past that molding so as they did not waste paint?
[Re: fuelishnsilly]
#2560178
10/07/18 12:02 AM
10/07/18 12:02 AM
fuelishnsilly
Greenwood Lake, NY
true but isn't OE allowing base clear from what I heard? Either way, thats the paint he wants to use and I don't think he will ever go OE judging with the car. I guess his main goal is to make it appear like it was factory using modern paints and such.
[Re: fuelishnsilly]
#2560183
10/07/18 12:11 AM
10/07/18 12:11 AM
fuelishnsilly
Greenwood Lake, NY
no problem. since I'm going to be helping him disassemble and reassemble the car, I figured I'd try and get as much info for him as possible to help with the resto.
I do know that he has planned on keeping the undercarriage the primer gray and not paint it the full color of the car like over restored cars get.
[Re: fuelishnsilly]
#2560215
10/07/18 01:47 AM
10/07/18 01:47 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I also know the GTX got that organisol paint on the lower part of the car below the body molding. Would the color of the car been painted all the way down or just down far enough past that molding so as they did not waste paint? Is there a reason you can't tell us the year? Over communicate, please! I'm assuming it's a 69 but it matters. It also matters what factory it came from. As Scott pointed out if he's going two stage he's already failed so what's the point? You asked for correct, is that what he wants or is he going down the Home Depot to buy some Krylon?
[Re: fuelishnsilly]
#2560239
10/07/18 05:01 AM
10/07/18 05:01 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
What would have been already assembled? I'm guessing doors, fenders, hood, trunk lid were all attached already? Yes. Body shell plus everything that is body color, as carefully noted during disassembly, such as the following list that is correct for a '69 A body and may not be correct for a GTX. But this list will give you an idea what to look for. Body shell, partially Upper rear shock mounting studs Side marker housings, 4 Hood, all over Hood Hinges, partially, and fasteners Hood Striker and fasteners, all over Front Fenders (except wheel well) and fasteners, exterior only Fender tag, all over, and one screw Yoke Cross member and fasteners, partial Hood Lock Vertical Support and fasteners, partial Upper Grille Panel and fasteners, exterior only Lower Grille Panel and fasteners, exterior only Battery Tray, Battery Tray Brace, and fasteners Doors, except interior of weatherstripping. Door Hinges and fasteners, partial Deck Lid, all over Deck Lid Hinges. Deck Lid Hinge Supports (welded to body), partially Deck Lid Torsion Bars, partially Other paint: doors interior of weatherstripping, called UDF (upper door frame) color and LDF (lower door frame) color, door frame plastic plugs, and also quarter panel interior; door lock knobs; roof rails; A pillar plastic covers; quarter panel lower garnish. In addition there are some special things to note about sealers in the engine compartment at the cowl and on fenders as noted in the photos.
[Re: fuelishnsilly]
#2560240
10/07/18 05:05 AM
10/07/18 05:05 AM
kentj340
Cut and Shoot, TX
This photo shows quarter panel interior to be painted UDF color.
[Re: fuelishnsilly]
#2560241
10/07/18 05:40 AM
10/07/18 05:40 AM
kentj340
Cut and Shoot, TX
There are other instructions that you may want your painter to know, such as in these photos.
[Re: fuelishnsilly]
#2560242
10/07/18 05:49 AM
10/07/18 05:49 AM
kentj340
Cut and Shoot, TX
Another special paint consideration I have never seen discussed in this forum is: what will the backsides of parts bolted to the body shell be painted?
One example is the battery tray and brace. If they are painted while bolted to the inner fender, the backsides will receive no paint. And the part of the inner fender covered by the tray and brace won't get painted either. A solution is to paint the tray and brace all over while loose and bolt to the painted inner fender with painted fasteners. Or paint the parts all over while loose and again while bolted on.
A similar situation is the backsides of grille sheet metal panels. These backsides were coated with dip primer at the factory. For restoration painting, something better than primer would be preferable, such as a primer followed by a top coat that looks like factory dip primer before bolting on the car.
In the case of the hood hinges, the factory hand painted the hinge/hood interfaces with green zinc chromate paint. This green zinc chromate may have also been hand painted on the interfaces of some grille sheet metal parts, such as the yoke cross member, before it was bolted on. (I stripped all paint off this part before I knew to look for factory hand paint.)
Photo shows hood hinge painted body color F5 Limelight Metallic Green. The darker green on the bolt joint interface is factory hand painted zinc chromate.
[Re: Morty426]
#2560565
10/07/18 10:49 PM
10/07/18 10:49 PM
Posts: 21,528 N.E. OHIO, USA
A12
N.E. OHIO, USA
As Scott pointed out if he's going two stage he's already failed so what's the point? You asked for correct, is that what he wants or is he going down the Home Depot to buy some Krylon? Those two points I agree are VERY important!!! Started to restore my '69 LA plant GTX with points that I knew from Lynch Road and St. Louis assembly plant '68 and '69 cars and they were not done the same at the LA assembly plant. Even some of the decal placements were different on the LA assembly plant GTX and there were reasons for them being place differently......one was funny to the point of disappointment as I thought someone had replaced the radiator support.
[Re: fuelishnsilly]
#2560576
10/07/18 11:14 PM
10/07/18 11:14 PM
Posts: 29,655 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Even within the same plant in the same month there are differences.
Lots of different employees, different shifts, temperature & humidity when the car was dipped, sprayed, etc., etc.
So........
Your car was there when it was built, so it is the best evidence you can find, explore & discover all you can.
Record the details with a camera & start a file.
Document what you find on your own car & then put it back to the same way, anything less (or more) is not a true restoration.
[Re: Morty426]
#2560597
10/07/18 11:46 PM
10/07/18 11:46 PM
fuelishnsilly
Greenwood Lake, NY
I also know the GTX got that organisol paint on the lower part of the car below the body molding. Would the color of the car been painted all the way down or just down far enough past that molding so as they did not waste paint? Is there a reason you can't tell us the year? Over communicate, please! I'm assuming it's a 69 but it matters. It also matters what factory it came from. As Scott pointed out if he's going two stage he's already failed so what's the point? You asked for correct, is that what he wants or is he going down the Home Depot to buy some Krylon? Morty, He is using PPG automotive paint and not Krylon. Also, if using Base / Clear is so bad, why are manufacturers using that on cars today? And isn't OE now allowing base / clear also? Whats wrong with having radial tires on a car when the originals were the bias ply tires? Maybe he is missing the mark by using PPG instead of whatever brand of paint the factory used? Seriously, he is trying to make it look like how it would have been in 1969 with the gray primer showing and all but it shouldn't matter if he uses base / clear and radial tires since he is not building an OE car nor plans on doing that route.
