Re: Dyno guess 440 stroker - my A12 upgrade
[Re: GomangoCuda]
#2554106
09/24/18 03:32 PM
09/24/18 03:32 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Great results! I was surprised to see the size of the outboard main jets. Those are 10 sizes larger than what my 493 with similar sized cam & Indy EZ's likes according to my wideband. I do run the mechanical DC Holley's. I bet his are .089" and .091" holes in metering plates. That would be about the same as your jet sizes in metering blocks. Decades ago when I raced with the mechanical carbs at least 4 times a week I had three outer metering blocks with 78, 80,and 82 jets. I could swap them at the track a lot quicker than switching jets. Usually ran 78's and 80's on warm days and 80's and 82's on cold days. 64's or 65's in the center. I don't know if its the the nature of the 6 pack or just a coincidence, but no matter what I run it on, I'll start with 65 center and 80's outsides. Then when I'm all done I'm usually exactly what you describe, 64/65, and 77/82, and does not seem to matter much if its a 350 hp or 550 hp deal. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: BSB67]
#2554212
09/24/18 08:22 PM
09/24/18 08:22 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Great results! I was surprised to see the size of the outboard main jets. Those are 10 sizes larger than what my 493 with similar sized cam & Indy EZ's likes according to my wideband. I do run the mechanical DC Holley's. I bet his are .089" and .091" holes in metering plates. That would be about the same as your jet sizes in metering blocks. Decades ago when I raced with the mechanical carbs at least 4 times a week I had three outer metering blocks with 78, 80,and 82 jets. I could swap them at the track a lot quicker than switching jets. Usually ran 78's and 80's on warm days and 80's and 82's on cold days. 64's or 65's in the center. I don't know if its the the nature of the 6 pack or just a coincidence, but no matter what I run it on, I'll start with 65 center and 80's outsides. Then when I'm all done I'm usually exactly what you describe, 64/65, and 77/82, and does not seem to matter much if its a 350 hp or 550 hp deal. We had perfect air O89 and 91 resemble stock plates Started there .. 77/82 seems small ..
[Re: sogtx]
#2554350
09/25/18 03:20 AM
09/25/18 03:20 AM
Posts: 43,335 Bend,OR USA
Cab_Burge
My pump gas six pack 511 C.I. low deck stroker motor liked .094 fuel inlet size on the driver side outboard plates with .096 on the driver side of the Eddy aluminum dual plane six pack intake using a set of OEM 1970 440 California automatic carbs. modded by C&J Engr. in Whitter, CA I don't remember those List numbers now though ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) I had that motor on two different engine dynos and it made peak HP at either 5500 RPM or 5600 RPM with peak torque at 4500 or 4600 RPM . I tested three different sets of carbs on the first test session, That set of modified 1970 carbs., a new set of OEM 1971 440 replacement carbs ![down down](/ubbthreads/images/graemlins/custom/down.gif) and a set of the original mechanical carbs as well as several different air cleaner elements as well as stacking two elements on top of each other. That motor made the most HP and torque with the air cleaner base on and no air cleaner element with the mechanical carbs. There was only 7 HP differences between all three sets of carbs though
[Re: GomangoCuda]
#2554462
09/25/18 01:25 PM
09/25/18 01:25 PM
Posts: 3,289 West Coast, USA
jbc426
West Coast, USA
Great results! I was surprised to see the size of the outboard main jets. Those are 10 sizes larger than what my 493 with similar sized cam & Indy EZ's likes according to my wideband. I do run the mechanical DC Holley's. I bet his are .089" and .091" holes in metering plates. That would be about the same as your jet sizes in metering blocks. Decades ago when I raced with the mechanical carbs at least 4 times a week I had three outer metering blocks with 78, 80,and 82 jets. I could swap them at the track a lot quicker than switching jets. Usually ran 78's and 80's on warm days and 80's and 82's on cold days. 64's or 65's in the center. Wow, great info you guys! This was back in the day before the non-stick gaskets, nylon bowl washers and widebands too, right? The Holley jets are not super accurate either. Does anyone make blueprinted Holley jets that actually match the flow of the number stamped on them? I don't have a heat crossover in my Indy's, have insulating mat between the intake manifold and valley pan and run a Shaker hood. The carbs are still super sensitive to air temperature and heat soak. I can feel significant power loss as heat saturates the intake from heat soak. I wonder if the same power loss would occur with multi-point EFI?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: sogtx]
#2554831
09/25/18 11:59 PM
09/25/18 11:59 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
Do mind sharing the cam card? That’s a bad dude!
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 68 HEMI GTS]
#2554912
09/26/18 08:18 AM
09/26/18 08:18 AM
sogtx
upstate western ny
Do mind sharing the cam card? That’s a bad dude! No sense of hiding it Hopefully it can get some critique here But its tough to compare to a reg solid cam spec due to the roller part of it . I think - i dont know much about reading split cam cards and All of the logic behind it .. and ill effects of this and that .. I guess well just call it the FM cam. Dont know how , but it works .. lol. Hopeful its nice on street - it sure idles like my old bobk cam. I only got 10-12” of vacuum But i wasnt tuning for vacuum yet .. Hopeful i can get it higher with a couple screws . Some more tweaking coming I got an H pipe and factory manifolds mounted On Dyno last night .. Figures the h pipe was contorted Needed a bunch of fat guys and a bigass pipe to twist the collector flange into position .. But moving along Will be bad air tonight
[Re: sogtx]
#2554979
09/26/18 12:18 PM
09/26/18 12:18 PM
Posts: 91 sweden
carter
sweden
Why can I not see a cam card, just see a "empty frame"?
[Re: dannysbee]
#2555401
09/27/18 07:56 AM
09/27/18 07:56 AM
sogtx
upstate western ny
Some more tuning could have been had , but three jet Sizes later , two different sets of mufflers and .......... We jetted all the way down to 81/83’s and 64’s on center We lost about 90 hp .. from headers to manifolds And 2 1/2” exhaust with h pipe .. And ....... We gained torque and about 10 hp with big a12 air cleaner and kn air filter Since we have trickflows The car is gonna go together with headers It will not even try to appear stock And thats ok ..
[Re: sogtx]
#2555434
09/27/18 10:34 AM
09/27/18 10:34 AM
Posts: 5,160 Texas
dannysbee
Texas
Yes it's a trade off for certain. But 550-570 is nothing to sneeze at. Anything faster than a 11.50 requires a roll bar. I think a drive anywhere stock appearing automatic a12 with a 3.54 gear that would run 11.50's through the mufflers would be awesome.
Getting old just means you were smarter than some and luckier than others.
[Re: sogtx]
#2555469
09/27/18 11:34 AM
09/27/18 11:34 AM
fast68plymouth
So. Burlington, Vt.
Sounds like the headers are an extremely cost effective power upgrade on that combo. The engine did not like the ex manifolds at all They never do. Some just dislike them more than others. 650hp in a 4000lb car should be able to run 10.60’s at 124+.
[Re: sogtx]
#2555494
09/27/18 12:10 PM
09/27/18 12:10 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
That's awesome power from a relatively mild combination. I just picked up some Tricklow 240s myself so it's cool to see how much power they are capable of. Hard to not use headers when there is that much power left on the table without them...
2 kids and a dog
