Re: T56 Magnum / TKO 600 / 18 spline A833 Passon OD 4 speed [Re: grancuda] #2560150
10/06/18 11:11 PM
10/06/18 11:11 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That $6k did include a $3k T56 Magnum and a few other parts like a bellhousing, driveshaft, clutch disc with the proper splines... see the price list on the thread which lists absolutely everything he bought wink
I'm impressed that you can get all that stuff for a total of $3k though.
https://www.forabodiesonly.com/mopar/threads/t56-magnum-conversion.416558/
I agree that the waiting list has been ridiculous. Jamie Passon could sell a lot more transmissions if he can actually produce them in reasonable numbers.
Re: T56 Magnum / TKO 600 / 18 spline A833 Passon OD 4 speed [Re: grancuda] #2560200
10/07/18 12:53 AM
10/07/18 12:53 AM
WI
mopar873 Offline
mopar873  Offline
WI
I just parted with an '02 TransAm that was set up as a street/strip car. The car had a 9" with a 4.33 gear. With just a cammed LS1 it ran consistent 12.0s at 116mph with a T56 Magnum and a Spec clutch. I will tell you that to get the best shifts out of these, the investment in a Tick hydraulic cylinder kit is the only way to go. Prior to having one, trying to shift hard full throttle above 6200rpm or so was impossible. The clutch would either hang up or you would be locked out of gear. After the Tick MC upgrade, the clutch would disengage cleanly as high as i cared to rev it (usually around 6700 or so.)
As far as comparable shifting, I previously owned a 1970 Mach 1 with a Toploader, and have driven a Challenger with a 833. The toploader was the easiest to shift hard with the 833 being just slightly a bit more notchy. That being sad, BOTH are still easier than any T56 I've driven and I've been in 5 different cars with them in it.
As far as gearing with the extra overdrive, I ran 28" tires with a 4.33 gear. If given a chance to do it over again, I would've run AT LEAST a 4.56 to fine tune the trap rpm a bit better and still wouldve been putting along on the highway in 6th.
If you're going to drive the car alot, the T56 Mag is a great tranny but it's huge and expensive and needs a little work to make a crisp shifting machine. drive
