Page 54 of 159 1 2 52 53 54 55 56 158 159
Re: Paint job on a budget!? CONTINUED..page 44........ #25518
08/13/06 02:58 PM
08/13/06 02:58 PM
last pic... that's my lil brother in the background
That car don't look bad at all.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Marq] #25519
08/13/06 03:44 PM
08/13/06 03:44 PM
So... what type of latex gloves were they ?
wow...those are some fine analytical skills you have there
I'm using the cheap medical type latex gloves because I thought mineral spirits dry out your hands. I guess I will man up and go bare hands for the test.
Re: Paint job on a budget!? CONTINUED..page 44........ #25520
08/13/06 06:40 PM
08/13/06 06:40 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Mineral spirits haven't dried up my hands, and I've even been washing them with mineral spirits when I get any paint on my hands.
and to TZ- that looks great. Spraying this paint seems to work real well in terms of gloss and hardness.
Re: Paint job on a budget!? CONTINUED..page 44........ #25521
08/13/06 09:28 PM
08/13/06 09:28 PM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
.. so we borrowed an HVLP spray gun and shot the rest of the paint. We sprayed two coats on the car outside and rolled the car in the garage after we finished spraying. the paint is rustoleum professional Royal blue and gloss white. I polished out the paint with a rotary buffer and a 3M hookit foam pad using the turtle wax polish suggested by 69charger. I'll let the pictures speak for themselves, but I will add that the color is a lot darker in person than it appears in the pics.
It would be great if you had any 'before' shots to give us an idea of what the car started like... was it simply a uniformly dull original paint job or was the car all primered up etc...
The pics look great... but it is like that television show the swan... where you see the ugly chick transformed into 'the hot chick'... We can see the car turned out 'hot'... and now it would be nice to know where things started from...
Re: Paint job on a budget!? CONTINUED..page 44........ #25522
08/13/06 09:40 PM
08/13/06 09:40 PM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
It's elementary my dear Watson. You simply apply Murphy's Law to any thing that might go wrong and back track to the least suspicious suspect. It was a case of trying to figure out if the gloves had some small role to play in that defect or if your neighbors dog had stupidly licked away at the paint while you were off preparing another batch of paint ( check his tongue color just in case or that it is still alive ).
I'm using the cheap medical type latex gloves because I thought mineral spirits dry out your hands. I guess I will man up and go bare hands for the test. :
Yeah... you only have to worry about cancer and having deformed children with three heads if you swim in the stuff
It's no big deal to temporarily expose yourself to the mineral spirits or wiping yourself down after a painting session to remove any paint. The exposure is only short term and this project is short term. It would be a different story if you worked in a 'el cheapo' paint shop and had to expose yourself to contact with mineral spirits five days a week... fifty weeks of the year for the rest of your working career. Heck the 'fumes' in the air would probably blow out your lungs long before your skin starts growing cancerous warts.
My only embarassment during the painting stage was wearing open toed sandals. I have the 'loveliest' Fire Red toe nails in town. Which does nothing for ones macho ego...
Ah the joys of painting at home....
Re: Paint job on a budget!? CONTINUED..page 44........ #25523
08/14/06 01:13 AM
08/14/06 01:13 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I always use the medical type. I wipe down with laquer thinner though and it eats the gloves up pretty quick. One thing to keep in mind is that most of these gloves come with some type of a powder on them. I always change out my gloves after wipe down and before painting.
It has been a while since I checked in on this tread. I will have to stop by more often. I have been in such a crunch lately trying to make the October show, that I completely forgot about it LOL.
You folks are doing a great job with it. I see so many pictures have been added it is hard to keep track of who is doing which car LOL.
Exit, your machine is looking great. There is no secret to getting great results. Surface prep, and learning how to wet sand and polish. Once you have those down, the results will follow.
For those still wet sanding, I buy my 1000, and 2000 grit at wal mart in the automotive section. It is pre cut to just the right size for the hard rubber sanding blocks. It is 3M imperial wetordry. The number on the 2000 grit pack is 03003NA. I only use a sponge on round surfaces. The hard rubber block is the only way to go on flat surfaces. Also always go in straight lines in a criss cross pattern. Use dishwashing soap in your water. It will help keep the block moving freely. I also keep a spray bottle handy with some soapy water in it as well.
Good Luck folks and keep working on it.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Marq] #25524
08/14/06 01:19 AM
08/14/06 01:19 AM
Ontario, Canada
78D150CLUB Offline
My avatar is a self portrait!!
78D150CLUB  Offline
Ontario, Canada
I didn't go for the toenail look, but I had some lovely green sparkle fingernails till about last Tuesday. BTW, did you polish and wax the toenails, or just go with the two coats of Brightside? I do agree with you on the joys of home painting. LOL
On a more serious note, just a few more trim bits and the bumpers to mount, and Godzilla is back to wreaking havoc on Ontario roads
I gave up on water for the wet sanding, I just constantly on the paper. The paint does have some flaws in spots, but I'm out of time for now, and the change is so amazing, I'm just going to leave well enough alone for now. I'll go back over it again, and really smooth things out when I locate some new and improved body parts.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 78D150CLUB] #25525
08/14/06 09:54 AM
08/14/06 09:54 AM
hi all from australia
i had to join up after seeing you guys produce some AMAZING stuff on a helluva budget.
im sold. although, i want to paint my car (Holden HG Premier) satin black, and depending how thrilled i am afterwards, i might think about adding some gloss black flames or stripes or something.
so i was wondering, is it worth getting the tremclad (tremco over here) in matte/satin black and using the roller technique, or doing something else?
also, if i were to add some form of gloss black ornament later one, could i just lay a coat of gloss straight over the satin, or whould i have to rough it up a bit first?
again, GREAT STUFF from all you guys, and charger for giving us budget-stricken guys this valuable info, and exit for being so patient with his experiments. keep it up!
p.s. 71 pages is alot of reading.
Man! Glad you didn't end up with Tar Heel blue! #25526
08/14/06 03:37 PM
08/14/06 03:37 PM
Very nice job!
Re: Paint job on a budget!? CONTINUED..page 44........ #25527
08/14/06 05:54 PM
08/14/06 05:54 PM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
I will give the answer for the Brightside marine paint.... Interlux ( the company that sells / makes Brightside ) also sells an 'additive' that can be added to any of the 'glossy-shiny' paints to make them 'flat and satin like'.
Since Interlux is a global company - you would be able to hunt down the Brightside marine polyurathane paints somewhere near you in Australia.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Marq] #25528
08/14/06 06:04 PM
08/14/06 06:04 PM
I agree, it would have been great if I had felt like taking progress shots along the way but really my attempt at this is pretty much par for the course as far as results. I do have two decent shots of the car before we started painting.
I will say that taping the car to spray this paint is more time consuming than the roller, but I gave both techniques a shot and ill have to say that though the roller produces an equal finish, my time is pretty valuable and I will probably spray the paint and only have to wetsand once. When I paint my mother's Neon this winter I'll be sure to take more pictures and keep you guys posted.
Feel free to ask any questions about the process as I have learned a few "what not to do tips" about painting this way.
Anyway here is a before shot.
Cheers,
Trent
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Marq] #25529
08/14/06 06:28 PM
08/14/06 06:28 PM
The car was like most of the Camaros in our area. Dull paint, faded basecoat, cracked clear coat, painted twice, dents, dings, cracked bumpers (I love plastic cars).
This is a head on shot of the ugly chick before the new paint unfortunatly I only have these two before pics.
She was a whole lot prettier than my first ride (an 83 escort wagon).
Happy rolling (Or spraying),
Trent
Re: Paint job on a budget!? CONTINUED..page 44........ #25530
08/15/06 12:51 AM
08/15/06 12:51 AM
progress on mine.
first two coats on and dry. Very hard paint, can't even scratch it. Will wetsand tomorrow night
this pic is after the first coat
Re: Paint job on a budget!? CONTINUED..page 44........ #25531
08/15/06 12:52 AM
08/15/06 12:52 AM
close up at trunklid
Re: Paint job on a budget!? CONTINUED..page 44........ #25532
08/15/06 12:54 AM
08/15/06 12:54 AM
seccond coat, applied and dry
Re: Paint job on a budget!? CONTINUED..page 44........ #25533
08/15/06 06:09 AM
08/15/06 06:09 AM
If you want to paint your car satin black then you could also use Tremco Metal Armour Gloss Black, and leave it out in the rain for a few weeks to get the 'satin' appearance.....
From this
to this,
just add rain....
Re: Paint job on a budget!? CONTINUED..page 44........ #25534
08/15/06 01:00 PM
08/15/06 01:00 PM
Steve (Aussie-MX5),
Have you tried re-buffing? I'm curious to know why the paint went flat on you in such a short period of time? I've had my Rustoleum painted mower out in the rain and sun for about 3 months already and other than looking like it needs a bath, the paint finish looks fine.
Re: Paint job on a budget!? CONTINUED..page 44........ #25535
08/15/06 01:06 PM
08/15/06 01:06 PM
Well this is my first post. After buying a 2006 Charger R/T with R/T package, I saw this thread. Great timing since I am restoring a 1970 Porsche and don't want to spend the $$$ on a .... yada yada yada...
I have smoothed out and primed the car; now ready for rollin.
I have purchased Blue Marine 1 Part Poly urethane in Black online. One gallon with one quart of brushing liquid/solvent delivered to my door for $80 total-not bad. has the same qualities as the Brightside. see it here:
Blue Water Marine
Ordered the rollers and handles from here:
Ebay Item: 130006642627
Roller frame plus 10 foam rollers for 9 bucks-beat that!
My plan is to do the first coat with 5% thinned this weekend and let it sit for a week. Then block wetsand with 400, then with 800. Do coat 2 at 5% thinned, wetsand with 1000, coat 3 full strength, wetsand with 1500, 2000, 3000 Then polish.
Hope it all works out. Thanks to all here for the research, time and dedication for us CSOBs!
Re: Paint job on a budget!? CONTINUED..page 44........ #25536
08/15/06 01:06 PM
08/15/06 01:06 PM
nuther
Re: Paint job on a budget!? CONTINUED..page 44........ #25537
08/15/06 02:00 PM
08/15/06 02:00 PM
here's a dumb question.
i guess i should've thought of asking this before reading the thread for like 4 hours lol.
um....my car is metal i think.
can you only use the marine and rust/trem stuff on fiberglass???
i have a 1990 honda accord that i'd like to do myself now, preferabbly with the marine paint.
thanks guys.
