Re: Steering wheel-mounted line-lock button?
[Re: BradH]
#2544187
09/01/18 11:49 AM
09/01/18 11:49 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I have never used a steering wheel mounted line lock button, but I don't think it would be a good idea for street. The amount of turning with those cords on a street car might tend to stretch out the cord, or worse, get tangled up and limit your steering in the middle of a turn. I'm not familiar with your shifter handle design, but I've always zip tied a micro switch to the shaft. Some handles already have the button installed. I think a trick street piece would be a late model steering column with a clockspring. Could be wired for line loc, trans brake, nitrous, whatever you want. No external wires.
[image][/image]
[Re: BradH]
#2544197
09/01/18 11:54 AM
09/01/18 11:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
What I did was mount the button on the wheel and ran the cord straight forward to the dash where I have a plug in for a RCA plug.. never tore the wires off EDIT On the street just make sure the button is recessed a bit so you dont hit it by accident
[Re: BradH]
#2544208
09/01/18 12:08 PM
09/01/18 12:08 PM
sgcuda
Take a closer look at the button assembly. There used to be a slot on the button where the rubber strap went through. I slid a zip tie through it. You might want to grind a small notch on the backside of the shaft for the zip tie to stay positioned in.
[image][/image]
[Re: BradH]
#2544209
09/01/18 12:09 PM
09/01/18 12:09 PM
MR_P_BODY
This is for my trans brake.. the switch came with it(Biondo switch).. for my line lock I have the Hurst ball handle with the switch in the ball.. I can hold the button while shifting it to high gear in the burnout.. I changed what I did and just used high gear for the burnout ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: BradH]
#2544234
09/01/18 01:02 PM
09/01/18 01:02 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I have always used a switch mounted on the shifter in a position that can be used when shifting into high gear. The line lock solinoid is low amp draw and does not require a huge switch
"Just a Bracket car dressed up like a streetcar"
[Re: BradH]
#2544294
09/01/18 03:27 PM
09/01/18 03:27 PM
Posts: 11,840 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I had the line-loc on the left side of the wheel and the transbrake on the right with coil cords. Secure the cords so they don't pull on the switch connections, leave some slack so it can "wrap" on the column when turning. Works fine. Just have to watch you don't snag them with your feet getting in or out.
[Re: BradH]
#2544391
09/01/18 08:35 PM
09/01/18 08:35 PM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
Make sure that if the turn stem is there it dont hang up.Dont ask my 65s did.Rocky
Chrysler Firepower
[Re: fourgearsavoy]
#2544413
09/01/18 10:04 PM
09/01/18 10:04 PM
MR_P_BODY
I have seen guys use the horn button to ground the line lock solenoid and have a toggle switch to switch the circuit from the horn from the line-loc ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Gus I was going to to this but went with the button on my T handle since I dont have a trans brake on my street rod ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: BradH]
#2544505
09/02/18 04:24 AM
09/02/18 04:24 AM
Posts: 8,390 fredericksburg,va
cudaman1969
fredericksburg,va
I made a bracket attached to dash, within easy reach but not to close the steering wheel. Always in the same position and stable, it was an forearm snap-pull back, takes the wrist- finger movement out of the equation, basicly one muscle. Right handed release, then to shifter, left hand on the wheel. Keep it simple. Had the cord and it always tangled on something and would catch between the gap of wheel and column, big pain.
[Re: MR_P_BODY]
#2544580
09/02/18 12:29 PM
09/02/18 12:29 PM
Posts: 19,712 north of coder
moparx
I hear ya.. any auto related I put in the shop.. might take me some time to find it but I will i know it's there because thst's where i put it. i just have to have it jump at me when i need it ! i started to write down where stuff is located, but i lost that note pad. go figure ! ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) i know how you feel mr.P. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: RTSE4ME]
#2544828
09/02/18 10:39 PM
09/02/18 10:39 PM
dartman366
Mt. Vernon, Ohio
I don't loose anything,, if I cannot find what I am looking for it's because my wife moved it.
