Page 2 of 3 1 2 3
Re: New S60 for the Coronet [Re: AndyF] #2534927
08/12/18 03:21 AM
08/12/18 03:21 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Very Cool Andy! I love my Strange S60 3.73 gears Detroit Locker.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: New S60 for the Coronet [Re: mopardude318] #2536928
08/15/18 10:33 PM
08/15/18 10:33 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The brake line routing is pretty on that one Mopardude but I prefer to run my brake lines on the body so I can just hang the calipers when I need to pull the rear. That way I never need to open the brake system to make chassis changes twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: New S60 for the Coronet [Re: AndyF] #2550519
09/16/18 02:22 AM
09/16/18 02:22 AM
AndyF Online content OP
AndyF  Online Content OP
Got the old Dana 60 pulled out and the new S60 installed. Weather was nice so I took it out for a drive today. The new rear end is nice and quiet, the S-Trac seems to work just fine. It doesn't make any noise going around corners but tightens up when I jump on it. The 3.23 gears seem like a good match for my engine and transmission. I had to shift out of first fairly quickly with the 3.54 gears but the 3.23 lets me extend that just a bit more. The rear discs aren't bedded in yet so stopping power isn't up to par yet. That will just take a little bit of time to get the brakes dialed in.
Re: New S60 for the Coronet [Re: AndyF] #2550528
09/16/18 03:39 AM
09/16/18 03:39 AM
Rittman Ohio
Rittman Ohio
Looks good Andy that 3.23 should work perfect with the super low gear in the 5-speed. Mine has a 3.27 low gear and I had 4.56 gears in the rear when I first installed it. I never did the math but I was shifting right after the tree. If Cass ends up making a run of the 3.23 gears I'm sure he will sell all of them.
Gus beer
64 Plymouth Savoy
Dana 60
Re: New S60 for the Coronet [Re: AndyF] #2550532
09/16/18 04:12 AM
09/16/18 04:12 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Looks nice Andy please keep us posted on the gears too
Re: New S60 for the Coronet [Re: fourgearsavoy] #2550612
09/16/18 01:34 PM
09/16/18 01:34 PM
4.56 with a 3.27 first gear is a 15:1 starting line ratio! That is the same as running a 5.60 rear gear with a standard 2.66 first gear.
The 3.23 rear gear seems to be a very good match for the Doug Nash 5 speed box. It is still a 10.56 starting line ratio which is the same as having a 3.97 rear gear with a 2.66 first gear. So it comes out of the hole just like a normal four speed car would with 4.0 gears, but then I have 3.23 gears when I shift into 5th out on the freeway. My rear tires are 28 inch diameter so it rolls pretty well down the freeway.
Re: New S60 for the Coronet [Re: AndyF] #2551542
09/18/18 03:11 PM
09/18/18 03:11 PM
Gilroy,CA.
Gilroy,CA.
Looks excellent Andy!
Re: New S60 for the Coronet [Re: AndyF] #2551600
09/18/18 05:43 PM
09/18/18 05:43 PM
Queensland Australia
moparmacka Offline
moparmacka  Offline
I hope you Devcon the plug weld holes from tubes to the housing. Mine developed an oil leak sitting in the crate. And figured it was a pinion oil seal. Nope, further investigation revealed all 8 plug welds had developed crater cracks from different cooling times from the differing materials. Tried re welding......unsuccessful. Filled them with Devcon, smoothed them over and never looked back. Another couple of guys over here have experienced the same thing with their S60 housings. Awesome product and great service though.
Re: New S60 for the Coronet [Re: AndyF] #2551611
09/18/18 06:36 PM
09/18/18 06:36 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Side adjusters in a dana is just the best thing ever.
Re: New S60 for the Coronet [Re: dthemi] #2552084
09/19/18 09:55 PM
09/19/18 09:55 PM
Rittman Ohio
Rittman Ohio
You aren't kidding the last 2 gear sets I done are the old factory deal. Not bad with a spool but that Powerlock is freakin heavy changing shims. I haven't had the opportunity to change gears on the new S60. I should trade my 68 housing in on a Strange S60 work Maybe with a set of 3.23 gears.
Gus beer
64 Plymouth Savoy
Dana 60
Re: New S60 for the Coronet [Re: AndyF] #2553806
09/23/18 08:09 PM
09/23/18 08:09 PM
I've been driving the car whenever the weather is decent and the new 3.23 gears seem to work just fine. No noise that I can hear. The car goes down the road nice but still has move than enough juice to spin the tires at will.
I screwed the prop valve all the way in (max rear brake force) and that helped with the brakes but it still isn't perfect. I think I'll need to swap in a MC with a smaller bore size to get the line pressure up to work with the four wheel disc brakes.
Re: New S60 for the Coronet [Re: AndyF] #3002704
01/06/22 08:21 PM
01/06/22 08:21 PM
So cal
E
EFI DART Offline
EFI DART  Offline
E
So cal
Gday Andy,
I love your book on Wedge engines
I am building a 68' Dodge dart with all Mopar running gear this time, last time it was on the road it had a Furd 9"
With the persuasion of a local buddy he's convinced mem into building a Dana S60 with all the fruit.
I seem to be having contact pattern issues where there appears to be too much contact on the heel & toe of of the ring gear set
If i shim out the pinion bearing it becomes too deep
If u reduce it becomes too shallow (see pics).....
unlike all other gears i have set up this will not give me a perfect oval shape in the centre of the drive side.
From what i can tell the gear sets are not ground as well as a Dana Spicer.
Cass Esslicks "Dr Diff" 3.23 gear set and
Any input is greatly appreciated
Moparaaaaaaars
Re: New S60 for the Coronet [Re: @#$%&*!] #3002740
01/06/22 09:54 PM
01/06/22 09:54 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
That's a nice piece. up
"Any fool can know. The point is to understand"
- A. Einstein
Re: New S60 for the Coronet [Re: EFI DART] #3018454
02/24/22 12:51 PM
02/24/22 12:51 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The pinion is too far away. I would try a 0.005" thicker pinion depth shim and run another contact pattern.
Re: New S60 for the Coronet [Re: DoctorDiff] #3104837
12/23/22 11:22 AM
12/23/22 11:22 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Any update on the 3.23 gears?
Kevin
Re: New S60 for the Coronet [Re: Twostick] #3104865
12/23/22 12:48 PM
12/23/22 12:48 PM
I've been driving the car for four years now. No noise or any problems with the 3.23 gears.
Re: New S60 for the Coronet [Re: AndyF] #3105078
12/23/22 10:53 PM
12/23/22 10:53 PM
Rittman Ohio
Rittman Ohio
Good to know as I have a set going into my Dana this winter, That is unless I put a 9" back under it whistling
Gus beer
64 Plymouth Savoy
Dana 60
Re: New S60 for the Coronet [Re: AndyF] #3105187
12/24/22 12:10 PM
12/24/22 12:10 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Are they in production? I don't see them on Dr Diff's site.
Kevin
Re: New S60 for the Coronet [Re: Twostick] #3105285
12/24/22 05:05 PM
12/24/22 05:05 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The first production run of 3.23 Dana 60 gears is sold out, but I have 200 sets on order. They should be back in stock this spring.
Re: New S60 for the Coronet [Re: Twostick] #3105312
12/24/22 06:53 PM
12/24/22 06:53 PM
Kevin
Have you thought of changing the rear tires to a taller set like 6 or more inches in circumference (2 to 4 inches taller)? If not, maybe you look into that twocents
Page 2 of 3 1 2 3
