6.1 45* oil filter adapter #2550280
09/15/18 12:54 PM
09/15/18 12:54 PM
Charleston SC
Fishstix Offline OP
Fishstix  Offline OP
Charleston SC
Anyone here don’t this? Trying to not hurt anything. The original mount has a threaded tube that the oil filter screws on, it that just threaded into the block? The 5.7 and 6.4 have a hex head I believe.
Figured I would see if anyone here has done this before I did anything stupid like throw some vice grips on it.......
Jason
Re: 6.1 45* oil filter adapter [Re: Fishstix] #2550298
09/15/18 01:41 PM
09/15/18 01:41 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
The nipple the oil filter screws onto is just threaded into the block. It does have to come out to install the factory oil filter adapter. Whatever you use to take it out, vise grips or the like, make sure they are in good working order. That threaded nipple is really in there. I used my Knipex Cobra (or Alligator) Pliers to remove it. They have an amazing bite though...
SuperBeast
An enforcer for the Mopar Mafia!
Re: 6.1 45* oil filter adapter [Re: Fishstix] #2550301
09/15/18 01:45 PM
09/15/18 01:45 PM
Charleston SC
Fishstix Offline OP
Fishstix  Offline OP
Charleston SC
Sycboi,
Thanks much. I figured that was the case. I have some great channel locks, but I will look at those alligator pliers since you had success with them. I wrapped a rag around the nipple, and gave it a half ass try just to see if it would move. Not a chance.
Jason
Re: 6.1 45* oil filter adapter [Re: Fishstix] #2550336
09/15/18 03:48 PM
09/15/18 03:48 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Actually I have the Knipex Cobra Pliers. The only difference is the adjustment part of them. Either will work though. As far as the rag around the threaded nipple to protect it, good luck with that. Just bite directly into the nipple itself. If you ever need a new one they are available readily for around $10. The one in there is most likely never coming out unscathed...
SuperBeast
Re: 6.1 45* oil filter adapter [Re: Fishstix] #2550381
09/15/18 06:34 PM
09/15/18 06:34 PM
Charleston SC
Fishstix Offline OP
Fishstix  Offline OP
Charleston SC
Good vice grips and I was victorious.
Re: 6.1 45* oil filter adapter [Re: Fishstix] #2550407
09/15/18 07:43 PM
09/15/18 07:43 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Excellent man. Progress!
SuperBeast
Re: 6.1 45* oil filter adapter [Re: sycboi] #2552604
09/20/18 11:30 PM
09/20/18 11:30 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
The nipple is loctited from the factory. Heat it up with a small propane torch and use the CORRECT SIZE allen wrench and it will come out and be re useable.
Re: 6.1 45* oil filter adapter [Re: Fishstix] #2552705
09/21/18 08:08 AM
09/21/18 08:08 AM
Charleston SC
Fishstix Offline OP
Fishstix  Offline OP
Charleston SC
6.1 hemis do not have the hex head. 5.7 and 6.4 do to the best of my knowledge.
Re: 6.1 45* oil filter adapter [Re: Fishstix] #2552840
09/21/18 01:45 PM
09/21/18 01:45 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
5.7 Hemis don’t either, at least none that I’ve ever seen...
SuperBeast
Re: 6.1 45* oil filter adapter [Re: Fishstix] #2552992
09/21/18 06:45 PM
09/21/18 06:45 PM
Charleston SC
Fishstix Offline OP
Fishstix  Offline OP
Charleston SC
The instructions on the adapter I bought stated 5.7 and 6.4 s have a 12mm hex head. Might be broken down by year.
Re: 6.1 45* oil filter adapter [Re: Fishstix] #2553157
09/22/18 02:19 AM
09/22/18 02:19 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Both the 5.7’s I removed them from were pre-vvt engines. Maybe that’s the difference...
SuperBeast
Re: 6.1 45* oil filter adapter [Re: Fishstix] #2553261
09/22/18 03:23 PM
09/22/18 03:23 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
03-08 5.7 have the same pipe as the 6.1's the VVT 5.7s and 6.4s have the New pipe with the hex head.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
