Re: Replace 590 cam With Roller
[Re: 77DragracerR/T]
#2553045
09/21/18 09:05 PM
09/21/18 09:05 PM
Posts: 14,531 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Okay, so what was the motivation for the cam change?
Those cams are quite a bit different than each other.
Like I said earlier....... cut the oil filter open and see what’s inside. As much as your car slowed down, if it’s engine related...... it should show up in the filter.
I assume you checked the basic stuff...... timing hasn’t moved.....still getting full throttle, etc.
I’d do a compression and leak down test as well, and if it all looks good..... time to pull the trans pan.
#2553058
09/21/18 09:45 PM
09/21/18 09:45 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
Dont forget to check battery and alt. Bad battery can kill ET I found that out a few years years back
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
