Re: Automatic Shifters??? Looking for opinions
[Re: wkroncke17]
#2544872
09/03/18 12:47 AM
09/03/18 12:47 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
The pro matic 2.... what i REALLY liked about this shifter in the Mirada was that I was able to graft it in to the factory council. Looked like it was born with it! https://m.youtube.com/watch?v=LvUkMXaLopIThe deal on the Duster was that we could never get it properly adjusted. Being it was “race” we concentrated on N and 123. Just could never find a happy medium. Both cars had Griner t-brakes and swapping the shift lever didn’t change a thing. Always figured something was just made “wrong” on that one.
[Re: J_BODY]
#2544961
09/03/18 09:55 AM
09/03/18 09:55 AM
Posts: 8,033 Tulsa OK
Bad340fish
Tulsa OK
Thats too much work lol I like my Turbo Action Shifter, its so smooth, and the lockout mechanism is good, yet seamless to use. I can see how the design might cause problems for some with the automatic 1-2 shift but mine has been a 1.43 60ft and hasn't done it yet.
68 Barracuda Formula S 340
[Re: J_BODY]
#2545016
09/03/18 11:57 AM
09/03/18 11:57 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I too like and use a PPP shifter.
They have a lot of options front or rear cable, push or pull upshift, air shift, Red or black.
Most people that say they don't like a PPP have NEVER used one. When I use a ratchet shifter I have Quickclick flashbacks.
"Just a Bracket car dressed up like a streetcar"
[Re: wkroncke17]
#2545164
09/03/18 04:00 PM
09/03/18 04:00 PM
Posts: 11,658 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I know some like them, but I abhor a ratchet shifter. Can't tell what gear you're in without trying to see the indicator or jacking the thing all the way to P or 3. Should be able to run it without thinking about it, looking at it, jacking with it.
[Re: wkroncke17]
#2545247
09/03/18 05:51 PM
09/03/18 05:51 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Another vote for the B&M Pro Stick. I run one in the race car and one in my street car. Factory Slap Stick in my wife's `Cuda. Both shifters are great.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: wkroncke17]
#2545326
09/03/18 07:59 PM
09/03/18 07:59 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
B&M pro stick, this video shows that it doesn't just slap up into 3rd, but requires the handle to be squeezed? Is that right. Why would they do that? https://www.youtube.com/watch?v=ooXaFtrTGtURe the Pro ratchet, I have one and drive it around every weekend on the street. I'm never confused about what gear I'm in and if I ever do look at the shifter, e.g. sitting at a light to see if I'm in 1st (or I might just try to ratchet it back), it's certainly not anything that takes any thought or effort.
[Re: Just-a-dart]
#2545437
09/03/18 11:44 PM
09/03/18 11:44 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Most people that say they don't like a PPP have NEVER used one. When I use a ratchet shifter I have Quickclick flashbacks. 😳😳😡 I had one of those Quick clicks!! I hated it also! I’m sure there’s been upgrades, but you are correct, it’s scared me away from them. I truly appreciate all of the advice, and yes, that have gotten expensive. But in this hobby that we love, what is cheap? I’m thankful the advice here is!
[Re: wkroncke17]
#2545472
09/04/18 01:33 AM
09/04/18 01:33 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I put a pistol grip on my Pro Ratchet, I like it a lot better than the ball.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: CMcAllister]
#2545482
09/04/18 02:47 AM
09/04/18 02:47 AM
Posts: 624 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
I know some like them, but I abhor a ratchet shifter. Can't tell what gear you're in without trying to see the indicator or jacking the thing all the way to P or 3. Should be able to run it without thinking about it, looking at it, jacking with it. ^^^ this
[Re: wkroncke17]
#2545537
09/04/18 10:23 AM
09/04/18 10:23 AM
Adobedude
New Mexico
I've had two ratchet shifters, not knowing what gear it's in has never been an issue.
[Re: Adobedude]
#2545820
09/04/18 08:35 PM
09/04/18 08:35 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
I put a pistol grip on my Pro Ratchet, I like it a lot better than the ball. I like how you attached the pistol grip The Ramcharger I recently picked up had a pro ratchet with the pistol grip attached by just screwing on to the shifter arm, eventually it broke off due to the added leverage. your mount is much stronger thanks for the idea.
[Re: Mr340]
#2545846
09/04/18 09:45 PM
09/04/18 09:45 PM
Adobedude
New Mexico
Mine broke too, hence the fix. Pulled into the staging lanes and "POP"...I went rounds, but it wasn't easy. It's an aluminum turn buckle from Lowes
[Re: Adobedude]
#2545997
09/05/18 03:00 AM
09/05/18 03:00 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have the reverse pattern and my shifter is mounter higher than your but I use 2 fingers to shift.. were little effort to shift.. I guess with your being lower you have to hit it a bit harder and it broke
[Re: wkroncke17]
#2546094
09/05/18 11:47 AM
09/05/18 11:47 AM
Adobedude
New Mexico
My not liking the Cheetah shifter is I'd pull on it instead of slapping it, nothing I could do would break that habit. Once installed my ratchet shifter and the in cab GoPro, I noticed I'm slapping the ratchet shifter.
Go figure.
[Re: Adobedude]
#2546100
09/05/18 11:54 AM
09/05/18 11:54 AM
MR_P_BODY
The one thing I would do once in a while was not letting go of the shifter.. if you dont let go of it it dosent set up for the next shift but that was seldom I would do that( on my pro ratchet)
[Re: wkroncke17]
#2546153
09/05/18 01:54 PM
09/05/18 01:54 PM
Adobedude
New Mexico
The GoPro pointed out I shift on the money when I leave 1st, when I'm chasing a slower vehicle I tend to shift late and bounce off the rev limiter. Hence the Shifnoid install. https://www.youtube.com/watch?v=qb3HbfhJXXM
