Page 2 of 6 1 2 3 4 5 6
Re: 771 horse stock stroke 360 motor, pump gas [Re: dizuster] #2554860
09/26/18 01:00 AM
09/26/18 01:00 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am the other member B3422W5 is talking about. Mine is a pump gas 394 ci that Brett Miller had in Enginemasters. It made peak power at 7300 rpm. I only shift at 6800. It has headers that I built on it and are probably holding it back. It made 662 hp on 91 octane gas. I have been beating on it for over 7 years.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 771 horse stock stroke 360 motor, pump gas [Re: HotRodDave] #2554983
09/26/18 12:25 PM
09/26/18 12:25 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Originally Posted By HotRodDave
I though the victors moved the shaft away from the valve so you needed a longer rocker on the valve side? Also a longer valve that further compunds the 59* lifter problem and add on top of that the offset? Pretty impressive it dont just cough the PR out under the intake when you crank it over...
There’s another thread going now with the Victors on a Ritter 59* block that they’re turning higher than 7500.
Re: 771 horse stock stroke 360 motor, pump gas [Re: fast68plymouth] #2554992
09/26/18 12:51 PM
09/26/18 12:51 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Pretty sure he had Jessle make him a set of custom rockers for that one. I’m sure all the info isn’t out there on this dyno Queen yet.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2554995
09/26/18 12:54 PM
09/26/18 12:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
Let’s just say I’d be pretty surprised to learn that the one in this thread is using some off the shelf ootb Harland Sharps.
Re: 771 horse stock stroke 360 motor, pump gas [Re: pittsburghracer] #2554999
09/26/18 01:00 PM
09/26/18 01:00 PM
Portage,michigan
B3422W5 Online content OP
B3422W5  Online Content OP
Portage,michigan
Indeed. All the info isnt out there on this motor yet. I shared as much as i felt should be shared about it. As i posted earlier, this motor has over 50 pulls on it already. Very trouble free thus far.
It wont remain a “ dyno queen” much longer. It will be for sale and in somebody's car at some point soon
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555004
09/26/18 01:08 PM
09/26/18 01:08 PM
PA.
"Little"John
"Little"John
PA.
Can’t wait to see some ET numbers
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 771 horse stock stroke 360 motor, pump gas [Re: WO23Coronet] #2555023
09/26/18 01:52 PM
09/26/18 01:52 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Originally Posted By WO23Coronet
I know there's formulas for this but is 770 hp possible at 7500 rpm with only 378"? I know that much hp is doable at the cu in for sure, I just thought it would be at a higher rpm, have to be some pretty stout volumetric efficiency.
125% @ 350 CFM will get you there
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555024
09/26/18 01:55 PM
09/26/18 01:55 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I'd like to see how close that 2.175 Intake valve is to the cylinder wall..
Re: 771 horse stock stroke 360 motor, pump gas [Re: ric3xrt] #2555036
09/26/18 02:25 PM
09/26/18 02:25 PM
Portage,michigan
Portage,michigan
His heads go 380+
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555040
09/26/18 02:34 PM
09/26/18 02:34 PM
Locomotion Offline
Locomotion  Offline
I'm curious to find out how the bottom end is put together to handle/support that HP.
Re: 771 horse stock stroke 360 motor, pump gas [Re: ric3xrt] #2555047
09/26/18 02:43 PM
09/26/18 02:43 PM
PA.
"Little"John
"Little"John
PA.
It’s a 3/4 concrete filled block bored to 4.100 so that helps I’m sure. I call BS on pump gas as I see 100 octane and sure it may have come out of a pump but come on now. I honestly hope it works out for them as this may get more Victor heads off the shelves and on some nice race cars.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 771 horse stock stroke 360 motor, pump gas [Re: Locomotion] #2555048
09/26/18 02:43 PM
09/26/18 02:43 PM
Portage,michigan
Portage,michigan
3/4 fill. He did use 4 bolt splayed caps. I asked him if those two outward splayed bolts had enough meat to attach to for viability. Because on a non magnum block they don't, at least that was my thinking
But he said on the Magnum block there is more meat there to make it worthwhile to use them.
I learned something. Didnt know the two blocks were different in that spot.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555065
09/26/18 03:25 PM
09/26/18 03:25 PM
Portage,michigan
Portage,michigan
Just talked to Jack..... little more info he doesnt mind me sharing.
Bullet cam. He consulted with Tony at BES regards it. One of Tony’s former guys, John Lohone( sp) now works for Jack and will make the trip down with him. One time Nascar engine builder
He said the valves clear with a ton of room. Very well centered in the bore, a big positive for the heads. Said they would clear a stock bore
That Holley manifold was indeed only made for W2. He has about 40 hours converting it from oval to square. Tons of work involved there. I had thought they must have offered it in a standard head form at one time, but just W2
Using cyro treated Hughes rockers. Really likes them.
Told me he made a plate for the front of the timimg cover where he can pop off the water pump and move cam in not much more than ten minutes. Said the motor is ultra sensitive to cam timing. Currently has it advanced 4 degrees, makes 750 this way but good bit more torque. Couple degrees can make or take 20 horsepower
Is likely to move it around down in Charlotte.
Said it will break 800 horse spinning it to 8k. Some very trick oiling mods. Had it on Bischoffs dyno recently and Tony told him it had the capability to win the competition. Was very impressed.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555066
09/26/18 03:30 PM
09/26/18 03:30 PM
P
Porter67 Offline
Porter67  Offline
P
Very impressive, I understand about some of the comp. engines mentioned now doing well in other rides, but I kinda think this might be pushing the envelope for longevity with a production block but then again over time it was said a oem block was only good to 500, then 500, then six.
Do you know what crank they are using?
I hope the best in the competition, do you know what some of the "Other" brand entries consist of?
I wonder how many sets of victor heads have sold? For so long it was "we cant get a good cylinder head" and now the price dont seem to be too bad.
Re: 771 horse stock stroke 360 motor, pump gas [Re: Locomotion] #2555067
09/26/18 03:34 PM
09/26/18 03:34 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
You and me both. I've had stock block, stock crank early LA 360s north of 500HP at 7500 and know what I had to do to keep it together for a season. And it still wanted to push the crank out of it. Add another 250? How short is the fuse on that?
Not busting on the builder. Just sayin', stock parts have there limits. I see they did use an aftermarket crank.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555071
09/26/18 03:47 PM
09/26/18 03:47 PM
Portage,michigan
Portage,michigan
Crank was destroked a little by Adney Brown down in Detroit. The guy who built the enginemasters 318 i bought and ran.
Adney owns Performance crankshaft
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: Porter67] #2555072
09/26/18 03:48 PM
09/26/18 03:48 PM
Portage,michigan
Portage,michigan
All 16 entries are listed on the website of the Race engine challenge website
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555078
09/26/18 03:55 PM
09/26/18 03:55 PM
Portage,michigan
Portage,michigan
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555085
09/26/18 04:17 PM
09/26/18 04:17 PM
The Great White North
RAMM Offline
RAMM  Offline
Impressive engine for sure. 800HP wow.
Should stick this on FABO just for the comments.
How is Randy doing with his Ford? J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555087
09/26/18 04:19 PM
09/26/18 04:19 PM
AndyF Offline
AndyF  Offline
I used to make a two piece cover for the SB engines. I stopped making them since there weren't very many SB guys building high dollar engines but it would make sense on a high buck engine like this.
