Re: Update; low oil pressure problems.
[Re: gregsdart]
#2550056
09/14/18 06:34 PM
09/14/18 06:34 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Thanks again for all the input. When this motor comes apart, there will be a lot of checking to do for sure. I do pull the dipstick and inspect for "glitter" often! On the oil feed hole in the bushings they are perpendicular to the oil galley and down about one inch, if i recall correctly. I drilled them after they were installed in the block.
[Re: polyspheric]
#2550059
09/14/18 06:41 PM
09/14/18 06:41 PM
gregsdart
I guess the Hippocratic oath doesn't apply to lifter manufacturers. You know, the one that say "above all, do no harm". In this case, it would mean "until you KNOW it can't wreck anything, don't sell it". And if you get caught with your pants down like the failed gasket in the Milodon oil filter adapter plate, lie yer [censored] off! "What? We've NEVER had a failure there!" Mine blew out in the traps at 150 mph. A real "fun" memory!
[Re: gregsdart]
#2550061
09/14/18 06:43 PM
09/14/18 06:43 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Greg, do you have a pic of your lifters that shows the pushrod oil feed holes?
[Re: fast68plymouth]
#2550123
09/14/18 10:34 PM
09/14/18 10:34 PM
gregsdart
Greg, do you have a pic of your lifters that shows the pushrod oil feed holes? Unfortunately, no. But they are the Isky EZ roll bushed lifters.i don't remember the oil holes being in line with my bushing holes, as that was a concern when i put them in.
[Re: gregsdart]
#2550140
09/14/18 11:31 PM
09/14/18 11:31 PM
fast68plymouth
So. Burlington, Vt.
Doug’s oil holes are like the Comp 892’s, and with the cam I had in that 572, the holes that were in the bushings with the block as delivered from Bill Mitchell, they lined right up with each other when the lifter was on the base circle of the cam. And that will get you some serious oil flow to the top end of the motor.
Fundamentally, that oil hole placement is for a Chevy running .904 lifters.
