92 Dakota died
#2559207
10/05/18 01:43 AM
10/05/18 01:43 AM
Posts: 954 garnett kansas
rhad
garnett kansas
my trusty 92 died on me 3 times today,first 2 it restarted right up,third time it had to set a minute,,over the years ive replaced the crank sensor a couple times,any bets on that being the problem again?,ive always used genuine mopar parts on it comments please!! thanks in advance Butch
my ladder of success is missing some rungs
Re: 92 Dakota died
[Re: rhad]
#2559311
10/05/18 10:53 AM
10/05/18 10:53 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
Did it run fine after it restarted? How did it die, like turning the ignition off or did it sputter and die?
Re: 92 Dakota died
[Re: sportfury70]
#2559677
10/05/18 10:40 PM
10/05/18 10:40 PM
Posts: 10,625 Freeport IL USA
poorboy
Freeport IL USA
Corroded wire under hood on left front fender. Don't recall which one but very common issue with the generation of Dakota That would be the junction where 5 wires that are ignition power are factory spliced together (mine were pink with a blue tracer) between the master cylinder and the under hood fuse box on the newer ones, and between the master cylinder and the battery on the older ones. My 93 would loose the power to the fuel pump relay in the under hood fuse box, but I've seen them loose power to the cam sensor and the crank sensor also. If you have something in the ignition circuit that doesn't have power when its suppose to, look for the junction to have broken wires. Gene
Re: 92 Dakota died
[Re: poorboy]
#2559734
10/06/18 01:55 AM
10/06/18 01:55 AM
rhad
garnett kansas
ive replaced the fuel pump at least twice over the 23 years ive owned it,and ive replaced the crank sensor also over the years,it just DIED,no sputter,just like i shut the key off,i think but cant remember for sure that i looked at the wiring several years ago and it was fine,i ordered a new mopar crank sensor today.......we will see!!
Re: 92 Dakota died
[Re: mopwrd340]
#2573730
11/04/18 02:16 AM
11/04/18 02:16 AM
rhad
garnett kansas
late update,replaced the crank sensor and thought it was fixed???,i used a genuine mopar part!,drove for a few miles and it died again,no sputter just wham its dead interesting thing,if i just shift to netural or park and crank it wont start,BUT if i turn the key off then back on and crank it starts,i replaced the ign switch and tumbler a while back,surely not a loose wire where it plugs into the switch???? i did splice the wires and plug that go to the switchmbut that was 20 yrs ago,i left the wires long and stuffed them down into the column,i suppose its possible one of them has rubbed bare and shorting out,tho that seems far fetched,i looked at the wiring harness junction several yrs ago and it was ok,dont have a code reader and cant count flashes as this is obd1 ,IF it has set a code?? i hate these search and destroy missions,anyone else have a problem like this?,i ran a wire years ago from the fuelpump to near the battery,i can make the pump run by touching the wire to the hot post of the battery i know its a old truck with 348,000 miles but ive owned it since 95 and its my trusty backup that ill never sell
Re: 92 Dakota died
[Re: mopwrd340]
#2575702
11/08/18 02:40 AM
11/08/18 02:40 AM
rhad
garnett kansas
i looked at it some today and remembered that i replaced the ign switch just before this started,so upon wiggling the key a little it died,not sure thats it but i ordered a new switch and we will see in a few days
Re: 92 Dakota died
[Re: rhad]
#2578626
11/15/18 02:37 AM
11/15/18 02:37 AM
rhad
garnett kansas
i replaced the ign switch ,second day driving a few miles each time,no die!!!!!
Re: 92 Dakota died
[Re: rhad]
#2578645
11/15/18 04:48 AM
11/15/18 04:48 AM
Posts: 43,263 Bend,OR USA
Cab_Burge
All parts will die when you use them, some sooner than others How long are you shooting to use this truck? It has given you good service in my opinion
Re: 92 Dakota died
[Re: rhad]
#2578895
11/15/18 07:55 PM
11/15/18 07:55 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
FWIW, I have a 93 with 160K and it's been one of the most useful vehicles I have ever owned. So I watch threads like these with great interest.
I prefer the N bodies over the AN body ones any day of the week.
I wish LMC or someone would offer more parts for the N series.
Common sense is a flower that does not grow in everybody's garden
Re: 92 Dakota died
[Re: Ron_M]
#2579022
11/16/18 02:34 AM
11/16/18 02:34 AM
rhad
garnett kansas
i bought this truck in 95 it had 142000 on it now it has 348500 on it i will NEVER sell this truck,maybe they will bury me in it?,at almost 75 thats coming sooner than later!!
