Bowed AAR Cuda hood.. Where to get a new one..
#2543731
08/31/18 07:01 AM
08/31/18 07:01 AM
Posts: 1,553 Sweden
71redcuda
Sweden
Hello,
Im planing to get a another hood for my AAR Cuda. The original is very bowed.
Is there anyone that makes OE correct aar hoods today? I want the very best & close to original as possible.
Hood is more bowed on passenger side.
Thanks Nicklas
Re: Bowed AAR Cuda hood.. Where to get a new one..
[Re: 71redcuda]
#2543768
08/31/18 10:54 AM
08/31/18 10:54 AM
Posts: 2,469 Answering the call of the wild
ThermoQuad
Set the hood down on a pair of 2x4x4 blocks with a hole for the hood pin in the centre of the 4 inch side.
Place a towel of 2 layers over the infected area.
Set a clean big block cylinder head on towel and leave it for at least 5 days.
Repeat if necessary.
[Re: ThermoQuad]
#2544133
09/01/18 04:01 AM
09/01/18 04:01 AM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
Without knowing the extent of the bow and if the hood may have previously been repaired, there’s no way to say if this will work, but based on my experience this is a long shot. I believe there is a gross underestimate on the role the bonded under support plays and the ability to overcome that stiffening with heat and weight.
[Re: ThermoQuad]
#2544212
09/01/18 12:16 PM
09/01/18 12:16 PM
AAR#2
Dry Heat AZ
Wow...Experience...i have none other than owning several of these cars and helping others since 1980
Are you sure? Have you ever tried this?
How do you know it does not work?
Repairs have nothing to do with the bow in the stock hoods.
A request was made for the OP to post a photo of the hood as it is today, this would help to better understand just how much the hood would need to move. Many an AAR hood suffered the fate of being ripped from its backing structure when someone would forget to install the hood pins, the subsequent repair often leaves these hoods in far worse shape than they would have left the factory. I've worked pretty extensively with composites of different types and cut my teeth as a tool engineer. Early composites were not well understood, things like CTE, shrink factor and spring-in were not well understood or accounted for in tooling. So the factory hood wasn't as perfect as you may be able to achieve today. To your point, I have never tried to simply add weight to a hood in an attempt to flatten curvature. I suspect only the smallest of movement will be achieved and the hood will quickly revert to its original shape. That said I would encourage the OP to give your suggestion a try as it is a much easier, less intrusive fix that anyone can perform.
[Re: Sixpak]
#2544229
09/01/18 12:54 PM
09/01/18 12:54 PM
Posts: 18,157 Mass
DAYCLONA
Mass
ASC&P used to make the best repro T/A hoods, not sure if they are still in business; they may have supplied Year One. The originals can be repaired by adding additional stiffening to the internal bracing, longer than the original steel insert. The factory steel insert the hinges bolts to is too short. ASC&P is all done, as to where their molds went? someone must know? I've been "lucky" the last 40 years with my repro T/A hood (Fiberglass Trends) on my Challenger, still nice and flat, and has had the springs on it for 40 years now
[Re: DAYCLONA]
#2544445
09/01/18 11:13 PM
09/01/18 11:13 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
ASC&P used to make the best repro T/A hoods, not sure if they are still in business; they may have supplied Year One. The originals can be repaired by adding additional stiffening to the internal bracing, longer than the original steel insert. The factory steel insert the hinges bolts to is too short. ASC&P is all done, as to where their molds went? someone must know? I am not far from where Barry made those hoods... He also made nice 442 hoods. I get down that way every so often I can ask as I know someone close to him that has a business still near there what actually happened to the molds... The farm he made them at was sold and being developed..
[Re: QuickBpBp]
#2544456
09/01/18 11:33 PM
09/01/18 11:33 PM
Posts: 28,611 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
ASC&P used to make the best repro T/A hoods, not sure if they are still in business; they may have supplied Year One. The originals can be repaired by adding additional stiffening to the internal bracing, longer than the original steel insert. The factory steel insert the hinges bolts to is too short. ASC&P is all done, as to where their molds went? someone must know? I am not far from where Barry made those hoods... He also made nice 442 hoods. I get down that way every so often I can ask as I know someone close to him that has a business still near there what actually happened to the molds... The farm he made them at was sold and being developed. I have one of his hoods. It is well made! Wasn't he a hit Air Balloon guy
[Re: ThermoQuad]
#2544508
09/02/18 04:52 AM
09/02/18 04:52 AM
Posts: 1,553 Sweden
71redcuda
Sweden
Thanks for the heads up. And this could work? Might be worth a shot.. Have you done this on a few aar cars before? Im just afraid of cracking the hood.. the car is nicly restored so i really would like to fix the hood so it matches the rest of the car.. and original is always original.. i have seen NOS hoods for sale that i have considered buying.. but i live in Sweden so shipping is no fun. I have added a few pics to my first post.. Thanks Nicklas
[Re: ThermoQuad]
#2544609
09/02/18 01:26 PM
09/02/18 01:26 PM
AAR#2
Dry Heat AZ
The information i have provided is factual and based on owning an AAR that i brought in 1980 and sold in 2012 that HAD the same warped area on the hood when i bought the car. Many other cars have been repaired with this technical information since 1980. I forgot to mention it works better if the hood car is placed in the hot sun for several hours before applying the "fix". It will not crack the hood! As i recall i wrote a tech article in the All American Racer Magazine regarding these hoods. You can give us all the mumbo jumbo and more that you have provided Dr Aar#2 but the information i have provided is real world and it works. Dilbert, thanks for contributing all that “technical” information, I’m certain I can’t provide any value added input. Since I’m always disappointed when I read threads were disagreements turn into mud slinging matches I’ll choose to bow out and remain a gentlemen.
[Re: 71redcuda]
#2544651
09/02/18 02:11 PM
09/02/18 02:11 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
The op asked where to buy a new hood, not how to fix his.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2544667
09/02/18 02:41 PM
09/02/18 02:41 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The op asked where to buy a new hood, not how to fix his. Yes, that's his initial request, but seeing he's in Sweden, shipping costs alone will be phenomenal, either matching or superseding the cost of a hood alone DAMHIK, plus there WAS only one source for a faithful reproduction, and seeing as that he has a "nice" original, other than having that massive bow(s) present, personally I think he should rework the original, it will take an individual knowledgeable in fiberglass repair to properly brace the hood back to the shape desired, cut into the stressed area underneath, insert stiffeners that won't telegraph later on into the surface, and re-glass the whole thing back together, it could be done without disturbing the painted finish...if the right individual is employed Yeah you could park an elephant on it in the sun for a short term fix, and then turn the car into a vampire, allowing it out only on cool summer nights never to see daylight ever again, but between the spring tension, underhood heat and the memory that fiberglass has taken, surgery IMHO is the only cure Mike
[Re: DAYCLONA]
#2544670
09/02/18 02:49 PM
09/02/18 02:49 PM
Posts: 1,553 Sweden
71redcuda
Sweden
The op asked where to buy a new hood, not how to fix his. Yes, that's his initial request, but seeing he's in Sweden, shipping costs alone will be phenomenal, either matching or superseding the cost of a hood alone DAMHIK, plus there WAS only one source for a faithful reproduction, and seeing as that he has a "nice" original, other than having that massive bow(s) present, personally I think he should rework the original, it will take an individual knowledgeable in fiberglass repair to properly brace the hood back to the shape desired, cut into the stressed area underneath, insert stiffeners that won't telegraph later on into the surface, and re-glass the whole thing back together, it could be done without disturbing the painted finish...if the right individual is employed Yeah you could park an elephant on it in the sun for a short term fix, and then turn the car into a vampire, allowing it out only on cool summer nights never to see daylight ever again, but between the spring tension, underhood heat and the memory that fiberglass has taken, surgery IMHO is the only cure Mike Hi Mike. Thanks for your input.. the problem is to find a good fiberglass guy that know what he is doing.. not good if the hood gets unusable.. Yes shipping is expensive but biggest problem is shipping damage risk. Im willing to pay whatever it cost to get another hood BUT it must be OE correct.. if that not is possible i think someone have a good business here to start making correct hoods. Thanks Nicklas
[Re: 71redcuda]
#2544698
09/02/18 03:48 PM
09/02/18 03:48 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
The op asked where to buy a new hood, not how to fix his. Yes, that's his initial request, but seeing he's in Sweden, shipping costs alone will be phenomenal, either matching or superseding the cost of a hood alone DAMHIK, plus there WAS only one source for a faithful reproduction, and seeing as that he has a "nice" original, other than having that massive bow(s) present, personally I think he should rework the original, it will take an individual knowledgeable in fiberglass repair to properly brace the hood back to the shape desired, cut into the stressed area underneath, insert stiffeners that won't telegraph later on into the surface, and re-glass the whole thing back together, it could be done without disturbing the painted finish...if the right individual is employed Yeah you could park an elephant on it in the sun for a short term fix, and then turn the car into a vampire, allowing it out only on cool summer nights never to see daylight ever again, but between the spring tension, underhood heat and the memory that fiberglass has taken, surgery IMHO is the only cure Mike Hi Mike. Thanks for your input.. the problem is to find a good fiberglass guy that know what he is doing.. not good if the hood gets unusable.. Yes shipping is expensive but biggest problem is shipping damage risk. Im willing to pay whatever it cost to get another hood BUT it must be OE correct.. if that not is possible i think someone have a good business here to start making correct hoods. Thanks Nicklas Nicklas, Sweden has to have plenty of guys that are involved with Fiberglass Boats. One of those guys should be able to fix the hood. Start talking to those guys. Morty
