Re: 8 spd up and running... Russ at Sound German Automotive
[Re: roadrunninMark]
#2549609
09/13/18 02:00 PM
09/13/18 02:00 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
This is awesome news. I have a Nag1 behind a 5.7 in my 70 GTX. I am using a transmission computer designed abnd programmed by Russell and it is awesome! Great news for the 8 speed swap folks!
Driving modern convenience in classic beauty
#2549765
09/13/18 09:40 PM
09/13/18 09:40 PM
Posts: 2,734 541 slobovia
A990
541 slobovia
Wonderful news. The 8 speed sounds like an awesome transmission. Gear ratios: 1 4.71 2 3.14 3 2.10 4 1.67 5 1.29 6 1:1 7 .84 8 .67 R 2.65 Allpar link "The transmission can be used in a mild or full hybrid setup, and allows input torque up to 900 Nm, or 664 lb-ft (8HP90) — high enough for any Chrysler gasoline engine, not quite enough for the Cummins diesel."
#2549780
09/13/18 10:55 PM
09/13/18 10:55 PM
Posts: 2,255 IL
furious70
IL
Sweet, but taking a look at the one in my charger it is huge! It's 30" long bell face to rear mount and still 9" tall at the mount.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Jerry]
#2550169
09/15/18 01:04 AM
09/15/18 01:04 AM
Posts: 712 Southern Alberta
Uberpube
Southern Alberta
now just to make a mount to put it behind a big block. With an output to match up to a right hand drop np205 transfercase.
[Re: DeMopuar]
#2600332
01/02/19 09:50 AM
01/02/19 09:50 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
The 8HP90 has the Mopar small block bolt pattern on the bell housing - that is what I believe is true at least - someone please verify this please and help me out. I just took a look at the 8HP90 transmission in the flesh, but isn't the starter on the passenger side on this new 8 speed? I thought the original small block Mopars were on the driver's side - or am I missing something here? Is it possible to change the 8HP90 to the driver's side - or does the small block easily hook up the starter on the passengers side? One way or the other, trying to hook up an old LA type block or B or RB block is going to be really tough - or is this only possible with the newer Generation III hemis? I thought it would be cool to be able to hook up the old gear with this newer technology, but the starter position deal might be an absolute no deal situation. The starter is the deal breaker? Just make your harness longer. Very easy to do. Yes, Gen 3 have the same bell pattern as LA and Magnum blocks.
#2600391
01/02/19 12:50 PM
01/02/19 12:50 PM
Posts: 2,255 IL
furious70
IL
If I was going through all the work of the TF-8 I'd be putting a Gen III in front of it, I wouldn't bother trying to mate it to an old engine. It's a play for efficiency, put a modern, efficient engine in front of it.
#2601201
01/03/19 11:11 PM
01/03/19 11:11 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
A 440 with new 8 speed auto would be cool
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: mcmopar1]
#2601371
01/04/19 10:06 AM
01/04/19 10:06 AM
DemonDust
Menomonee Falls
It would probably die behind a big 2nd gen hemi! I hope you're kidding....
#2601430
01/04/19 01:18 PM
01/04/19 01:18 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
ZF8HP70 is rated for 520 FT-LBS the ZF8HP90 is rated for 740FT-LBS. it would have to be one Healthy G2...not saying that blown 572 G2 wouldn't shred it. just saying
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
