Re: School me on an "H" wheel...
[Re: 64Post]
#544774
12/04/09 03:15 PM
12/04/09 03:15 PM
Posts: 20,733 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Pics, but no part numbers. I think the 70-71 cars came with a special steel wheel that has the same outer hoop as a rallye wheel. Not sure if those are supposed to have an H stamped into them???? I don't see a pic of them on that website. http://www.classicchambered.com/classic/wheels.html
[Re: Neil]
#544776
12/04/09 04:09 PM
12/04/09 04:09 PM
Posts: 221 Detroit Rock City!
silent-H-wheel
Detroit Rock City!
The H wheel that is the sought after one (for the A12 guys) is the 15 x 6 JJ. That 15 x 6 JJ will be stamped on the outer rim hoop where the tire will cover it. The tire must be removed to see it. It will also have a large H stamped in the flat between the lug holes at the eight o'clock position, when the wheel is placed with the valve stem hole at the 12 o'clock position. The 1969 H wheels don't have part number or pentastar stamped into them, but will have the manufacturer code, date, and 6.0 stamp near the valve stem hole - designating the 6 inch wheel width.
Chrysler had later 15 x 6.5 "H" wheels up through the mid 70s, but the H stamping is much smaller. These later wheels will have the Pentastar, part number, manufacturer code, and date code stamped near the valve stem hole.
Hope this helps.
John
2019 Jeep Grand Cherokee SRT 2018 Challenger SRT Demon
[Re: silent-H-wheel]
#544777
12/04/09 04:23 PM
12/04/09 04:23 PM
Posts: 2,304 WI
RestoRick
WI
#544778
12/04/09 04:39 PM
12/04/09 04:39 PM
Posts: 21,539 N.E. OHIO, USA
A12
N.E. OHIO, USA
Hope this helps.
also note the '69 H-wheels have 3- "dimpled" "nubs" for the hub cap, not 4 or 3 undimpled, and the valve stem is in alignment with one of the three nubs when at the 12-O'clock position and as mentioned the "H" stamped at the 8-O'clock position.
MikeR
[Re: A12]
#544779
12/04/09 05:01 PM
12/04/09 05:01 PM
silent-H-wheel
Detroit Rock City!
John
[Re: DoctorDiff]
#544782
12/05/09 06:13 PM
12/05/09 06:13 PM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
Early July 68 dated H wheels do not have the dimples. July wheel is the middle wheel in picture.
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
[Re: 808CUDA]
#544784
12/21/09 07:13 PM
12/21/09 07:13 PM
A12
N.E. OHIO, USA
What is the correct paint finish on 1969 1/2 A12 Road Runner wheel? Flat, semi or gloss black?
Gloss black IMO. I think the semi or satin finish comes from age.
MikeR
#2555614
09/27/18 05:28 PM
09/27/18 05:28 PM
Posts: 29,656 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
The H wheel that is the sought after one (for the A12 guys) is the 15 x 6 JJ. That 15 x 6 JJ will be stamped on the outer rim hoop where the tire will cover it. The tire must be removed to see it. Can anyone tell me if the number 870 is also stamped in this area?
