Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: 340SIX] #2544710
09/02/18 04:04 PM
09/02/18 04:04 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Originally Posted By 340SIX
I have one of his hoods. It is well made! Wasn't he a hit Air Balloon guy
Think they may still do that... Notary work for sure... I think there was Barry and maybe his brother or another relative...
http://asctitleandtags.com/
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: fastmark] #2545343
09/03/18 09:10 PM
09/03/18 09:10 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
[quote=fastmark]They come from the factory that way. The factory bulletin says to remove the hood springs and use a prop rod. The west Texas sun flattened mine out in two days [/quote
After two pages of advice, mine is still the same. Your oem hood is the most valuable for the car. Take the springs off and let it sit. It will flatten out. The sun will help. Be careful adding weight. It can go to far. I’d post a picture but this site does not like my iPhone.
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: 71redcuda] #2545501
09/04/18 04:22 AM
09/04/18 04:22 AM
Sweden
71redcuda Online content OP
71redcuda  Online Content OP
Sweden
Yes maby i need to do that..
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: fastmark] #2545547
09/04/18 10:43 AM
09/04/18 10:43 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Does anyone have a copy they can post or know where this document can be seen?
Maybe Barry???
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: ThermoQuad] #2545681
09/04/18 03:06 PM
09/04/18 03:06 PM
NY
LTLBEE Offline
LTLBEE  Offline
NY
Originally Posted By Dilbert
Set the hood down on a pair of 2x4x4 blocks with a hole for the hood pin in the centre of the 4 inch side.
Place a towel of 2 layers over the infected area.
Set a clean big block cylinder head on towel and leave it for at least 5 days.
Repeat if necessary.
This method worked on the bow in my AAR hood. Only other thing that I did was Took the car for a ride first to get the hood hot from the engine heat on a hot 90 degree day and used a 2x6 under the head on top of the towel. Put it in the garage with the head on it for a week and the bow was almost completely gone. I lived with that bow for 26 years before I tried this. Should have done it earler. Its been almost a year and the bow has not come back yet.
Give it a try what is the worst that can happen, you might have to rework the hood anyway?
And It does'nt cost you anything to try.
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: 71redcuda] #2545794
09/04/18 07:39 PM
09/04/18 07:39 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Unless that OE hood is repaired to add stiffness to it it WILL eventually flex and crack the gel coat, and worse, no matter whether you remove the springs or not.Even with the springs removed the hood will flex in the opposite direction upon lifting it. The factory steel insert that the bolts thread into to mount the hood is all the stiffness there is up to that point. Where the steel stops, is where it flexes and eventually cracks. The original fiberglass channel is not strong enough to support it. The best way I know how to make an "invisible" "repair" is to insert some sort of stiffening material (hollow pipe, etc.) into the channel from the very back of it, by carefully sawing away at the end 'cap' of the channel at the very back of the hood where it's least visible. Insert the stiffening device , then set the hood upside down and lock it into a position where the bend is gone. Then pour mixed epoxy resin into the channel to set the stiffening device in place. Make sure to thread bolts into the OE hood mounting holes before pouring the resin. You only get one shot at it, so you have to get it right the 1st time. Not for the faint of heart. Some judicious gel coat work at the place the channel is opened up to reattach the removed piece, and some dark primer and you're done.
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: 71redcuda] #2545800
09/04/18 07:55 PM
09/04/18 07:55 PM
Kirkland, Washington
Pacnorthcuda Offline
71redcuda: are you sure your car has the correct AAR hood springs? They are smaller in diameter than steel hood springs, and while they still promoted the bulge, when someone put standard springs on a glass hood car the hood would really warp!
Make sure your springs are as weak as possible once you "fix" the hood.
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: Pacnorthcuda] #2547283
09/07/18 05:56 PM
09/07/18 05:56 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
This all good info, but again does anyone recommend a replacement hood. I also have a hood that someone left,the pins and folded,the hood back. The inner frame structure in front and behind the hinge mounts is cracked completely around. I’m surprised the hood hasn’t come completely apart. The inner structure needs to be rebuilt. So I am looking for a hood also.
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: fastmark] #2548211
09/10/18 01:32 AM
09/10/18 01:32 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Common issue reported on original hoods. Those hoods are supposed to have special hood springs. I’m not sure if you can find a repro hood that would work any better? Even if you do, you want to keep the original hood.
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: RoadRunnerJD] #2549432
09/12/18 11:32 PM
09/12/18 11:32 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Nicklas, I purchased one 5 months ago from Year One and I'm very happy with it. It was molded from a nice original hood and even the holes for the clips and screws underneath were faintly there just needing to be opened up. Eddie
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: 71redcuda] #2549771
09/13/18 10:02 PM
09/13/18 10:02 PM
MO
cdp Offline
cdp  Offline
MO
My friend has a restored FM3 AAR. He bought a new year one piece and it is extremely nice. One thing he does is to not store it with the hood pinned down. He always pulls the pins so no pressure is in the hinge area during long term storage stints.
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: 71redcuda] #2550150
09/14/18 11:58 PM
09/14/18 11:58 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
I replaced my hood back in the late 80s with one from year one. It was exact to my orig except for the wedge bumps that touch the plastic wedges on the inside lip of thefender. The year one hood just didn’t have em. So I made em with fiberglass and they are still there today. Wish I knew about straightening the original hood... I woulda done that
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: 71redcuda] #2550189
09/15/18 03:09 AM
09/15/18 03:09 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The year one hoods used to be made by ASC&P which they no longer make them... I looked into buying one last year and ended up molding a race glass hood to a steel frame. I know mine won't bow.
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: Silver70] #2550268
09/15/18 12:18 PM
09/15/18 12:18 PM
moparx Offline
moparx  Offline
interesting. what did you use for springs ? did you do anything to mimic a "fiberglass appearance" to the hood framework ?
beer
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: 71redcuda] #2550331
09/15/18 03:15 PM
09/15/18 03:15 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I just left it rough and painted flat black. It's just a clone, so wasn't too concerned about looking original. I had cuda hood the top was shot and got the fiberglass race glass hood on ebay for basically nothing using ebay bucks. I did buy some good 3m adhesive made for bonding materials like this.
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: 71redcuda] #2551973
09/19/18 03:55 PM
09/19/18 03:55 PM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
AAR out of Florida was making these and nice pieces. I have the repo T/A hood. Nice piece but after 10 years even it has started to bow. I tried all those fixes on my original hood. None of them worked.
1970 Dodge Challenger T/A
Re: Bowed AAR Cuda hood.. Where to get a new one.. [Re: jeff968] #2552017
09/19/18 06:18 PM
09/19/18 06:18 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've had my Fiberglass Trends repro T/A hood on my Challenger since about 1979 (39 yrs) with the springs always on...been lucky, still hasn't bowed...
