Re: Another carb CFM question [Re: LowDeck451] #2547897
09/09/18 12:37 PM
09/09/18 12:37 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The equation prevents 2 things:
1. Children asking yet another question
2. Selecting a carb large enough that idle and tip-in are poor (although there is no input for "primary venturi area per inch of engine displacement"). As the total CFM goes up, the primary:secondary balance of all square bore carbs (4150/60, AFB, AVS) changes.
Boffin Emeritus
Re: Another carb CFM question [Re: LowDeck451] #2547905
09/09/18 01:03 PM
09/09/18 01:03 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
For what it’s worth, The Holley website carb-selector does not just blindly follow the common equation. I actually followed its advice on my car, which was an HP1000 on my 452”, 6300 rpm mill.
Re: Another carb CFM question [Re: LowDeck451] #2548198
09/10/18 12:56 AM
09/10/18 12:56 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Holley also assumes that all calculations would be based on a V8 engine with all cylinders drawing from all carb throat simultaneously. This means a single plane manifold, not a dual plane, divided single plane, or "360°".
If using a V8 with individual throttle bodies such as stack injection, the formula will invariably return a size far too small to work. E.g., if a single Holley 4500 supplies 1,000 CFM to a 500" engine at 7,000 RPM, the intuitive assumption is to divide the 1,000 by 8 to get the ITB CFM, or 125 CFM each. This is only slightly more than 1" diameter...
There is a correction for 6 cylinders or less supplied by the same carburetor, multiply this number by the usual Holley formula:
7 or more cylinders: 1.0
6 cylinders: 1.1
5 cylinders: 1.3
4 cylinders: 1.6
3 cylinders: 2.2
2 cylinders: 3.3
1 cylinder: 6.6
The CFM for the 500" engine would each be 825 CFM (assuming no manifold volume). At about 125 CFM per square inch, this makes the throat 6.6 square inches, or about 2.9" diameter. How odd, that's the size of the Crower BBC stacks...
Boffin Emeritus
Re: Another carb CFM question [Re: polyspheric] #2548216
09/10/18 01:42 AM
09/10/18 01:42 AM
Originally Posted By polyspheric
some have to pick everything apart
So annoying - someone had the correct answer, and it wasn't you.
What is perfect for one may or may not be perfect for someone else shruggy
Being the racer I am may have some influence on my choices on many things dealing with motors, especially Hi Po motors whistling grin
