Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2553045
09/21/18 09:05 PM
09/21/18 09:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Okay, so what was the motivation for the cam change?
Those cams are quite a bit different than each other.
Like I said earlier....... cut the oil filter open and see what’s inside.
As much as your car slowed down, if it’s engine related...... it should show up in the filter.
I assume you checked the basic stuff...... timing hasn’t moved.....still getting full throttle, etc.
I’d do a compression and leak down test as well, and if it all looks good..... time to pull the trans pan.
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2553058
09/21/18 09:45 PM
09/21/18 09:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Dont forget to check battery and alt.
Bad battery can kill ET
I found that out a few years years back
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
