Re: Just returned from the track....Something is wrong!
[Re: Crizila]
#254984
03/18/09 08:56 PM
03/18/09 08:56 PM
Posts: 7,506 Az
Crizila
Az
EZ valve train geometry check: Remove the rockers. Wipe a few valve stems dry with solvent. Then color them black ( at least one intake and one exhaust ) with a magic marker. reinstall the rockers. Rotate the engine through several cycles. Remove the rockers and examine the contact pattern. If it's centered on the stem and not too near the stem edges, your good to go.
Fastest 300
[Re: Pacnorthcuda]
#254986
03/18/09 09:11 PM
03/18/09 09:11 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
...so had he degreed the cam in the first place....
...instead of lining up the dots...
[Re: 69L78Nova]
#254987
03/18/09 09:22 PM
03/18/09 09:22 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
When finding TDC with the piston stop make sure to go VERY SLOW as you come up to the piston stop. You do not want to create any new problems.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#254988
03/18/09 09:47 PM
03/18/09 09:47 PM
64Post
Baltimore/Denver
What... like breaking the stop off in the cylinder?
[Re: Crizila]
#254989
03/18/09 10:02 PM
03/18/09 10:02 PM
Posts: 143 North America
kwikblownhemi
North America
Interesting thread. Lotta experts here. I didn't say he didn't have a timing problem. I said cutting it back 3-4 degrees wasn't going to solve his problem. Neither is degreeing in his cam - if his marks are lined up correctly.
Lining the marks up means nothing. I had a customer's race 440 in the shop a few years ago because he couldn't get it to run - a real pig. I checked the cam timing and it was hugely retarded -about 15 degrees IIRC. Did I mention the marks were aligned? The cam gear/ a MP double roller set/ was marked off one tooth. Seems he hadn't wanted to go to the trouble to degree it when the engine was built.
It amazes me all the guys who drop big bucks on an engine build but won't spend less than $100 and an hour or so to degree the cam.
There's never enough money to do it right, but always enough to do it over.
[Re: 69L78Nova]
#254994
03/18/09 10:49 PM
03/18/09 10:49 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
Well, I just tried degreeing the cam. Repeated it 6 times to verify my results. The number I came up with is 116.5. If this cam is on a 108*, then Im 8.5* out? Which direction do I go? Advance or retard? To my knowledge, I cant seem to find a source that had 8 degree offset keyways. Any ideas?
Wow...thats off! Are you sure your TDC was accurate (which determines your positioning of the degree wheel) If it is accurate, your WAYYYYY retarded, and need to advance. Summit makes a great billet 9 slot set for about $70 that would be great (+/- 2 degrees, +8 to -8) But I gotta question if your 116.5 is accurate.
[Re: 69L78Nova]
#254998
03/18/09 11:07 PM
03/18/09 11:07 PM
64Post
Baltimore/Denver
Nevermind... that was no help.
How are you arriving at TDC?
