Re: just got home from the track, and...
[Re: max_maniac]
#2557261
10/01/18 09:39 PM
10/01/18 09:39 PM
dartman366
Mt. Vernon, Ohio
Around a 9.65. I would say closer to mid to upper 9.70's in my car, and definately in the 135.xx mph range,,I never even got to try out my new air pan, need to get to a TnT and not a regular event to play with it, cause I figure I am going to have to jet up just a little in the cooler weather. Don't under estimate your car Bill. In my 3480 POUND PIG when I ran 6.21 in the 1/8 I ran a 9.75 in the 1/4!! I say you are easily in the 9.6x range I would not be suprised that the 240's are running out of breath on the top end of the track as it is going across the stripe at around 6700
[Re: dartman366]
#2557481
10/02/18 10:45 AM
10/02/18 10:45 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Very nice! Congrats on the new best!
[Re: Thumperdart]
#2557986
10/02/18 10:25 PM
10/02/18 10:25 PM
dartman366
Mt. Vernon, Ohio
Good job............ For a comparison I went 6.15 at 112+ w/a crappy 1.40...........Still more there........ it appears the 8082 dommy is getting pretty well dialed in,, now to try the converted 3 circuit and see what it does.
[Re: dartman366]
#2557989
10/02/18 10:28 PM
10/02/18 10:28 PM
Posts: 20,206 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Good job............ For a comparison I went 6.15 at 112+ w/a crappy 1.40...........Still more there........ it appears the 8082 dommy is getting pretty well dialed in,, now to try the converted 3 circuit and see what it does. The Halloween Classic is coming up real soon.
[Re: dartman366]
#2558281
10/03/18 02:54 PM
10/03/18 02:54 PM
Posts: 19,403 Las Vegas
Al_Alguire
Las Vegas
Nice outing keep chipping away at it..
[Re: RustyM]
#2558599
10/03/18 10:08 PM
10/03/18 10:08 PM
dartman366
Mt. Vernon, Ohio
What rear end gears are you running as well s tranny- if you don't mind me ask" convertering? 4.56 dana 60, 727 trans with a CRT transbrake VB and 5400 stall Ultimate 8" converter
