Re: RacePak user??? [Re: SCDaytona] #2551064
09/17/18 02:12 PM
09/17/18 02:12 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Originally Posted By SCDaytona
Just sent mine in for backlight issue and I was told $60 plus shipping. Should be back this week.
For that I would consider it. I kinda like to tinker so not sure which way I will go. Kinda hate paying twice
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: RacePak user??? [Re: JERICOGTX] #2551125
09/17/18 04:38 PM
09/17/18 04:38 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
On one car V500
oil temp
oil pressure
water temp
fuel pressure high
fuel pressure carb
fuel pressure nitrous X2
trans temp
trans pressure
voltage
crank case vac
DS speed
front and rear shock position/ and velocity
8 channel AF
8 EGT
nitrous pressure
G's
grid
another car, D logger dash
oil pressure
water temp
trans temp
trans pressure
voltage
fuel pressure carb
1 channel AF
DS speed
rear shock position/velocity
nitrous pressure
crank case vac
G's
grid
Re: RacePak user??? [Re: pittsburghracer] #2551198
09/17/18 06:54 PM
09/17/18 06:54 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
I was just called and it is confirmed. $65 to repair. Having it sent back 2nd day for $20. They received it Wednesday of last week.
Re: RacePak user??? [Re: SCDaytona] #2551207
09/17/18 07:06 PM
09/17/18 07:06 PM
PA.
"Little"John
"Little"John
PA.
Here’s another issue I ran into once. I raced in the No Box Bonaza at Norwalk a few years ago and if you closely read the rules it says no data recorders. When I told him my RacePak dash was hooked to my data recorder it was needed to see my oil pressure, water temps, and other required info. He said I could not run the race. After some more calls I was told to remove the sd card and put a wire tie around it that could be inspected at any time. Gauges for me for now on.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: RacePak user??? [Re: SCDaytona] #2551209
09/17/18 07:08 PM
09/17/18 07:08 PM
PA.
"Little"John
"Little"John
PA.
Oh and I won’t pay them 85.00 to repair their junk. It should have been covered for the period I had it. I’ll fix it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: RacePak user??? [Re: pittsburghracer] #2551246
09/17/18 08:36 PM
09/17/18 08:36 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
That rule kept me from using a Racepak. New for 2018 data recorders are now legal in Pro et.
copied from et section
COMPUTER
Prohibited. See General Regulations 9:1.
DATA RECORDER
Data recorders are permitted in Advanced E.T., Super Pro,
and Pro only. Data recorders (except for “playback”-type
tachometers) are prohibited in all other E.T. classes. See General
Regulations 9:2.
"Just a Bracket car dressed up like a streetcar"
Re: RacePak user??? [Re: JERICOGTX] #2551252
09/17/18 08:54 PM
09/17/18 08:54 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The data will spoil ya quick.
There are so many small things you'll find to hone in on.
I spent a lot of time working on stabilizing my fuel pressures. I went from 30 pounds on the high side, down to 18 high. To get there, I had to drill out the bypass, change springs, change return lines ect. End result is carb, and nitrous pressures that vary less than .25 pounds from line to stripe
Trying to get the car to go dead straight is another g meter function you can play with forever lol. I need to install steering input sensor so I can id the culprit in my mid track wanderings.
Being able to tie the Grid into the racepak is fantastic. I found a faulty WOT switch from the connection. I had this fluctuation going on, that was the switch dropping out for just a split second. When I laid the step retard on the graph I saw the trouble. Could have chased that for a while without the data.
Re: RacePak user??? [Re: JERICOGTX] #2551556
09/18/18 03:57 PM
09/18/18 03:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO it depends on your goals and what you are trying to accomplish. For the bracket guy Oil press, fuel press, trans temp, water temp and vacuum would be all I would be concerned with. It comes with the G meters and voltage and driveshaft RPM. IMO driveshaft ROM and G meter will tell you a TON about how the car is working. Many people overlook the G meter and wheelspeed early in the run, it is the difference between and great running car and an average running one. As for engine vitals, engine vacuum will be your best friend here as far as ring seal and overall engine health. Oil pressure is nice the rest just seem to be stuff people want to see.
As for me I have a ton, never a thing as to much info...
Re: RacePak user??? [Re: JERICOGTX] #2564614
10/15/18 10:09 PM
10/15/18 10:09 PM
MN
JERICOGTX Offline OP
MN
For those running a Dana 60, how did you mount your drive shaft sensor?
69 GTX 68 Road Runner
Re: RacePak user??? [Re: JERICOGTX] #2564650
10/15/18 11:30 PM
10/15/18 11:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I mounted mine to read the wheel studs, I am not sure if the racepak can give readings for this but my EFI can. Its just OK I liked it better when I had a sensor on the yoke with my 8.75 and I will be trying to do this for my Dana in the future.
My moser yoke for my 8.75 had a provision for a sensor ring, the moser yoke for my Dana did not, that is what you get for assuming lol.
68 Barracuda Formula S 340
Re: RacePak user??? [Re: JERICOGTX] #2564707
10/16/18 01:54 AM
10/16/18 01:54 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I put the tone ring on my output shaft and drilled and tapped a hole in the tail shaft. Can swap between my 727 and 904. Not sure if you can do that on a manual trans.... but it’s an idea you can look into
Re: RacePak user??? [Re: Bad340fish] #2564739
10/16/18 09:02 AM
10/16/18 09:02 AM
MN
MN
I have a Mark Williams yoke on my Dana 60 right now, but it doesn't have room for a ring. The Strange Billet yoke does, and I'll be going with one of those. Wonder if drilling and tapping a couple 1/4-20 holes in the case would be OK?
Re: RacePak user??? [Re: JERICOGTX] #2564744
10/16/18 09:52 AM
10/16/18 09:52 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I can't remember if there is room to do something like this on the Dana. I really want to change, haven't been real happy with the wheel stud reading because it has a blip in it likely from one of the studs being farther away than the others. The moser 5/8 studs aren't real consistent on the back side.
This is the motion race works kit for a ford 8.8
