Re: Survey Please [Re: Cab_Burge] #2554834
09/25/18 11:00 PM
09/25/18 11:00 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By Cab_Burge
Most butt dyno are very misleading when it comes to all out performance shock The time slip is not up scope
This.
I bet there would not be more 0.05 sec. difference between the two at the track.
Re: Survey Please [Re: 72 RR DUDE] #2554881
09/26/18 12:53 AM
09/26/18 12:53 AM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
I can't give you advice on what gear to change to, but I'll give you this (apples to oranges) comparison (and I'm sure you have a car with OD too). My 2001 Dodge truck has 3:55's and an OD transmission, and it turns about 2.200 RPMs at 80 MPH. Spending your money is easy, but if overdrive is in the budget, check it out. I think you'd have all the performance you're looking for...
Re: Survey Please [Re: 72 RR DUDE] #2554962
09/26/18 10:35 AM
09/26/18 10:35 AM
Going to change the rear gears so do i go with 3:55 or 3:23 Opinions Please.
I dont have a real world ans/exp for that particular situation but just me for a start I would do some math & find the RPM differences that I would get with 3.23 & 3.55 changeout.
Re: Survey Please [Re: RapidRobert] #2555061
09/26/18 02:19 PM
09/26/18 02:19 PM
NE
moparpoolman Offline
NE
https://www.e-bodies.org/resources/rpm-speed-gear-tire-size-calculator/
cool calculator! looks like only a 271 rpm difference from 3.55's to 3.23's
