Re: Update; low oil pressure problems. [Re: gregsdart] #2550056
09/14/18 06:34 PM
09/14/18 06:34 PM
gregsdart Offline OP
Thanks again for all the input. When this motor comes apart, there will be a lot of checking to do for sure. I do pull the dipstick and inspect for "glitter" often!
On the oil feed hole in the bushings they are perpendicular to the oil galley and down about one inch, if i recall correctly. I drilled them after they were installed in the block.
Re: Update; low oil pressure problems. [Re: polyspheric] #2550059
09/14/18 06:41 PM
09/14/18 06:41 PM
Originally Posted By polyspheric
I guess the Hippocratic oath doesn't apply to lifter manufacturers.
You know, the one that say "above all, do no harm".
In this case, it would mean "until you KNOW it can't wreck anything, don't sell it".
And if you get caught with your pants down like the failed gasket in the Milodon oil filter adapter plate, lie yer [censored] off! "What? We've NEVER had a failure there!"
Mine blew out in the traps at 150 mph. A real "fun" memory!
Re: Update; low oil pressure problems. [Re: gregsdart] #2550061
09/14/18 06:43 PM
09/14/18 06:43 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Greg, do you have a pic of your lifters that shows the pushrod oil feed holes?
Re: Update; low oil pressure problems. [Re: fast68plymouth] #2550123
09/14/18 10:34 PM
09/14/18 10:34 PM
Unfortunately, no. But they are the Isky EZ roll bushed lifters.i don't remember the oil holes being in line with my bushing holes, as that was a concern when i put them in.
Re: Update; low oil pressure problems. [Re: gregsdart] #2550132
09/14/18 11:01 PM
09/14/18 11:01 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
One of my Isky bushed Red Zones. As I remember the feed hole goes straight thru from the other side as well. It is inline with the bushing feed in my motor.
Doug
Re: Update; low oil pressure problems. [Re: gregsdart] #2550140
09/14/18 11:31 PM
09/14/18 11:31 PM
So. Burlington, Vt.
So. Burlington, Vt.
Doug’s oil holes are like the Comp 892’s, and with the cam I had in that 572, the holes that were in the bushings with the block as delivered from Bill Mitchell, they lined right up with each other when the lifter was on the base circle of the cam.
And that will get you some serious oil flow to the top end of the motor.
Fundamentally, that oil hole placement is for a Chevy running .904 lifters.
Re: Update; low oil pressure problems. [Re: fast68plymouth] #2550157
09/15/18 12:26 AM
09/15/18 12:26 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
it shot oil out of the top of the Jesel adjuster screws about 15 feet across the shop.
I saw that and the thought that popped into my head was, “well........ I guess that’s not going to work”.
wink
I enjoyed that, thanks laugh2
Rich H.
Esse Quam Videri
Re: Update; low oil pressure problems. [Re: gregsdart] #2550175
09/15/18 01:54 AM
09/15/18 01:54 AM
So, with the distinct posibility that the holes line up in my motor, any ideas on how to restrict flow?
Re: Update; low oil pressure problems. [Re: gregsdart] #2550231
09/15/18 10:25 AM
09/15/18 10:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I had my Comp tappets restricted. The feed holes in the lifter were plugged. The side opposite the bushing feed was drilled .040". The problem was we used epoxy. Eventually the epoxy worked loose and slid back and forth in the feeds on some of the lifters. Never hurt anything. I think pressing a brass rod in there and then drilling might work. The funny thing is mine has huge clearance compared to yours, but has good oil pressure. Same lifters, block. maybe your lifter bushings are shorter uncovering a passage?
Doug
Re: Update; low oil pressure problems. [Re: dvw] #2550274
09/15/18 12:36 PM
09/15/18 12:36 PM
Shelby Twp. Mi
HardcoreB Online content
HardcoreB  Online Content
Shelby Twp. Mi
Greg I bumped an old post about lifters that may offer good info.
Re: Update; low oil pressure problems. [Re: gregsdart] #2550653
09/16/18 03:57 PM
09/16/18 03:57 PM
Thanks hardcoreb and DVW! Again, all this info is great. Lots to look at!
