What motor do I have 273 or 318? #2544317
09/01/18 04:50 PM
09/01/18 04:50 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
I just picked up a 1967 small block motor. Chevy guy I bought it from said he took it out of his friends 67 Barracuda. They think its a 318. The casting number on the block is 2806030-273-4 cast on 4-7-67. The number stamped on the front of the block under the head is C 318. I thought the casting number on the side of the block had the motor displacement in the number which is 273 but on the front the stamped number is 318. What makes it more confusing is the motor has the 273 adjustable rockers with the correct heads and date codes. How can I find out what I have?
Re: What motor do I have 273 or 318? [Re: LTLBEE] #2544319
09/01/18 04:55 PM
09/01/18 04:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
since you can't make a 318 out of a 273 casting, I'm gonna say 273.
Measure the bore. 3.625 vs 3.91
Don't be the exception.
Re: What motor do I have 273 or 318? [Re: LTLBEE] #2544325
09/01/18 05:21 PM
09/01/18 05:21 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Being 67 and adjustable rockers, I'd say 273. But who knows, maybe they just put the wrong numbers on the side or front since 67 was the first year for the LA 318, but not in a Barracuda I think. 67-68-69 where the last years for the A-body 273s. At least it's got the good steel crank. Only one way to tell....
After looking at those rockers again, they look added, retainers are too big for the springs and they too look bigger than stock, then the aluminum intake too. Somebody's been changing parts. What's the head numbers?
Re: What motor do I have 273 or 318? [Re: LTLBEE] #2544334
09/01/18 05:56 PM
09/01/18 05:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Wrong number on the side, lol. Listen to what you said. Everything you point out, except the numbers on the side, can easily be changed after it left the factory. The casting numbers can't.
measure the bores, anything else is BS.
Re: What motor do I have 273 or 318? [Re: LTLBEE] #2544336
09/01/18 06:00 PM
09/01/18 06:00 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Had a 67 Fury one owner since new that had a 318 Poly from factory.IIRC it was a real early build.Paid 75 bucks for it because timing jumped.New chain and my brther drove it for 3 years.Rocky
Chrysler Firepower
Re: What motor do I have 273 or 318? [Re: cudaman1969] #2544340
09/01/18 06:05 PM
09/01/18 06:05 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
The head numbers are 2658920 with the correct 67 date code. The motor had a LD4b manifold and Mallory Dual Point dist added but the cam is original. Can the adjustable rockers be used with the hydraulic lifters and cam?
Re: What motor do I have 273 or 318? [Re: Supercuda] #2544348
09/01/18 06:19 PM
09/01/18 06:19 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
Its supposed to be a running motor so I really don't want to pull it apart to measure the bores unless I have to.
Re: What motor do I have 273 or 318? [Re: LTLBEE] #2544371
09/01/18 07:14 PM
09/01/18 07:14 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Go with the casting number, that's a 273 that someone stamped 318 on the front.
Re: What motor do I have 273 or 318? [Re: LTLBEE] #2544390
09/01/18 08:33 PM
09/01/18 08:33 PM
yes but you likely will need shorter pushrods (mockup & see what you have for preload/threads showing under rocker tip) which might not be as critical on a daily driver but see what you got & go from there. EDIT cup/ball end rods like the OE solid lifter pushrods. MORE EDIT after some brief thought, very likely you will need shorter ball/cup pushrods.
Re: What motor do I have 273 or 318? [Re: RapidRobert] #2544419
09/01/18 10:26 PM
09/01/18 10:26 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Originally Posted By RapidRobert
[quote] Can the adjustable rockers be used with the hydraulic lifters and cam?
What makes you think it has a hydraulic cam?
Since it IS a 273 block, it IS a 273 and would have solid lifters and adjustable rockers stock. If the cam is stock as you say then the rockers and pushrods should be correct.just remember it needs lash not preload.
Re: What motor do I have 273 or 318? [Re: GomangoCuda] #2544501
09/02/18 04:01 AM
09/02/18 04:01 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
The casting numbers tell the story, you have a 273. I have had several 273's. Up until 1968 they all came with solid cams and adjustable rockers. The 68 engine I have now, came with a hydraulic cam and stamped steel rockers like the 318's.
Re: What motor do I have 273 or 318? [Re: elmor353] #2544524
09/02/18 10:10 AM
09/02/18 10:10 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
2 barrel engines were solid lifter also?
Kevin
Re: What motor do I have 273 or 318? [Re: Twostick] #2544535
09/02/18 10:45 AM
09/02/18 10:45 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Kevin
No. 273's went up to 1969, had a 69 Dart convertible with one in it, two barrel only in 68 and 69. wave
JB Rhinehart, Realist
A-Body's RULE!
Re: What motor do I have 273 or 318? [Re: LTLBEE] #2544561
09/02/18 11:45 AM
09/02/18 11:45 AM
fredericksburg,va
fredericksburg,va
My 65 Satilite has the 273-2 bbl, solid lifters
Re: What motor do I have 273 or 318? [Re: elmor353] #2544618
09/02/18 01:32 PM
09/02/18 01:32 PM
NY usa
540challenger Offline
NY usa
When I purchased my Challenger someone install a 273 in it fun little motor. Solid cam 10.5/1 piston. Just be aware 67 and pprior had a smaller crack hub for the torque converter later so if swapping trans take measurements first
Re: What motor do I have 273 or 318? [Re: Rhinodart] #2544877
09/03/18 12:59 AM
09/03/18 12:59 AM
E
elmor353 Offline
elmor353  Offline
E
As I said ALL 273 engines, 2bbl and 4bbl, were solid lifter engines until 1968. 68 and 69 came with hydraulic cams and stamped steel rockers like the 318.
Re: What motor do I have 273 or 318? [Re: elmor353] #2544949
09/03/18 07:04 AM
09/03/18 07:04 AM
As said definitely a 273 short block. that is a new one on me, stamping the front dr side of the 273 block with "318" & they kept the 273 solid lifter stuff. Any evidence of a restamping there?
Re: What motor do I have 273 or 318? [Re: RapidRobert] #2545089
09/03/18 01:45 PM
09/03/18 01:45 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
Does not look like it was restamped.
Re: What motor do I have 273 or 318? [Re: LTLBEE] #2545132
09/03/18 02:48 PM
09/03/18 02:48 PM
Assembly line workers have their off days too (all I can think of).
Re: What motor do I have 273 or 318? [Re: RapidRobert] #2545649
09/04/18 02:05 PM
09/04/18 02:05 PM
dogdays Offline
dogdays  Offline
Exactly. iagree
R.
