Re: 1966 dated 14 x 6.5" LBP steel wheel, first one I have seen.
[Re: NANKET]
#2558646
10/03/18 10:57 PM
10/03/18 10:57 PM
Posts: 8,414 Highland, MI.
Sunroofcuda
Highland, MI.
Like NANKET mentions, the spider is a 68-9 Mopar - the wheel center. The pre-68 Mopar wheels use a 9-3/4" ID dog dish. I've never seen a Mopar 14x6.5" anything steel wheel. Ford yes, Mopar no.
[Re: ScottSmith_Harms]
#2558735
10/04/18 02:15 AM
10/04/18 02:15 AM
Sunroofcuda
Highland, MI.
Sure that's not a 1976 Wheel? Really a strange one for sure. I don't think Motorwheel was even building rims in 1976. The latest I've seen were 1969 dated.
[Re: Alaskan_TA]
#2558777
10/04/18 09:13 AM
10/04/18 09:13 AM
Posts: 29,662 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Did any 1976 wheel have the 1968 type center? Did the '76 wheels have part numbers? No part number on this one like a lot of older wheels. If I was sure of what it was, I would not be asking. I really would love to know what it is for sure. ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Alaskan_TA]
#2559035
10/04/18 07:40 PM
10/04/18 07:40 PM
Posts: 17,527 Las Vegas, NV
6bblgt
Las Vegas, NV
the 11 16 66 date would be well into the '67 model year with the '68s on the horizon as far as production components (9" hub cap) would be concerned
a low production over-the-counter "performance" intended wheel wouldn't need to conform to current assembly line requirements
that "hoop" design will not clear '70 - up B/E-body & others sliding calipers
anyone know where Motor Wheel plant #2 was located?
M1 = Motor Wheel plant Lansing, MI M2 = Motor Wheel plant ? M5 = Motor Wheel plant Chatham, ONT
Motor Wheel Corp. made all the Rallye, Road, Polycast wheels in the '70s
Motor Wheel Corp. was owned by GOODYEAR 1964 - ?? at the start of '95 there were 3 MW plants in the US: Lansing, MI - Mendota, IL - Bowling Green, KY
[Re: Alaskan_TA]
#2559360
10/05/18 12:52 PM
10/05/18 12:52 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
When speaking on early wheels (these being the high performance, most big block, Hemi, and station wagon 14 x 5.5 applications) for 66 and some early 67 Wheels had the "10 hole" centers, 5 for the studs/lugs. The typical 67 wheels had 6 holes, 5 for studs/lugs, one supposedly a vestige feature for the no longer existing tapered axle pin. Your example shows none of these extra holes which leads me to think its a 68 application, or something that was not regular production.
[Re: mccannix]
#2559546
10/05/18 05:31 PM
10/05/18 05:31 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Are you certain it is not a Ford rim. Ford never put their oval Ford stamp on rims till later years. Have you checked it on a Mopar hub Yes I did, perfect hub match.
[Re: Alaskan_TA]
#2559736
10/06/18 01:58 AM
10/06/18 01:58 AM
Sunroofcuda
Highland, MI.
I am wondering what this could be?
Intended use, etc.
The center will take a 9" hubcap. Any good photos of the backside? I want a good look at the welds. Electrofuse or MIG?
