Re: M/P HEMI BLOCKS
[Re: 440lebaron]
#2546660
09/06/18 01:12 PM
09/06/18 01:12 PM
Posts: 4,595 Motor City
6PKRTSE
Motor City
I have a Mopar M block for my Hemi and everything was spot on. Came in at the 4.500" I only had to dust the bores to 4.503 to fit my JE Pistons.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: M/P HEMI BLOCKS
[Re: rickseeman]
#2546680
09/06/18 01:50 PM
09/06/18 01:50 PM
Posts: 1,545 USA
hudsonhornet7x
USA
If you want 4.500" bore someplace else might be cheaper. Any suggestions? Also can the 4.24 bore blocks go out to 4.500"?
Re: M/P HEMI BLOCKS
[Re: 440lebaron]
#2546692
09/06/18 02:13 PM
09/06/18 02:13 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Common casting, all Siamese, unfortunately there haven't been any water blocks since the prior generation piece marketed as 'megablock'.
Rich H.
Esse Quam Videri
Re: M/P HEMI BLOCKS
[Re: ZIPPY]
#2546702
09/06/18 02:29 PM
09/06/18 02:29 PM
Posts: 43,368 Bend,OR USA
Cab_Burge
Common casting, all Siamese, unfortunately there haven't been any water blocks since the prior generation piece marketed as 'megablock'. I built a cast iron World block back in the early 2000s with the 4.190 rough bore block bought from Mopar per the customer not wanting to take a chance on the larger 4.490 bore block running hot, he ASSUMED that the smaller bore block would have water passages between he cylinders, NOT SO There may have been around 1.0 to maybe 2.0 inch small opening, part of a very small water passage, down low on the center cylinders, maybe not ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
Re: M/P HEMI BLOCKS
[Re: 440lebaron]
#2546711
09/06/18 02:50 PM
09/06/18 02:50 PM
ZIPPY
S.E. Michigan
Cab, there was no such thing as a Mopar "World" block in the early 2000s. it didn't exist yet.
If you meant the megablock as I am assuming you might have, then I would have to agree with your findings...the bore would not be a determining factor, small bore was available both ways.
Rich H.
Esse Quam Videri
Re: M/P HEMI BLOCKS
[Re: 440lebaron]
#2546726
09/06/18 03:25 PM
09/06/18 03:25 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
I have a World hemi block in the shop that came new as a 4.24" bore. It is Siamese bore and has PLENTY of meat in the walls. I bored it to 4.5"...took about 25 lbs out of it which was a huge plus! These things are ridiculously heavy.
Re: M/P HEMI BLOCKS
[Re: rickseeman]
#2546934
09/06/18 10:11 PM
09/06/18 10:11 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
I thought Bill Mitchell had been making aluminum blocks for years? He was, but he stopped making them a few years ago. He just started talking about producing them again this year with some improvements. Looks like he shipped some recently and is tweaking it again before shipping more, later this year.
Re: M/P HEMI BLOCKS
[Re: ZIPPY]
#2547029
09/07/18 01:32 AM
09/07/18 01:32 AM
Cab_Burge
your correct ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) it was in the late 2000s, not earlier ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) I built that one around 2008 or later with the block ordered from my local Dodge dealer, it was a World block ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) I did build several other N/A cast iron hemi blocks that where the earlier Mega blocks, one 4.25 bore and the others where either 4.320 or 4.380 bore sizes, CRS I finished a pump gas EFI 572 C.I. motor earlier this year with one of the old World blocks that was 4.490 rough bore size, it made right at 799 HP at 6500 RPM, a little less torque than HP ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif)
Re: M/P HEMI BLOCKS
[Re: rickseeman]
#2547045
09/07/18 02:43 AM
09/07/18 02:43 AM
Posts: 1,545 USA
hudsonhornet7x
USA
Dumb question I know, but is there any chance of an average guy like me getting one of these for a build this winter? Yes, you could get one if you will pull out your credit card and hit the button. Just took the plunge. Now I just need everything else lol.
Re: M/P HEMI BLOCKS
[Re: hudsonhornet7x]
#2547594
09/08/18 01:37 PM
09/08/18 01:37 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
Yes: I see on the JEGS site the 4.5 block is a bit over $4k and is supposed to ship in a week while the 4.24 bore is a bit over $3k and is supposed to ship in a couple weeks. So that is a no-go? I was going to order one as well but I guess it isn't worth me phoning?
Sheldon
