Re: D400 - Should I convert from Manual to Auto? [Re: 68Cbarge] #2559918
10/06/18 02:40 PM
10/06/18 02:40 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I have to agree a Cummins 12V would be the way to go, you'd have to gear it up though. They're about done at 2000RPM.
Sheldon
Re: D400 - Should I convert from Manual to Auto? [Re: Handygun] #2560829
10/08/18 11:41 AM
10/08/18 11:41 AM
Truck Y'all ! Offline OP
@handygun ...I sent you a PM. I am looking for a hydrobell and (of course) B/RB engine mounts
Re: D400 - Should I convert from Manual to Auto? [Re: poorboy] #2561318
10/09/18 09:41 AM
10/09/18 09:41 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Originally Posted By poorboy
I have no doubt that a 727 can be built to do the job, but at what cost?
There is a pretty signigifent different difference between a high power motor abusing a trans for 7-12 seconds, or rock crawling at very slow speeds and a 6 mile 6% uphill grade pulling 20,000 lbs.
Ask Rhinodart how those 727s and their derivatives hold up dragging heavy loads across the country. Gene
I know a 48RE is a 727 derivative but throwing all the electronic garbage and weak overdrive is what killed mine! Don't forget I lunched 5 NV4500's and 2 G56 Mercedes transmissions too! I am still contemplating what to put in my D700 as it has a 361 big block and I believe a 435 now. shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: D400 - Should I convert from Manual to Auto? [Re: Rhinodart] #2563547
10/13/18 07:29 PM
10/13/18 07:29 PM
IN
ahy Offline
ahy  Offline
IN
I like that vintage Dodge truck... both the 400 and 700 are nice.
Does the 700 have a 2 speed rear?
Re: D400 - Should I convert from Manual to Auto? [Re: Truck Y'all !] #2564225
10/15/18 01:10 AM
10/15/18 01:10 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Turbocharge the slant!
Re: D400 - Should I convert from Manual to Auto? [Re: ahy] #2564303
10/15/18 09:48 AM
10/15/18 09:48 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I believe it is a 5-speed, I haven't had it on the road yet and it doesn't have the extra switch for the 2-speed rear... shruggy
A-Body's RULE!
Re: D400 - Should I convert from Manual to Auto? [Re: Truck Y'all !] #2569669
10/26/18 09:52 AM
10/26/18 09:52 AM
An NV4500 with hydraulic clutch would be interesting, too. I see where the Lakewood bell can be used behind B/RB but I can't seem to figure out if a certain McLeod hydraulic throw out bearing can be used to make it all work together
Re: D400 - Should I convert from Manual to Auto? [Re: Truck Y'all !] #2574336
11/05/18 11:38 AM
11/05/18 11:38 AM
OK, so...final note on this topic from me: cutting out the bellhousing crossmember and somehow trying to fashion a replacement which leaves room for the Lakewood bell OR a 727 is not on my list of things to do.
I'm gonna keep searching for the one-year-only bellhousing which permits me to run a six-bolt flywheel with the hydraulic clutch bellhousing. I know Bud Thorp has some...
Thanks for the thoughts and suggestions. I love Moparts.
