Re: A12 Idle solenoid TROUBLESHOOTING problem
[Re: Snoopy]
#254543
03/19/09 05:19 PM
03/19/09 05:19 PM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
I think you will find that Year One supplies the harnesses to Frank Badalson/Roger Gibson and they are made by M&H.
Having said that, it looks like he has added the label and seems to have a lower list price than Year One.
69EH This is the only correct 69 ½ engine harness available. Correct modifications unique to the 1969 ½ 440-6 cars only. Furnished with correct part number tag $105.00 69EHS
.with solenoid wire
..$130.00 69EHSB
.with ballast resistor to coil wire
.$140.00
You are correct,they don't make them,they sell them.
[Re: Snoopy]
#254544
03/20/09 08:24 AM
03/20/09 08:24 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
John, Doesn't the idle solenoid plug into the special connector on the coil wire that plugs into the regulator?
There is a plug just like the one in the picture above on that ballast resistor , it's on the other side of the regulator, you just can't really see it in that picture but it's there .
I bought both the separate wires that Badalson sells to add them to the NOS 69 engine harness I have when I had an A12 , still have the harness and the wires just not the car. I used one of the wires to power the choke on my ebrock carb
